1 - 4 of 4 Posts
I'm getting excited about crank the engine, but I just want to make sure about some things before the moment of true.
1. I mapped the injector triggers according with injector number. Trigger 0 to injector 1, trigger 1 to injector 2, etc. So, when I do the configuration I place then in the cycle according to the firing order, right? like:
Configuration Screen
Injector Driver - Injector Trigger
#1 #0
#2 #1
#3 #4
#4 #3
#5 #2
2. The coil + wires remain the stock one, right? It seems that they are controlled by a relay not affected by the removal of the stock ECU.
I might have more questions later today.
Thanks for all your support,
Carlos.
#1 #0
#2 #1
#3 #4
#4 #3
#5 #2
I think it should go more like this based on a 1-2-4-5-3 firing order.
Injector Driver (cyl #) - Injector Trigger
#1 #0
#2 #1
#3 #4
#4 #2
#5 #3
That's the proper way to do it. assuming your wiring looks like this
Injector Driver - Cyl #
#1 #0
#2 #1
#3 #2
#4 #3
#5 #4
You're right about the coil, you just need to hijack the (-) wire
Jim,
Thanks for replying.
My bad on the firing order, but the general idea is confirmed.
When you say hijack the "-" you mean that I keep the positive the way it was and the negative gets substituted by the trigger from the new ECU (the one with the 1 OHM resistor), right?
Thanks again,
Carlos.
ps. It looks like that I'll be cranking it today!!!!
That's correct Carlos, great job, keep us posted!
1 - 4 of 4 Posts
