Hi guys,
since you have more experience with this kind of fuel,i need your help.
The Problem:
at high boost (2.2-2.5bar,36psi) and correct lambda 0.75-0.8,i have serious misfiring (engine bogs).With leaner (0.86-0.9lambda) mixture (i had only 1 fuel pump previously,but now im running 2 044's) the problem is much smaller,but hey,i dont want to melt down the whole thing!
The weakest link is surely the ignition system,which is a stock 3B dizzy setup.Im going to install a CDI box to get some more spark,and i also ordered some cooler sparklplugs.Currently im running stock Bosch F5DPOR Platine plugs,and the had some funny deposits,but were mostly light brown.What kind of plug has the same properties like the stock one but is cooler?Do F4DPOR exists??
Engine spec:
AAN engine,GT37 turbo,tubular manny,Standalone EMS,120lb injectors,2 044 Fuel pumps.
I would like to keep the dizzy setup,and get the most out of it.
Any ideas are welcome.
Thanks,
Peter
11.18@202.5km/h
The Problem:
Engine spec:
Thanks,
Peter
11.18@202.5km/h
