motorgeek.com :: Board index :: The Tech Lounge :: Bodies
Post new topic Reply to topic  [ 54 posts ] Go to page 1, 2, 3  Next
T44 clips for chrome trim above and below grill
 Post subject: T44 clips for chrome trim above and below grill
PostPosted: Tue Feb 21, 2012 10:37 am
Anyone know where to get the little white clips that attach the chrome trim to the grill and headlight frames on my 89' 200tq?
Thanks,
Jeff
89' 200tq - DD
85' Alfa Romeo GTV-6
 Post subject: Re: T44 clips for chrome trim above and below grill
PostPosted: Tue Feb 21, 2012 10:53 am
Dealer. Part number: 447853674C
Stock is limited though.
Nick
'13 Golf R - APR Stage 2+
'91 200 20v - whoa
'91 200 20v Avant - stock
Last edited by amd is the best on Tue Apr 17, 2012 7:44 pm, edited 1 time in total.
PostPosted: Tue Feb 21, 2012 11:35 am
burnin that gasoline
1999 Mercedes Benz SLK430 - M113 V8 swap
1995 Mazda Miata
2002 Jeep Liberty
2015 Chrysler 200S 3.6
PostPosted: Tue Feb 21, 2012 12:40 pm
If you are going to glue, I'd suggest silicon. It may be reversible at a later date.
John Anderson
04 XC90
91 200 20V - not stock
01 S8 - stock
97 GMC Sonoma - 436rwhp
84 928S - 270rwhp
73 MGB
PostPosted: Tue Feb 21, 2012 2:57 pm
I really need some of these. I've had my trim off for like 3 years because of this lol.
-Chris
'01 ///M5
PostPosted: Tue Feb 21, 2012 3:01 pm
I just ordered some up at the dealer the other day. I needed one, but when the dealer told me there were only 16 left in the country I bought 4 of them, lol. Good luck guys!
Nick
'91 200 20v - whoa
PostPosted: Tue Feb 21, 2012 3:18 pm
http://www.clipsandfasteners.com/Default.asp has a bunch of similar looking clips... I was going to take some measurements and call them or just order all the similar clips and see if i can find one that works.
1991 titan grey 200 20v avant, K24 7400, brembos, coilovers, treadstone IC, VEMS - DD
1988 tonado red 90 quattro AAN swap, holset hx35, VEMS - in progress
1991 pearl white 200 20v avant, EFR 6758 - in progress
quat·tro \ˈkwattro\ v (1980) : To use a full time all wheel drive equipped Audi to drive where other cars can not. He just quattro'd right through that snow bank.
PostPosted: Tue Feb 21, 2012 4:10 pm
:blog:
ebay "vw trim clip"
Austin
PostPosted: Tue Feb 21, 2012 5:48 pm
Thanks for all of your replys.
Austin, I grabbed a box of those clips on e-bay. Appreciate it.
Jeff
89' 200tq - DD
PostPosted: Mon Mar 05, 2012 2:05 pm
So just an FYI for everyone on those trim clips. I purchased them from seller "mk1autohaus". They are adertized as MK1 golf, jetta, cabby body trim clips, NOT Audi trim clips.
Great seller, got the clips in a couple of days but when I went to install them I discovered that they are a little bit bigger than the original trim clips. They fit the holes in the grill and headlight frames but I had to shave all 20 of them down some to get them to fit the slot on the chrome trim. I used a dremmel with an 80 grit sanding drum. You also have to sand a little bit off the expansion nubs that fit into the grill hole so the pin will push in and expand the nubs.
Anyway, turned out just fine with a little bit of work and front of the car looks a little less ghetto now.
89' 200tq - DD
PostPosted: Mon Mar 05, 2012 3:33 pm
:blog:
They are a tight fit but I never had to grind them down like that just a little heat gun action and then press the trim on. And I'm fairly certain that the one or two I ordered from the dealer at one point were the same size.
