1 - 8 of 8 Posts
· Registered
Hey guys, I'm here to document progress on our C4 A6 Avant dubbed AYeet. The original AYeet is long gone, sadly. It was a 1995 A6 Avant FWD that I had picked up for $500 in Chicago and used as a trail runner, all dressed up in Hella rally lights and a roof mounted light bar. This car was a blast and was pretty reliable as far as trips and driving was concerned. After a spring trail season bombing through ATV trails and being choked out with water about half a dozen times, the exhaust flange broke off at the exhaust manifolds and I decided it was time to sell it as there were no manifolds or exhaust pieces left out there. I ended up selling it and it was passed around until it eventually got abandoned in someone's back yard, got cut up and scrapped. I wish I would've known what happened as I would've bought it back and made a trailer out of it :bangshead: 🔨
Wheel Automotive side marker light Tire Vehicle Land vehicle
So, while browsing around on Facebook Marketplace, I came across this twin to v1. It was a 1997 A6 Avant Quattro in the same Emerald Mica and Ecru interior but in MUCH better shape. Perfect interior, near perfect exterior paint and mechanically in great condition at a very reasonable price.
Wheel Tire Automotive parking light Automotive side marker light Car
So we loaded up and hit the road to pick it up for a nice daily driver for my fiance. The deal was done after chatting for an hour or so with the owner about the stories the car has and how they came to purchase the car. The car had the typical leaky 2.8 v6, leaky exhaust, a mismatched front bumper, faded front right fender and some rear bumper damage. Pretty normal stuff of the C4 chassis. I had the front bumper and headlamp sprayers resprayed and reinstalled.
Car Tire Wheel Land vehicle Automotive side marker light
We ordered new brakes all around along with new CV's as the boots were tearing. Life was good with AYeet v2, until one night driving around town when the coolant warning light came on. I checked the level and it was fine, so I started digging on the forums for normal causes. Number 1 was a new coolant reservoir and sensor, nothing changed. We just continued to drive it thinking it was something with the circuit. Eventually steam started coming from the cowl, had the heater core just let go? The coolant leak was coming from the heater core outlet. So I ordered up a heater core and new hoses, the blower motor also had the typical squeak so I ordered a new blower as well. We tore it apart the next weekend and changed the core and the blower. I then bled out the cooling system, and air kept coming out of the bleeder on the crossover... and coming... and coming. After about 20 minutes of hissing, I knew something was up. At this point, everything pointed to the dreaded head gasket leak. I started collecting parts, Reinz head gasket set, Meyle head bolts, FCP assembled timing belt kit with the special sprocket holding tool, new Bosch water pump, new valley pan gasket.
Motor vehicle Automotive tire Auto part Engineering Vehicle
Crankset Photograph Bicycle tire Automotive tire Bicycle chain
Motor vehicle Light Automotive tire Automotive design Automotive wheel system
We also narrowly avoided a massive headache. The headgaskets must've been replaced at some point already, being Reinz gaskets and updated head bolts installed.
Hand Automotive tire Finger Wood Gas
We had the job done in 2 days worth of work, the exhaust manifold hardware being the worst part of it. All said and done, car running perfect. But wait, there's more. After idling for about 15 mins, the coolant light came back on... I noticed the radiator fans never kicking on. I slapped the scanner on and watched the temp rise up to 215* with no fan kicking in. The dip you see is from me turning the blower motor on and pulling out heat through the heater core.
Gadget Audio equipment Electronic instrument Font Automotive design
On a whim, I replaced the coolant fan switch on the radiator and nothing changed. Then I decided to pull the radiator and flush it out, while taking it out, a hole got gouged in the core and a new radiator was ordered and on the way. While swapping everything over, i pulled the new coolant fan switch out to swap over and noticed the hole was plugged full of gunk. The bottom of the radiator was completely filled with gunk/mud looking stuff. So that was it then right? Actually yes this time it was. Since then, everything has been hunky dory.
Tire Vehicle Hood Wheel Automotive tire
I addressed the massive exhaust leak due to someone hacking apart the catalytic converters and emptying them. I chopped them out and replaced them with test pipes. This turned on the CEL due to no downstream O2's, this will be addressed later.
Motor vehicle Automotive tire Automotive exterior Wood Automotive wheel system
· Registered
Discussion Starter · #2 · (Edited)
Now the modifications, first off I put on a set of ASA GT1 18x8 ET35 that I had refinished and wrapped in new Pirelli PZero summer tires.
Tire Automotive parking light Automotive side marker light Wheel Vehicle
The wheel gap was absurd at this point, so I asked around the Facebook groups and was pointed towards the H&R 29800 springs. I ordered a set and installed them, the grin was ear to ear. The 'stance' was perfect, the wheel and tire fitment was perfectly flush to the fenders. Exactly how I wanted it.
Automotive parking light Tire Wheel Car Vehicle
While browsing eBay for NOS Audi aftermarket parts from Kamei, I happened across a set of headlamp covers that were not the Kamei models but a custom made set from ben_tuning in Kazakhstan. They were a very reasonable price, so I ordered them up. They eventually made it through customs and arrived unharmed. I sent them off to my painter and had them matched. Install was easy and fit is pretty solid. They look much better than the ones offered by Kamei.
Vehicle registration plate Tire Car Vehicle Wheel
We attended a local car show, but not before having the whole car cut and buffed! The results speak for themselves.
Wheel Tire Automotive side marker light Vehicle Car
Wheel Tire Car Sky Cloud
We added a set of roof rack crossbars and a Thule Mountaineer ski box. There was one problem though, the ski box was touching the antenna mast. I started looking for options and found out there were universal 'shark fin' style antennas that simply screw into the base where the original mast threaded. I had that painted as well to match and installed. Fit is great, reception is also exactly the same as with the traditional mast.
