you get around it by using 323x30 S8 rotors, just like Porsche calipers are for 32mm too...greesha said:whats the bolt spacing of the evo caliper mounting bolts? also, how do you get around the evo having 32mm thick rotors?
Depends on the Porsche calipers. 996 calipers are for 28mm rotors.Mushasho! said:you get around it by using 323x30 S8 rotors, just like Porsche calipers are for 32mm too...greesha said:whats the bolt spacing of the evo caliper mounting bolts? also, how do you get around the evo having 32mm thick rotors?
is that non turbo only?90quattrocoupe said:Depends on the Porsche calipers. 996 calipers are for 28mm rotors.Mushasho! said:you get around it by using 323x30 S8 rotors, just like Porsche calipers are for 32mm too...greesha said:whats the bolt spacing of the evo caliper mounting bolts? also, how do you get around the evo having 32mm thick rotors?
Greg W.
Don't know the size of the 996 turbo rotors. Never had those calipers in my hands.my2000apb said:is that non turbo only?90quattrocoupe said:Depends on the Porsche calipers. 996 calipers are for 28mm rotors.Mushasho! said:you get around it by using 323x30 S8 rotors, just like Porsche calipers are for 32mm too...greesha said:whats the bolt spacing of the evo caliper mounting bolts? also, how do you get around the evo having 32mm thick rotors?
Greg W.
:lol: RS2 is not "a highly developed 4wd front engined car". Came with Porsche set up.skinthespin said:I have this set up for my CQ, would rather use them than a Porsche set up, after all its from a highly developed 4wd front engined car not a mid or rear engined car, so will be much better balanced.