Austin
PostPosted: Mon Mar 05, 2012 4:06 pm
Heat gun might have worked but they were definitly larger. I might take a picture of a new one next to one of the old ones.
Still better than getting them from the dealer or using JB weld though.
89' 200tq - DD
PostPosted: Mon Mar 05, 2012 4:25 pm
good to know... I picked some of these up too
Casey O
Current Attire:
-2007 Mini Cooper S
Past Affairs:
-1991 Audi 200 20vt - GT35 and 24psi
-1991 Audi 90 20v
-1985 Audi 4000CS quattro
-1996 Audi Cabriolet 5 Speed
PostPosted: Mon Mar 05, 2012 5:11 pm
same
-Chris
'01 ///M5
PostPosted: Wed Mar 21, 2012 1:27 pm
i had the same problem, i think you and i talked about this the other day Chris.
https://www.facebook.com/groups/Yodalist/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; <-------- Buy Sell Trade European car parts, cars, bikes, accessories and more!
Join the group and post!
death 4kqt wrote:
zturnidge wrote:
i do know the coupe gt is fwd but they are still cool cars and i would love to have one.
fwd audi is like a super hot mermaid.....it might look sweet, but what can you really do with it?
PostPosted: Wed Mar 21, 2012 2:00 pm
ya, I guess we'll see when (if) I get mine from ebay.
-Chris
'01 ///M5
PostPosted: Wed Mar 21, 2012 2:15 pm
I think a better way might be to use the heat gun trick on the ones attaching the trim to the grill. Then shave down the ones attaching the trim to the headlight surrounds. Then you are assured the trim will stay on the grill but you can unclip it from the headlight surrounds fairly easily when you want to remove the grill. I shaved some of them down a little bit too much and they don't want to stay clipped as well as I would like. Luckily there are 32 in the lot.
89' 200tq - DD
PostPosted: Sun Mar 25, 2012 3:44 pm
Was there ever a consensus on this?
I found these.... they look similar:
http://www.clipsandfasteners.com/Body_S ... a12641.htm
Listed as "BMW" clips, but appear closer to the clips on my audi than do the "VW" listed ones.
91 200 20V TQA
PostPosted: Mon Mar 26, 2012 9:22 pm
Ace is the place, I just got some push in fasteners from Ace hardware. They seem to be holding great, and were only around .29 cents each.
Todd
86 4000TQ (project)
91 200 20vt
68 Olds Cutlass
PostPosted: Tue Mar 27, 2012 7:39 am
awesome! There's an ACE near me... do you know what the part number is?
91 200 20V TQA
PostPosted: Wed Apr 11, 2012 3:09 pm
Photo of ebay clip next to old clip - ebay one is a little bit bigger even if the tabs on the old one were straight.
89' 200tq - DD
PostPosted: Wed Apr 11, 2012 3:16 pm
amd is the best wrote:
Dealer. Part number: 447853674B
This part number corresponds to the incorrect clip (same larger clip you guys got off of eBay). I just wanted to point that out.
I think the correct thiner one is 447853674C. I'll be the guinea pig and order them too, lol.
*EDIT* - 447853674C is correct and they are available!
Nick
'91 200 20v - whoa
Last edited by amd is the best on Tue Apr 17, 2012 7:46 pm, edited 1 time in total.
PostPosted: Wed Apr 11, 2012 3:44 pm
:blog:
You're going to need a time machine if you plan on ordering them as they are NLA.
Austin
PostPosted: Wed Apr 11, 2012 4:08 pm
But the B's are. Strange
Nick
'91 200 20v - whoa
PostPosted: Fri Apr 13, 2012 4:19 pm
I just got some "Au-ve-co" BMW clips - the ones I linked to above. Car is in the shop but I'll update when I get it back and try them out. PN 1802389B..... initial glance over, without having the car in front of me, indicates they'll be a tricky fit. At worst I'm out $7.
91 200 20V TQA
  |  It is currently Tue Sep 22, 2020 2:09 pm
