1 - 20 of 74 Posts
I am starting to part out a late 1990 Coupe Quattro with a Tornado Red exterior and Black leather that is in good shape (leather is 7.5 out of 10, and door cards are pretty good.. Minus the normal fix needed on front door leather inserts).
Car is running and driving - 204k on motor
Cams $250
Block $200
Complete $500
Head w/Cams $350
Driver door, bare (no latch, window reg, seal, etc. - $100 each (Pass. side SOLD)
Hood, B3 - $125 (some typical clear coat peel)
Black leather interior - $500 (front and rear seats, carpet, door cards, & rear cards. No door pulls).
Center console, complete (front and rear sections with gauges, shift boot, ashtrays, covers, and rear diff lock switch) - $100
Door pulls, bare/no switches (interior) -$100 each
Driver side master window switch - $35
Pass. Side window switch - $15
Mirror adjustment switch - $20
Hatch complete (w/ "quattro" script defroster glass, wiper, etc.)- $200
Tail lights - $100 Driver, $75 pass (has some spider cracks around lock cylinder)
Tail light bulb trays - $30 each, $50 pair (some corrosion)
Kamei grille, B3 - $75
Fogs - $45, NO LONGER MADE (glass is good, but tabs are broken)
Black dashboard with vents, plugs, and speaker grilles - $125
15" CQ Speedline Rims - $250 w/ almost Brand New tires
Rubber door seals (NO LONGER AVAILABLE FROM AUDI) - $175 per side, shipped
Hatch seal, rubber - $100
Trip computer control switch - $35
Front subframe with stamped steel control arms, swaybar, etc., awesome shape - $125
Rear subframe complete w/ control arms, bushings, etc. No sway bar or provision for one (aka 90' chassis) - $75
Engine ECU - $75
7A 5-cylinder engine, complete but no accessories (no alt., ps pump, starter, AC, etc.) Runs great, Will NOT separate!!! - $400
01A, 5-speed transmission w/ shift linkage - $125
Brake bomb - $100
Brake master cylinder w/ reservoir - $75
Heater box, complete w/ everything including the blower motor - $100
Gas tank complete w/ sending unit, pump, basket, vac canister, gas cap, etc. - $250
Rear brake setup, complete (calipers, carriers, rotors, pads, rubber hoses) - $50
Wiper motor & transmission, complete w/ arms and wiper blades - $35
B-pillar interior trim panels - $20 each
C- pillar interior trim, pass. side - $20
For all smaller, hard to find, or items not listed, please post your requests below!!!
SOLD parts list:
Passenger fender
Driver Fender
Passenger door
Door mirrors
Headlights
Corners/turn signals
Window regulators
Headliner
Cluster
Driver Fender
Sunroof and Tracks
Braided Fuel Lines
Headliner
1 - 20 of 74 Posts
