This is how cool the pipes look when off the car 😎😅 Not much to see more than alot of bends everywhere 🙈
So, I continued with the pipe going backwards. Drilled holes in the jackstandmount to get the coolant through it, will be a rubber hose there so I can easier attach/detach the tubing if needed to.
And it goes along the rail all the way right before the rear wheels
Where it goes slightly inwards before proceeding up over the rear axle.
I also made theese two cuties. One aolid and the other i drilled a hole in to attach a airvalve from a rim.
By doing that, and with 2 hoses, I could attach them to my tubing and put pressure within
Making it way easier for me to spot leaks, and there was many small leaks to fix.
I also made a new bracket for an electrical waterpump I've purchased. I'm still not sure if the engines waterpump is sufficient when it comes to flow water all the way to the trunk and back front again. It's the Davies Craig ewp150 with the small computer with it, so it will operate on it's own. And, I did a smaller flowcheck to see how much water it flows through when turned off, and it will not interfeere too much if it dies and only mechanical pump work.
I welded the bracket onto rear left jackstandmount.
And mounted the ewp onto it. The design of the mount is made so I can remove the pump by releasing the three nuts on the rubbers, and slide it out.
Timmy
Timmy
