1 - 20 of 26 Posts
My '93 90:
My '90 Coupe
And the 4Runner...
So many things I want to do to both of the Germans...
***Photos courtesy of Kevin Salisbury (Tecknoquatt)
That coupe is waaay pretty!
what under the hood of each
OE 12v for the 90 with some tasteful mods like 30v MAF, VAP intake system, Stebro Exhaust with new Vibrant Cats
OE on the Coupe...minus 034 injectors and a couple other items...just cleaned up to work as a sound DD until I figure out the next engine setup...
And the 4Runner has the 4.7 V8 with an AFE Dry Filter...
What did Kevin replace the coupe with?
Discussion Starter · #12 ·
He made room in his wallet for a larger turbo on the RS2 Saloon and picked himself up a DD Toyota with a bit more cargo space...
Discussion Starter · #13 ·
Alex,
Do you have any extra parts from your old coupe in the form of ABS modules?
SC_09iduA said:
Alex,
No I don't, sorry!
Discussion Starter · #16 ·
So I'm having an issue trying to figure out how to close the gap between the front bumper and the B4 hood grille. I don't have B4 fenders but that wouldn't make for a fix, would it? Is it a matter of realigning the front bumper supports to tighten the gap up? Here's how it stands now...not bad but it can be better:
Also, where is a good place to source clear corners for the Euro bumper?
Discussion Starter · #18 ·
Hybrid_Hatch said:
There is a center support mount on the b4s. I doubt it was installed.
Hmmm, I'll remove the bumper to see what I'm dealing with. Most likely the case on not having the center support installed. Thank you for the quick response. Where would you recommend a person look for clear turn signals? eBay.de?
rock auto sells new ones, ebay.com also has replica ones shipped from Latvia, or the s2 forum is another good source.
1 - 20 of 26 Posts
