Can I use a digital caliper to measure the lobes of the cams?
Measure the "base circle" and then measure the base and the lobe, subtract that from the 1 measurement (base circle) and that will give you total lift.Ronald G Wainwright+ said:Lil I just watched that vid & used that guid to measure. I still must b doing it wrong.
Something's wrong with Cuatrokoop's spread sheet, some of the calculations are incorrect:varia said:http://www.motorgeek.com/viewtopic.php?t=1612" onclick="window.open(this.href);return false;
