New timing belt , new ngk plugs, bosch plug wires, cap, rotor etc. Timing marks dist. Align all on the money.
Motor fires up and runs on cylinders 2, 3, 4, 5. Pulled plug wire on #1 no spark no motor change.
Replace and pulled at dist cap. No spark to dist top. #1. Replaced cap, same symptons. #1 will not get spark but the rest will. Tested hall sender according to bently, 4v with hall window closed 17v when open bently says must be 0.0-0.5v when open or replace? Blink code 2113 hall sender.
Basically what I'm asking is can the motor still run 4 cyl with a faulty hall sender unit? Like its just not giving spark to number one but to the rest. I don't quite understand.
