41 - 59 of 59 Posts
Discussion Starter · #42 ·
Turned out to be MFTS, S2 use their signal to limit boost like the 3B cars.
Disabled the feed to the ECU, no more boost issues.
Discussion Starter · #43 ·
Upgraded the rear brakes.
Who knew that a complete B7 S4 setup bolt on.
This system uses a vented 300mm rotor, so nice balance to the Big Blacks in the front.
Following the S2 forum thread:
http://www.s2forum.com/forum/showthread.php?t=22558" onclick="window.open(this.href);return false;
Everything fits under the 16" Avus, however the e-brake cable spring touches the rim, ever so slightly, so for now no spring, need to figure out a solution as I would like to keep the stock 16" wheels on it.
Also got the front suspension redone with HD Bilsteins and compbrake mounts.
Rear got Sport Bilsteins and full alignment... she's ready for winter duty (limited).
http://www.s2forum.com/forum/showthread.php?t=22558" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Nice car! Will a spacer on the rear wheels give enough clearance for the e-brake spring?
:thumbsup: Chris
Discussion Starter · #46 ·
:thumbsup: Chris
I am going to try that when I swap for winters.
Discussion Starter · #47 ·
Almost three years now.
Car has seen few trips and couple of winters
The original Lazer Red has faded just like any single stage paint left in the sun
So. A bit of TLC to bring it back to its glory.
I have decided to keep it summer only, since dumping $2k into the A/C system :(
Off to paint it goes.
Will be nice to see it all shiny again!
Discussion Starter · #51 ·
I stll have not figured that one out... took the pump out to replace with a rebuild unit just to find out that one of the ports on the rebuilt unit was different diameter, once the pump went back on, it stopped making noise, and trust me, it was no belt making that noise... ;) so not sure what taking it off and putting it back on accomplished but its been quiet since then.
Discussion Starter · #52 ·
I see primer!
Removed rear glass to make sure its good underneath.
That era Audi hatches have a reputation for corrosion.
All good now
Discussion Starter · #55 ·
The seats were option on most B4s. These came from a Later Cabrio hence the full headrests
I also have a set with open headrests from early CQ.
Discussion Starter · #56 ·
Getting there!
Paint all done, now reassembly
Very nice!
41 - 59 of 59 Posts
