I knew I should have pulled the trigger way back then.varia said:Aron used to make it, but not anymore![]()
Thanks!Speedyurs4 said:Looks great.
Thanks for that...I will look into using them. I would think a custom cut sheet of 12x36 would be sufficient for both sides. When you cut the sheets, is there anything special to do to the edges?Fbatwork said:Engine bay looks great!! Unfortunately I don't think anyone is making the carbon door sills anymore.
I've used these guys for Carbon fiber quite a bit - Their veneer is nice and I think that it would work very well for sills (this is what I will likely do if I ever ding my current carbon door sills...
The adhesive is good - would likely be a two person job and may actually want to remove the doors but it will roll quite tightly.
https://dragonplate.com/Twill-Weave-Car ... er-48-x-96" onclick="window.open(this.href);return false;
For a thinner veneer you can use a good pair of scissors or a razor / utility knife. For frays I trim any outlier strands and then use a clear lacquer to reseal the edge.jbrentd said:Thanks for that...I will look into using them. I would think a custom cut sheet of 12x36 would be sufficient for both sides. When you cut the sheets, is there anything special to do to the edges?Fbatwork said:Engine bay looks great!! Unfortunately I don't think anyone is making the carbon door sills anymore.
https://dragonplate.com/Twill-Weave-Car ... er-48-x-96" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Thanks Chris!varia said:You can go straight up a bit with the hard line and make the connection then go out to the fender-well
Thanks. I used this stuff, along with hole punches, rivets, and some plastic retainers.Fbatwork said:Flaps look great, what did you use for material?
Positive post on the fan is the one with the big honking insulator on it. The one that's in contact with the body of the fan is ground/negative.jbrentd said:Made a bracket for and mounted my fan resistor pack. Also got most of the fan wiring done. Does anyone know which post on the 500W fan motor is positive?
Thanks, that's what I thought, but didn't want to assume.Berserker said:Positive post on the fan is the one with the big honking insulator on it. The one that's in contact with the body of the fan is ground/negative.jbrentd said:Made a bracket for and mounted my fan resistor pack. Also got most of the fan wiring done. Does anyone know which post on the 500W fan motor is positive?
Thanksjbrentd said:Thanks. I used this stuff, along with hole punches, rivets, and some plastic retainers.Fbatwork said:Flaps look great, what did you use for material?
NABOWAN Solid Rubber Sheets,Strips,Rolls 1/16" (.062") Thick x 11.8" Wide x 47" Long Neoprene Rubber Mat https://www.amazon.com/dp/B08G5211B6/re ... UTF8&psc=1" onclick="window.open(this.href);return false;
