Hi all,
Long story short - I fried my 034 EFI relay board (which was) providing switched power to ECU, Ignition Coils (x4), Fuel Pump, and Fan.
The ECU relay is the one that has melted, and I believe the damage goes beyond the socket. I did try to replace the relay itself, no luck.
I have determined that the relay boards are no longer available, so it is looking like I'll need to re-wire and determine a new solution.
Unfortunately, I am not sure how to use all my existing wiring most efficiently because I'm not sure how the relay and circuit board interacted.
Everything I need to re-connect is sitting there neatly wired to the relay board... can someone give me a hand figuring out the best solution to re-wire?
