1 - 20 of 61 Posts
Hi all, I'm looking using a W12 engine in my next project but finding out technical information on these engines isn't easy!
I know that these are several different versions with the first variation coming out in the Audi A8 D2. As this is the most likely for the conversion due to the rest getting closer to vehicles from 2006 onwards and may be involving can-bus... I'll probably be concentrating on this engine.
I've heard of weaknesses of the crank but don't which engines in particular this affects.
What is the engine to transmission bolt up pattern? The majority of W12s seem to come as autos so I'll be needing a flywheel etc which will work with it and a transmission. I know that the W12 is basically two VR6 engines together but does that mean that they use the VR6 bolt up pattern?
I have an 01E 6 speed kicking around...
Cheers.
MG
I cant confirm the tranny, but the body looks like a Type 147 Fridolin . .there was a great build thread on this link http://www.volksforum.com with a W-12 and other great tidbits..
That box appears to be an 0A2 from a FWD diesel 2.7 or 3.0. (very similar to a Boxster S box).
The First generation of W12's had crankshaft issues, something like 70-80% of the crankshafts broke between the #7 and #8 rod journals. I'd stay away from those.
I believe the W12 to have the same bolt pattern as the V10, RS6, and Rs4 V8 engines meaning it won't bolt to an 01E, and judging by the picture above it won't bolt up to the 0A2 either. (note an B7 RS4 gearbox may work).
The W12 was also installed in the Bentley continental and continental GT, but with a pair of turbos.
the type 147 project is here... http://www.volksworld.com/volksforumfrid
Thanks for the info so far.
I have been watching W12 engines come up for sale on ebay.de for the last 6 months and the prices vary from as little as 2K Euro to 6K Euro with varying amount of parts missing or added etc.
Obviously fitting a W12 motor to something else means I need everything from the car and I don't know at present what's involved in getting an Auto engine to run without the transmission... I guess I could run it with the loom, ECU and minimal parts from the trans etc.
This is some info I've managed to put together so far on the W12 engine.
Audi A8 W12 6.0 (AZC)
From 03/01-09/02
444 Bhp @ 6,000rpm
428 Ft lbs @ 4,700rpm
Notes: Only 750 Produced in the D2 A8.
Audi A8 W12 6.0 (BHT)
From 02/04-
450 Bhp @ 6.000rpm
428 Ft lbs @ 4,000-4,700rpm
VW Phaeton W12 6.0 (BAN)
From 05/02-
444 Bhp @ 6,000rpm
413 Ft lbs @ 3.250rpm
VW Touareg W12 6.0 (BJN)
From 08/04-
444 Bhp @ 6,000rpm
443 Ft lbs @ 3,300rpm
If the early engines had problems then I'll avoid them, thanks for the warning. The later I go, the more complications but I can live without having to replace the crankshaft on a W12!! Do you know which engine code the problems were with?
I'll have a look into B7 RS4 transmissions and try to get some more photos of the flywheel end of the W12 as that's going to give me the most info.
MG
I looked seriously into this conversion last year. There was a Phaeton W12 that came up for sale at a VW dealer. It was 100% brand new, and included all 4 downpipes with cat converters, 8 O2 sensors, both electronic throttle bodies, A/C compressor, alternator, P/S pump, coil packs, wiring harnesses, factory warranty, you name it. They were pretty anxious to sell it, and probably would have let it go for less than $5K. I was even looking to sell all of the stuff I didn't need (O2 sensors, cats, throttle bodies, etc.) and make some of that money back. Anyway, after doing a lot of research, I determined that it probably wasn't something I could pull off. For me, the deciding factor was the lack of a suitable manual transmission.
I was hoping that the W8 transmissions would bolt up, but they're typical 01Es, and wouldn't be a direct fit. Here is a pic I photo-shopped of how a 016 might bolt up to the engine:
As you can see, not enough of the bolt holes line up. There are probably other ways to make it fit, including some factory spacers that might work, but I couldn't see spending $5K on a motor, and not know FOR SURE whether or not it would work.
Something else I considered was light turbocharging. It looks like the typical VR6 turbo manifolds that you find on eBay would have worked for at least once cylinder bank. I think it would have worked for the other cylinder bank too with a little bit of work. I was thinking somewhere in the neighborhood of 6 PSI, non-intercooled would be good for 550-600 HP, without the extra trouble of intercooling.
