1 - 8 of 8 Posts
I have my 1991 Audi 200 running on IIc and stage 2 wideband/EGT controller.
I'd like to use the 2 outputs from the controller for a wideband and egt guage.
I'm proficient at using google and can't find anything.
I'd even purchase something similar to Zeitronix hacker afr display board, HINT HINT HINT
http://www.zeitronix.com/Products/Hacke ... aker.shtml
I want to be able to monitor egt and afr without the laptop open.
Thanks in advance,
Jason
You can use pretty much any display that takes a 0-5v signal and make the WB scale to the gauge.
I thought 034 sold Innovate displays no?
I believe the Innovate gauges only work with an Innovate controller.
The egt gauge's they sell come with the probe and everything as a seperate system.
I just need 2 gauges.
Architect, welcome home:)
Any chance you could make something like the link to the Zeitronix product?
I can assure you that the innovate analog gauge "display" works fine with the 034 WBO2.
For EGT one would need to change the scale to read in degrees.
Chan 3 analog output (on the 034 WB02) outputs 0 to 5v as a function of 0 to 1024 degrees C BTW.
Thank you so much for the info 0000GT
Those Auber Instruments are exactly what I was looking for, basically a completely programmable gauge using 0-5v linear inputs. I'm buying 2, one for Lambda and one for EGT.
Again, thank you.
Jason
1 - 8 of 8 Posts
