motorgeek.com :: Board index :: The Tech Lounge :: Brakes
Post new topic Reply to topic  [ 6 posts ]
S4 b5 brakes on 91 coupe (front and rear)
 Post subject: S4 b5 brakes on 91 coupe (front and rear)
PostPosted: Wed Jun 10, 2020 2:57 pm
I have a 5 lug converted coupe (a4 hub in rear and urs4 hub in front) that needs new breaks.
I have a set of s4 b5 front and rear caliper that were given to my by a friend. I would like to use on my coupe.
Anyone know if this is possible? somebody told me that it is possible to run b5 s4 calipers on coupe with 5 lug but not sure what I will need to make it happen. What rotors, brackets, etc?
Thanks!
 Post subject: Re: S4 b5 brakes on 91 coupe (front and rear)
PostPosted: Wed Jun 10, 2020 4:35 pm
there are many better (fitment, clearance) brake out there then those HP2....
PostPosted: Wed Jun 10, 2020 5:12 pm
Thanks Varia. I read about other options.
I only drive the car a couple of hours on Sundays. Just road driving. So not looking into getting anything really expensive.
Since I already have the b5 s4 calipers, I was wondering if I can use them.
I also have a 1.8t b5 a4 with the hp2 brakes. For what I use my car for, they work ok.
PostPosted: Fri Jun 12, 2020 5:06 pm
Can't comment on the fronts but the rears you're going to run into issues bleeding the brakes because the bleed nipples are pointing down. If you want to use the rotors (which are a nice upgrade) you'll want to use D2A8 calipers and S8 carriers.
Speaking from personal experience, you're best served looking at other paths for an upgrade. Maybe keep an eye on the local junkyards for some Touareg or Cayenne front calipers. There are also other bolt ons for the rear like C4S4/6 calipers and rotors, or I believe some people are fitting B6/7S4 rears as well.
Find me on Instagram @pry4sno
|| 2010 Golf Sportwagen TDI /// #farmenwagen
|| 2002 Dodge Ram 2500 24v Cummins 4x4 #bertancummins
|| 1992 80 quattro 20v /// Eventual AAN'd Winter Sled
|| 1990 Coupe quattro /// #becauseracecar
|| Spare parts for sale
PostPosted: Tue Jun 16, 2020 1:51 am
Thanks for all the information.
PostPosted: Thu Jul 16, 2020 11:15 am
You may want to look for a non-Audi rotor with the same centering hole than can work with the HP2 calipers and the Coupe offset. I found a Volvo S6 rotor 286mm 5x108 that roughly works with the 90q20v offset and B5 A4 G57 single-piston caliper, just need to redrill 3 holes and grind the inside of the caliper carrier ~1mm wider or have the rotor lathed at O'Reilly Auto. I found that by looking at the Brembo European website and searching on rotor diameter and offset.
  |  It is currently Tue Jan 26, 2021 1:35 pm