I also think that stand-alone engine management would have worked with a single ECU. Since the crank is a split pin variety, I think the engine could have been run like a single VR6. You would just have to fire both injectors and both spark plugs on the opposing banks at the same time. It's not very elegant, but it's the same concept used on a lot of production cars in the '90s.
I still have a few more pictures/ideas if you need them. Just let me know.
To be honest I'd roll with a V10... Much simpler engine, lighter, smaller, and just more bad ass, it has FSI and if you got the wallet you can get the RS6 version with nearly 600hp.. There is one on ebay for $19,000.
The N/A version produce as much power as a W12 with 2 less cylinders and without all the retarded crap that comes with a W engine.
:stupid:
Only thing better than an I5 is a V10 in my book :D
Discussion Starter · #11 ·
Thanks for the detailed replies.
Looking at the photo, I can see fitting a manual transmission (along with clutch and flywheel) being one of the biggest headaches with the W12.
Re engine management, I'd stick with the OE setup as I have an idea of what's needed and have managed to get many other VAG engines up and running in other vehicles. I don't have the knowhow to map an aftermarket system.
A V10 sounds like a great idea but there isn't enough room in the car...
I had an ABZ kicking around which I almost fitted to it (and had running on the floor) but I'm wanting more hp and the W12 does it for me...
MG
MG
ABZ + supercharger or Twin turbo..
IIRC the V10 is an inch longer than the Cam belt V8 engines, and the W8 is slightly smaller in length but is quite a bit wider than both the V10 and V8.
MG
I work on a similar project with audi ABZ engine and if the V10 are only one inch longer you have room to fitting in the vw.
this is my project: http://www.motorgeek.com/viewtopic.php?f=6&t=12942
Discussion Starter · #14 ·
Just following on from this.
I'm still looking at the W12 as a possible engine for the project but the V10 is now also a possibility IF it will fit.
Does anyone have some measurements of the engine?
There's not that much room in the back of a Bug!
MG
Is the w12 not FSI? the newest 6.3l version is.
Are you planning on running stand alone, or wiring the factory computers in? A post above mentioned the amount of sensors, and I downloaded that self study pdf on the engine. Could you bypass some of the sensors if you were running a stand alone, or 2, one for each bank
Looking forward to this, if you actually go through with it.
side question, has anyone tried calling the phaeton owners hotline, would they speak to you if you are not a phaeton or w12 owner?
Almost positive you can use the SteveKen adapter kit for the trans. The wiring shouldn't be tough, the technology isn't that advanced for an 04ish car. Just use the W12 cluster and wire it up correctly.
The technology IS very advanced, even on a 2001 D2 6,0 A8L. The cluster's just a minute part of the jigsaw. To run the W12 cluster, you'll need to have pretty much the whole wiring, or at least the main (central) one, which is the dash harness.
I've rewired a D2 6,0 W12 that had suffered a minor dash fire. It took close to 4 weeks to get it up and running, making a new harness. Bear in mind, this car actually came with a 6,0 W12, yet it was a pig to rewire, and fought back every step of the way. After she ran, it took me a further week to eliminate bugs that had the cluster glowing like a Christmas tree.
It's not an easy job.
V8QinNJ said:
Kind of late to the conversation, but why not use a 1.9 TDI engine and power adders (bigger turbo, injectors & chip) Can easily make big HP and Torque numbers, is a very small power plant and trans choices are large..
Kind of like this http://www.youtube.com/watch?v=2vLOcva5 ... re=related" onclick="window.open(this.href);return false;
1) Limited rev range.
2) Sound - very flat, lacks "soul."
3) Power delivery.
4) Cost. Diesel's a lot more expensive in the UK than gasoline.
5) Lots of black smoke under full-bore throttle, more so once modified with bigger turbo and injector nozzles.
:? Even I wouldn't suggest a 1.9 TDI to someone who was considering a W12 :p It'll 'easily' make 200hp / 300lb-ft but beyond that it gets pretty expensive. Not sure anyone has managed 440hp from one!
Now a V8 TDI would be a different kettle of fish entirely, but thats probably a whole other thread :wink:
1 - 20 of 61 Posts
