vwnut8392 said:
to my amazement i found a superchips sticker on top, i got curious and opened it and and found a chip inside with a superchips label. has anyone ever seen or ran a superchips modified ECU? i find this to be a bit odd as its modified by superchips.
*interesting* indeed...!
Interesting, as the only thing the Mac-02 ECU does is run ignition timing, and control the fuel pump (and do O2 sensor stuff)
As such, I'm not sure how much you *can* do to the ECU, except change the conditions when the fuel pump will cut out (like increase the boost cuthout threshold).
As such, "some" chip 'tuners' just did a hardware hack (the "Zener Clamp") that clamped the signal coming from the pressure transducer to a level just below the fuel pump cutout point. So, under high boost, pump wouldn't cut out. At teh same time, the ECU wouldn't know about the higher boost (as signal was clamped), so wouldn't adjust timing accordingly either..
On the other hand, some modified the ECU by re scaling the pressure sensor output using a resistor divider and re mapping the internal EPROM for this new sensor output, and also raising the overboost fuel pump cutout map inside the EPROM code.
Would be be very interesting to hear what other have to say about what you have..
