1 - 13 of 13 Posts
can urs hubs be used for the rear with b5 brakes? or do i need the wholed thing from a b5? o and are the hubs from b5s4's and a4's the same? thanks!
CQ 5 lub conversion, rear:
A4Q (B5) rear hub
A4Q (B5) rear caliper bracket
A4Q (B5) rear brake disk
CQ rear brake caliper
thanks, ive heard of people using b5 s4 rotors and calipers anyone know whats needed to make that set up work?
u can use s4 rear caliper and disk. a4 not good cos it pulls thge ebrake from the wrong side
ok ya i think im going with the b5 s4 rotors and calipers, carriers. those should bolt right on to b5a4 hubs right?
I'm going to use a4 hubs and urs4 rear break and switch them side, handbrake should hook up.
let me know how that works, ive got urs4 rears already.. u using b5 hubs?
Not sure if this helps, but I'm running early B5 A4 rear hubs, with D2 A8 rotors, carriers and calipers. This combo bolts right up, with proper E-brake cable placement.
Requires C5 A6q rear brake hoses, though, as A8 stuff uses banjo fittings.
yup, a4 b5 hub, urs4 have vented rears.
I know it is an old thread. just to clarify part number for the future B5 A4Q come with 2 different hubs
dont use 4A0407615G it is 82mm hub for b5
use 8D0407615E (75mm hubs)
just in case you decide to buy new like I did
I used machined C4S4 front hubs and B5A4q rear hubs in my 5x112 conversion.
Fronts used:
-- RS2 caliper brackets
-- machined 3mm shim
-- 986 BoxsterS calipers
-- 323mm D2A8 rotors
Rears used:
-- B5 S4 calipers
-- brackets
--rotors
On the rears, the bleed nipples were upside down and made bleeding the brakes a major PITA. I grabbed a set of D2A8 calipers to fix this. The e-brake cable worked with a little finessing. Otherwise, I'd say the C4S4 rears mentioned above are the way to go.
1 - 13 of 13 Posts
