1 - 3 of 3 Posts
I'm getting the following message:
"The FileName buffer is too small to store the selected file name"
When I try to save the current configuration in my ECU.
Any clues?
TIA,
Carlos.
just a guess, but it sounds like you probably chose a relatively long filename to save on your computer, and the ECU will not support it.
Try using a shorter file name (and use a filename without spaces... that can mess up certain programs too).
Also be sure not to use any slashes, space or punctuation, only underscore to seperate letters.
1 - 3 of 3 Posts
