1 - 2 of 2 Posts
ok well i got my head back from the machine shop to do the port matching on and they recommend i look into new valve springs....thoughts on this? The springs out of my MC have 155k miles and look fine. I'm sure they're worn some from stock spec, but i've seen a lot of these engines with a lot more miles and they are just fine.
look for some .02 cents on this one.....
TIA
jeff
Jeff, never really seen a stock VS go bad, but if I do a bigger cam I usually replace them with stiffer springs anyway, but I'd say your fine if you're using the stock cam. New HD Springs from Autotech run about $90 for the 10v I believe.
1 - 2 of 2 Posts