Peripheral Computer keyboard Input device Hood Black
Car Vehicle Window Motor vehicle Automotive carrying rack
Wheel Automotive side marker light Automotive tail & brake light Automotive parking light Vehicle
The ASA wheels are a bit bent prior to me owning them sadly, so I was on the hunt for new wheels. Eventually I found a set of Fifteen52 Tarmac 18x8.5 ET45 with new Continental Procontacts for a decent price and scooped them up. I think they look fantastic on the car.
Tire Wheel Car Vehicle Land vehicle
· Registered
While doing some maintenance I decided to address the number of burnt out bulbs in the 3rd brake light. I replaced them all with new bulbs, and found that half of them still didn't work. I went through and cleaned all the terminals to no avail.
Automotive lighting Motor vehicle Bumper Automotive exterior Automotive tire
At this point I thought I could easily have a PCB made up and solder in LED's to replace this old setup. So after a bit of work with a ruler and some time in KiCAD, I had a solid design that would function perfectly. I ordered the PCB's through JLCPCB and waited for them to arrive. After all the parts were here, I assembled the first one and installed it in the car. I knew this would trigger a bulb warning light, and it did. I had preemptively ordered some load resistors used when installing LED's in cars. I crimped it in and the warning was gone. I even started selling these as kits on the Facebook group and other forums.
Computer Computer keyboard Peripheral Input device Personal computer
Automotive parking light Automotive tail & brake light Automotive lighting Hood Vehicle
I designed one for the sedans as well as the Avants.
Computer Peripheral Input device Musical instrument Black
Vehicle Car Automotive tail & brake light Land vehicle Automotive lighting
Now the skunkworks stuff. We decided to 4.2 V8 swap the car as the AFC was getting a bit smokey and weak. So far, I've collected a set of PT headers, NOS S6+ engine brackets, and an upper radiator hose from an S6+.
Motor vehicle Gas Engineering Automotive design Automotive exterior
Big brakes are in the works as well, having acquired a pair of multipiece rotors from a 2018 R8. They measure 365mmx35mm and are 2 piece and scalloped. They should pair nicely with a set of RS5 8 piston calipers and custom brackets will be needed.
Automotive tire Wheel Vehicle brake Bicycle part Font
· Registered
Heres a little lakeside sunset photo shoot with the new wheels installed. Fitment required 10mm spacers in front to clear the spindle.
Wheel Tire Car Sky Vehicle
Wheel Tire Sky Car Vehicle
Tire Wheel Automotive parking light Sky Land vehicle
· Registered
So a different motor kind of fell into our laps. A few months ago I received a message on Facebook from a guy who picked up an urS4 that had been wrecked asking if I wanted any of the parts. He sent me a couple videos of the car and it was clear that it was in some seriously bad wreck. Both frame rails were pinching the engine in place, not letting it come out. I told him I'd let him know if we decided to buy anything from the car. Some time went by and one of my personal friends asked if we wanted an AAN and 01E, apparently he somehow managed to get the powertrain out of that urS4. So after some haggling (not really, I made an offer, he counter offered and we agreed), we came home with this!
Automotive tire Motor vehicle Automotive lighting Automotive design Rim
A glorious AAN and 01E, in need of some serious love. We dropped it in our garage and I began assessing the damage. All in all, it needed more money in parts than we spent on the whole powertrain.
Automotive tire Tread Motor vehicle Automotive design Gas
Let's being repairing the transmission first. When the car was in the wreck, it tore the left CV stud shaft out of the transmission. In turn, it pulled the retaining bolt along with the threads out of the front diff and broke the speedometer ring.
Tire Wheel Automotive tire Motor vehicle Tread
I pulled off the front diff access cover, and removed the differential along with the speedometer ring.
Automotive tire Motor vehicle Automotive lighting Alloy wheel Watch
Automotive tire Gas Auto part Machine Motor vehicle
Here you can see the piece that had its threads torn out. Luckily this was the extent of the damage.
Camera accessory Automotive tire Headgear Gas Cameras & optics
I took the diff to work the next day and disassembled it. The plan was to repair the threads with a helicoil kit. It went extremely smoothly, and the result was good enough to toss back together.
Hand Automotive tire Finger Household hardware Thumb
Wood Automotive tire Gas Electric blue Tints and shades
Blue Wood Gas Automotive tire Screw
Automotive tire Gas Engineering Bicycle part Automotive wheel system
· Registered
Here is the passenger side engine bracket. The left side survived, along with the passenger side transmission mount. The left side transmission mount is also broken.
Azure Wood Grey Font Electric blue
I have a solid chunk of parts coming from iABED Industries to get this back in running order. Thanks to Issam for being a legend!
So far the needed parts list it:
right engine mounts (all)
left chassis engine mount
left trans mount
power steering pump and lines
alternator
idler bracket/cooling fan pulley
oil cooler and lines
oil filter housing
starter
valve cover
coils
tfsi coil harness
all timing covers
turbo manifold (I think I have a stock unit from my nogaro urS4)
turbo
all turbo lines
all coolant hoses
standalone and harness
both CV's (cut from removing the engine)
rear driveshaft
downpipe
wastegate
intercooler and hoses (I have a new fmic kit yet from the noggy car)
speedometer ring
clutch pedal assembly with master
· Registered
While looking around for a stereo upgrade for AYeet, I came across a video explaining how you can use the tape deck channels as in input for a Bluetooth Receiver to stream audio to the original headunit. Here's a writeup on how I did this modification!
· Registered
Currently working on a way to bring back functionality of the factory cellular phone! It'll be powered from the phone jack, but connected to my cellphone via bluetooth.
1 - 8 of 8 Posts
