Jonus's 2,5'er has (as far as i know) only the tdi block and crank from the tdi bottom-end. Rods and pistons are custom.
I just took apart a 2,5 tdi block (making a 2,5 with AAN setup), and the pistons have (as mentioned) a depresion. But in that there is a dome. This dome is there for helping the diesel-spray in the chamber, as the spray is directed against this dome.
Also (as mentioned), the weight of rods and pistons are considerable higher than the 20VT oem internals. The X-pin is 26mm, and almost 2x the weight of oem 20VT x-pin.
All this makes it not very rpm-friendly, as the loads on bearings and crank will be nasty at 7000+......
And then the CR, i dunno the exact cr on the 2,5 tdi. But say it is 16:1. It is a considerable amount of milling on piston to lower this to, say 9. If not impossible!
And if all the above mentioned was possible, the dome in piston still had to be removed. As this would definately corrupt the combustion, pluss be a very likely hot-spot.
I asume that all the mods/machining that had to be done, would cost moore than a set of used aan,aby,adu,3b pistons and a set of custom rods.
PS!, Maybe some of you have heard the news, but Jonus has just dynoed his new-built 2,5 20VT. He made 740 hp @2,1bar on 98 gas with The motronic. And 1065 Hp/1016Nm @ 2,8 bar on race fuel and Autronic.
-Rune
