1 - 6 of 6 Posts
Trying to do my HP2 conversion on my 91 200 with UFOs. I don't really have access to machine my UFO hubs to accept the HP2 rotors without sending them out. I have read that you can use URS4 hubs on UFO uprights and it will slightly change the offset, is that true? Also if I can get 100/200 G60 hubs, would that be a direct swap? I know they all use 82mm wheel bearings and I want to think it will be that easy, but I want to ask?
Also that being said, does anyone have any of these hubs to sell to me?
I have a set of 10v G60 uprights that I really don't need.
Awesome. Do you know if they are a direct press in with no issues also? If not I'll be willing to find out, how much do you want?
Won't change the offset unless you use 10v hubs. You want urs4/6 V8Q G60 hubs which can come from the front or back of the one of those cars.
Awesome great thanks austin! No others straight forward and they should clear HP2s without grinding them down correct?
1 - 6 of 6 Posts
