Flywheel insert, AQX engin large diameter flywheel
1K views 3 replies 3 participants last post by  newt
#1 ·
I have a v8 from a VW touareg, in order to make use of the stock starter location I need to use the larger diameter flywheel, and bellhousing that come on the touareg.
I have a nice aluminum 034 flywheel and clutch kit, but it is for the smaller diameter.
will the insert kit work with the 10 bolt AQX and larger diameter flywheel?
or if my current flywheel will stack with the flex plate, can I get the longer bolts from somewhere on the 034 website.
#2 ·
Very doubtful anything would line up properly on the ABZ insert, you probably want to look at the B6/B7 V8 flywheels, as those all use the larger style ring gears.
