1 - 5 of 5 Posts
Have the basis for my IIc install online, I still want to add some software information to show the setups for the trigger angles and such, but the basic install itself is there. Pick your stage here:
http://www.newtsplace.com/90tq/index.ph ... Management
IIb and IIc are obviously quite similar with the exception of the trigger wheel, and coilpacks.
is this still somewhere? i'm in desperate need of some help wiring up this IIC on an AAN
dude, that link brought back memories from High School!!! Wow, time flies!!! I saw the COP and placed my order thereafter!!!!
This may be a silly question - I have access to an aluminum flywheel with a 60-2 trigger wheel on the outside edge - I'm thinking I should be able to use this and the stock location for the VR in the bell housing for my IIc setup.
any pro's cons?
My application will be for rally - so I figure it will be much less exposed compared to a crank pulley based trigger wheel...
1 - 5 of 5 Posts
