1 - 5 of 5 Posts
1. One should connect a manifold vacuum line on the rubber hose at the back of the unit, right?
BTW, this is not written anywhere on the documentation. (or at least I couldn't find)
2. One should put a fuse on the power feed of the ECU, right? Amps (5,10,...)?
Cheers,
Carlos
1. yep, the hose connection on the ECU goes to manifold vacuum. Just to clarify, this should be a source of vacuum that is behind the throttle body that sees vacuum at idle and boost on.. well.. boost :p
2. Probably a good idea. I went overboard and made my own little board with a fat connection to the battery then individual fused circuits for all the custom stuff I was wiring in. I gave the ecu a 30 amp fuse and it hasn't blown. I may try stepping down a few amps at a time to see if lower is more appropriate.
here is a pic of the board I made with the little 5-circuit fuse block at the bottom and a junction box made from a radio shack project box with bolts sticking through the top sort of in the middle of the pic:
Premium Member
1) Correct, the vacuum line is essential for proper fuel calculations and load compensation/ignition advance/retarding. It should be connected to the intake manifold post throttle body.
2) Yup, you never want an unfused power source, I think a 15a fuse is more along the lines of what you want. If I recall correctly the 034EFI ecu at max load will pull/handle at most 16A. I'll check my docs
Carlos, generally I recommend a 30A fuse, you don't want that thing blowing, especially during a race, and 30A is plenty more than enough to protect from a short, etc.
1 - 5 of 5 Posts
