1 - 5 of 5 Posts
As title states, looking for a set of rear s8 (D2) caliper brackets to use for the big brake swap on a b3 coupe. I had a set and somehow managed to misplace them.
Thanks
Are they any different from B5S4 or UrS brackets? They may fit as the D2 S8 & L rear calipers/brackets fit UrS cars. I used B5S4 brackets on my UrS with Urs caliper, rear of course...
I can not confirm nor deny this. Specifically I know that the s8 rear calipers will fit the urs4 rear calipers I have. I guess following that, you would think the urs carriers would also suit. I was following guidelines from a thread on here/s2 forum regarding the big brake conversion for the b3 coupe. I could try to run the numbers via etka and see if it would suit well.
1 - 5 of 5 Posts
