my friend cannot get his car inspected unless the turn signals work.When you flip the signal out to turn left or right there are no signals 99% of the time, same as the hazard blinkers, however if you just leave them on( hazards) siting in the driveway if your lucky you'll see them turn on for 10 seconds then they shut off, same with the turn signals. I took the hazard solenoid out and cleaned the terminal because I read somewhere that the relay signal went through it, no luck
