Hello, Im looking to buy one of the surge tank kits as a solution to increasing the fuel available to my ABZ coupe quattro.
I'm going to be adding a Garrett TA51 turbo, and running upto about 20psi boost, which should net me around mid 600 crank hp by my calculations.
I'm just wondering, if I mount the tank in the front of the car somewhere in the engine bay, will the stock fuel lines -5ish or whatever they are be adequate for this amount of power? I understand that the stock pump in this configuration will be pumping out plenty of fuel to feed the tank because its at more or less 0psi, but will the stock lines cope?
And also, is there a lead time on the kits, or are they always on the shelf? I'm looking to pick one up when I come over to the US next month.
Cheers,
Kieron.
Cheers,
Kieron.
