1 - 4 of 4 Posts
I'm in the midst of doing the larger brake upgrade on the coupe, still have it at 4x108, running off of the s2 forum thread using the s8 carriers, urs4 calipers etc. Looking for alternative rotors that would fit the 280x22 mm and the correct hat height for the coupe, although I can just get the 300 x 22 from the s4 and machine it though would love to not have to machine em down. The problem I'm running into is with the longer carrier bolts. Believe they are from the s2 avant, of course the part is NLA , curious if anyone has done this and found an alternative route for both the rotors but mainly the bolts themselves. Original bolts are 30 mm, I would need ones that are 35mm for this conversion to work.
Appreciate any input,
Thanks
Fantastic, thanks Greg. Appreciate it.
if you convert it to 5x112 using an B5A4 rear hub, you can use the B5S4 rear brake carrier, disk and the urs4/6 or D2 S8 rear caliper.
Everything bolts up, no shim, spacer, grinding. e brake works too
1 - 4 of 4 Posts
