1 - 7 of 7 Posts
Im trying to reinstall my steering rack in my urs4 and for the life of me cant get it to line up correctly. The splines to the steering shaft are correctly aligned but the entire rack is still an entire inch further forward than it needs to be :frustrated:
Ive looked at numerous diy's and havent gotten anywhere with it. Anyone have any suggestions?
Im ready to let the first person with cash and a trailer just take it...
Then the steering shaft is'nt fully seated into the rack. Wiggle and push is the best advice I can give.
U have the hoses attatched to the rack yet?
Splining the steering shaft is always the hardest part. I found on T44s you can push the firewall boot out and turn the steering column from the engine bay with the steering wheel off, once it's lined up correctly it slides right in. Should be nearly the same on C4. HTH
Hoses arent attached yet but I made sure theyre not getting in the way.
And the splines are about 3/4 of the way into the u-joint, it just doesnt seem to want to go the rest of the way :curses:
SPLINES ARE IN! the rack still needs to move about 1.5in towards the rear of the car, but it feels like its getting hung up somewhere on the driver side
should i have the driver side of the rack in the 'slot' that it goes in in the fender well and slide it forward from there or do i need to position it some other way first?
1 - 7 of 7 Posts
