So the sunroof that came in my 200 never worked. I tried to diagnose it, figured out why it was not getting power. Once it had power realized that it did not function. The arms that control the tilt/and slide it back function were broken. I tested my parts car sunroof and it worked great.
Pulled the parts cars sunroof, pulled mine. Installed the known good one. I'm sure its just something is not seated right, slid in somewhere, or something. But when it is "neutral" the front is popped up, also it only slide 3/4 the way back (seems to be getting stuck on the roof panel). Also when I go to vent the rear the motor will turn but I have to push on it for it to actually pop up, even then it doesn't vent all the way and the front will come up a bit higher.
My theory is that these sliders are suppose to be in this channel and they are not. But I am not sure, I am about to go read in my bentley and see if it helps me at all but figured I'd post up here first.
Here is some pictures from the crap sunroof to show what I am talking about.
How it currently sits.
How the slider is now.
And with the two black nubbed "arms" in the rail on the inside.
Also if they are suppose to be in there, I'm assuming I need to remove the whole panel to get them to slide in there, correct?
