motorgeek.com :: Board index :: The Tech Lounge :: Bodies
Post new topic Reply to topic  [ 54 posts ] Go to page Previous  1, 2, 3  Next
T44 clips for chrome trim above and below grill
 Post subject: Re: T44 clips for chrome trim above and below grill
PostPosted: Fri Apr 13, 2012 8:15 pm
yodasfro wrote:
You're going to need a time machine if you plan on ordering them as they are NLA.
Just so you know, I ordered 4 of the C's today from there dealer and there are hundreds in stock in the country. I'll know next week if they are correct.
Nick
'13 Golf R - APR Stage 2+
'91 200 20v - whoa
'91 200 20v Avant - stock
PostPosted: Fri Apr 13, 2012 8:52 pm
:blog:
I was only going off what it says at worldimpex. What dealer did you order them from?
Austin
PostPosted: Fri Apr 13, 2012 9:53 pm
I went right to my local dealer in Latham, NY. They did have to order them special but he said there were hundreds in stock. I'll let everyone know if they are correct.
Nick
'91 200 20v - whoa
PostPosted: Fri Apr 13, 2012 10:31 pm
awesome thread
i need some of these, my trim is all jank ever since i took it off and (tried to) put it back on, those clips are so brittle after 20 something yrs..
Julian
Indigo 200 20v- the shadow
PostPosted: Sat Apr 14, 2012 9:02 am
How much did they cost?
89' 200tq - DD
85' Alfa Romeo GTV-6
PostPosted: Sat Apr 14, 2012 9:06 am
Cool, please do post up if they're the right ones.
91 200 20V TQA
PostPosted: Tue Apr 17, 2012 1:51 pm
100% correct!! Woot!
Nick
'91 200 20v - whoa
PostPosted: Tue Apr 17, 2012 1:57 pm
Nice! Could you post a side profile pic? Curious how the ones I've got compare in that regard.
thanks!
edit: and are they $2.53 each, or per box? if that's each, yikes!
91 200 20V TQA
PostPosted: Tue Apr 17, 2012 2:01 pm
thanks!
Does this one help?
Nick
'91 200 20v - whoa
thanks!
Does this one help?
yes - thanks!
91 200 20V TQA
PostPosted: Mon May 07, 2012 6:15 pm
man these things are a pain. I don't have a Bentley manual (nor do I know whether it's even described in there) - does anyone have any tips or tricks for reattaching the chrome strip?
Clips into the grill and then slide the chrome on?
Clips into the chrome and then pop them into the grill?
91 200 20V TQA
PostPosted: Mon May 07, 2012 8:30 pm
grill?
tabs into the strips first i would say because they slide in, just would be tricky to position them to line up with the holes on the grille
neeeeeeeeed these so bad lol
Julian
PostPosted: Mon May 07, 2012 8:32 pm
just squeeze with hercules force to get them popped in, thats what i had to do at least. it is kinda annoying lol
Julian
PostPosted: Mon May 07, 2012 10:13 pm
The careful and strategic use of a vice grip with felt or a rag to protect the trim and grill has always worked for me.
My biggest struggle is getting the alignment of the grill and the headlight brackets just right, so the chrome doesn't pop back off as soon as you look away. It takes patience.
Current:
'91 200q Avant- Lago- time capsule
'91 200q Avant- Cyclamen- upcoming project
'91 200q Sedan- Bamboo- under the knife
'98 A6 Avant- Pearl White- current DD
'90 200q Avant- Pearl White- awaiting part-out
Past VW/Audis: '91 200q Avant, '07 A4 Avant, '93 S4, '94 S4, '91 200q Sedan (#2), '89 200q Avant, '92 Jetta GL, '09 TDI JSW, '02 Jetta VR6, '90 CQ, '88 90q, '91 200q Sedan (#1), '86 4000, '85 Scirocco, '92 S4, '01 S4 Avant, '98 A4, '94 Cabriolet
PostPosted: Tue May 08, 2012 7:36 am
They can slide in from the ends. After attempting to put them into the grill first and then slide the entire long chrome top strip on (which ended up popping 2 of them out of the grill), I finally slid them into the chrome strip, and then positioned to pop into grill by sliding them down the necessary amount. By that point I'd stripped 2 of the clips though.
So off to order more and try again!
91 200 20V TQA
PostPosted: Tue May 08, 2012 12:03 pm
They slide onto the ends, but then how would you go about putting the pins in?
Current:
PostPosted: Tue May 08, 2012 4:51 pm
align them with holes on the grill by sliding them within the chrome strip and pop them in. That's how I did it after my attempt to first put them into the grill and then slide the chrome strip on from one end failed. It wasn't a super tight hold, but it didn't seem like it would fall off either.
looks like AMD did it recently, maybe he can enlighten me/us
91 200 20V TQA
PostPosted: Tue May 08, 2012 6:02 pm
Are those the ebay clips or the OE (dealer) clips? Have you read this thread from the beginning?
89' 200tq - DD
PostPosted: Wed May 09, 2012 9:34 am
They're from the dealer. And yes, I have.
Thanks for the replies Audidrums and Heed. I'll try them again into the grill first and then the vice-grips squeeze trick.
91 200 20V TQA
 Post subject: T44 clips for chrome trim above and below grill
PostPosted: Wed May 09, 2012 9:49 am
The ones that get slid in are for the grill area and not above/below the headlights. The correct one for the headlight area go into the frame around the headlight then the chrome strip just gets pushed on to then.
Nick
'91 200 20v - whoa
PostPosted: Wed May 09, 2012 11:46 am
Yoda's said he had success softening them up with a heat gun before pressing on the trim.
89' 200tq - DD
PostPosted: Wed May 09, 2012 1:32 pm
My brand new ones required no heat. Just tapped the trim on with the back of a screwdriver. Popped right on.
Nick
'91 200 20v - whoa
PostPosted: Wed Apr 01, 2020 7:11 pm
Anyone got a current source for these? or a work around other then glue...?
thanks
87 QSW
88 Q sedan
91 20vt Avant
04 s60 R
16 Golf Sportwagen
08 Passat wagon tsi 6spd- goner
PostPosted: Wed Apr 08, 2020 10:21 am
Should still be available through Tradition.
PostPosted: Sat Apr 11, 2020 7:25 am
I just shaped the heads of zip ties to fit in the channel with wire cutters and slide them in, push the tail through the hole, the cut the heads off more zip ties and use them to lock in place. Dirt cheap and hold better.
XLR8
2003 540i/6 M-Tech #1090/1265 Spring/Summer/Fall
1991 200 20v Winter/Utility - MRC tune, Bilsteins, powerflex
  |  It is currently Tue Sep 22, 2020 12:38 pm
