121 - 140 of 177 Posts
Discussion starter · #122 ·
Thanks Sean. If anyone wants to see it up close off the car, I'm thinking ill go ahead and remove it and take a few pics of it by itself this weekend.
awesome idea with the dogbone mount - I might have to steal that idea for IC clearance!
Audilard said:
Looking good Dave!
Your looking good too Darin!
As far as the dogbone mount, I posted it for all to see. Take it if you want it yo!
The dogbone is a carquest mount p# 31-8200
It is slightly twisted so you have to put it in a vise and straighten it. No big deal.
Need to order a Cobra head for my turbo. Need to get my ecu back from Swanson. Hopefully he has the e85 mod done. I'm literally minutes away from firing this thing up. Then its down to the lab I go to get a v-band put on my charge pipe. I can't wait!
I'll take a few pics of how she sits and post them in a few.
So, update.
As I neared completion, I wanted to upgrade my heat exchanger for the AOW innercooler. The OEM secondary radiator that comes stock on the coupes is a nice thought, but seemed a fizzle when challenged.
So out with the old
And in with the new
It took some to finger that thing in there to fit, but that's how this build has been from the start, it all mostly seems to work out. If not at first, tweek it here, there, then it says...ok....
So after finishing up the outside build, for the most part, I went and fired it up like it had never been apart in the first place, and took it up to brents (savagerocco) place for the emissions and safety tests. Got it through, and now I am legal.
Still have a couple minor issues with the exaust leaking and I need to put a vband on the charge pipe at the turbo, but all in all, the car feels Effing awesome! Even at less than 5 lbs of boost. Can't open er up cause of two things, the vband/charge pipe thing, and I need to drive it like miss daisy to break in the clutch. Shouldn't be long before I'm on the dyno finding out what the roof is on this tearbo!
Great job Dave. Can't wait to see it.
Discussion starter · #135 ·
I can't help it guys. First step is to admit you have a problem.. Some day you may hear me say that.....but not today!
I'm also a procrastinator....I'll say it later. I'm just so sleepy right now.
Dave don't let them get to you. If you noticed in another thread floating around, I'm being accused of polishing my driveshafts. I have a similar problem, but not for shiney.....just clean!!
Discussion starter · #137 ·
So I've been driving my precious around for a few weeks or so. Swapped out the rear subframe bushings and trans mounts while I had the subframe out to weld/repair/paint anything on it that needed doing. Still need to order rear koni's and get em installed before Vegas. Will be doing front subframe this weekend. Also need new tires and an alignment as well. The tires I want are too wide for the wheels I have and will rub my tie rod, so I may be doing a slight bit of fab work to the front housings to boot. Possibly clocking the steering arms. Seems like the best and safest option. Havnt decided to install the LCA bushings or not. The ones that are in there aren't trash yet. I may hold off till next year.
This car is going to get me arrested! I want to dyno this thing and see what its pushing. Much harder butt dyno numbers than with the OEM K24. Real results will be nice to know for sure. Regardless, I love this thing! Freakin awsome. Of course Hanks is (I just peed my pants) awesome, but I'm not going there with this car.
A Few more pics with the phone.
You sure went together fast. I'm impressed. I think you ended up about where I want Her Urq to end up.....a load of fun, but not edgy and stupid fast. It looks waaaay nice!!
