So, my daily driver 7A (or actually I have NM, but since the 7A word is more familiar here..) lost power steering and brake assist yesterday evening. Luckily I was making the last turn to my homeyard when it happened.
I examined the situation today and it seems that when turning the steering wheel even a tiny bit, there is coming a loud groaning/buzzing sound from the PS pump. Surprisingly quiet at idle (usually the pump has been operating with a little grinding noise)
The brake warning light in the cluster is flashing now which naturally means there is not enough pressure on the rack.
I changed the fluid to Redline today, I had been running Comma Central Hydraulic Fluid (rated to G 002 000) in there for a year. Changing them didn't effect at all like i assumed.
SO I'm just ensuring does this mean the pump is kaput. The belt is pretty old but if it slips would it be possible to cause these kind of symptoms? I personally don't see how that could happen. I also thought what if the "triangle pulley" is slipping? It's just pressed in right?
I'm pretty sure I can't find a used 20V pump easily here in Finland or do I even want one.. and the new ones cost waaay too much if they're even available.
I could be interested in going electric PS, but I wouldn't want to also have to change vacuum booster for brakes. Why do people always change to vacuum booster when going electric? They dislike the bomb, or the electric pump can't handle both PS and brakes? I would put the Astra pump but don't want to buy it if it doesn't work with the bomb.
I've been thinking about all of this the whole day. Help me gather some thought together. I need it running asap because its my DD.
