1 - 8 of 8 Posts
OK guys, pay attention. I've been chatting with one of the engineers and here's what he had to say about using a stock MC style ISV:
On GPO 1 or 2, put a diode across your ISV, with the cathode to the
+12v side of the wiring, and
the anode to the GPO output.
a 1n4003 or 1n4004 should do the trick.
This will enhance the linearity by about 4/1 since the flyback from the
solenoid isnt lost to the zener clamp.
GPO 3 and 4 are to be connected to a solid state relay, not direct to
any solenoid.
There is no flyback protection on those chanels.
You cannot drive any coil-type relay with GPO3 and 4.
The flyback when the relay is turned off, will damage the drive
transistor.
Jim,
Thanks, it makes sense.
Also would you mind to share the values you are using for the ISV table?
You can email me privately at [email protected] if you prefer.
Thanks,
Carlos.
Jim, I thought I'd shared this information with you in the past, its also in more recent tuning manual releases, pulled from the latest:
Boost Control: Boost can be controlled by manually manipulating the pressure signal to the wastegate or by using an outside electronic boost controller. Currently the 034EFI ECU will control boost pressure to a wastegate via one of the GPO channels (General Purpose Output). Only a relay should be connected to GPO 3 or 4, any solenoid device should be run off the 8A GPO1 or 2 Channels (Damage will occur if this in not adhered). Many different strategies can be applied, but most will involve pulsing a frequency valve to bleed or modify the wastegate pressure signal. This can be mapped via a GPO using various parameters. NOTE: If the range of the frequency valve is very limited using the GPO output, insert a 50-100V, 3-5 amp Diode across the solenoid terminals to increase its effective range. The cathode should go to the Power side, the Anode going to the ground side (ECU output)
Sweet, thanks Jim, I'll have to give this a try soon, the cold starting with no ISV isn't very much fun lately :p
Nice Jim, glad its working nicely
Oh yes, also, I was thinking that eventually we'll have to get you going on the IAC to free up one of your GPO channels, should you need it.
1 - 8 of 8 Posts
