Author |
Message |
RennenMsports
Post subject: Biggest brakes that can fit behind 16’s Posted: Sun Dec 27, 2020 3:53 pm |
kickin' tires'n lightin fires |
Joined: Tue Nov 22, 2005 1:11 pm Posts: 854 Location: South Florida
I got a 91’ 80q and if I put 5 bolt hubs on with 16” wheels what are the largest calipers I can use? I’m thinking boxster s but not sure yet
_________________ Lite some tires and start some fires
91' 80q
Top |
varia
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Sun Dec 27, 2020 6:28 pm |
I post, therefore I am |
Joined: Thu Mar 12, 2009 10:42 pm Posts: 4037 Location: Lost Angels, Ca
again, it depends.... what hub (offset)? what wheel (ET)? I had Porsche 993tt with 16" fuchs Attachment:
_________________ ¯\_(ツ)_/¯
Top |
90quattrocoupe
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Sun Dec 27, 2020 8:50 pm |
mach 2 with my hair on fire |
Joined: Thu May 06, 2004 7:26 am Posts: 1481 Location: Long Beach, CA.
You can fit Boxster S behind the Avus 16 inch wheels.
Greg W.
_________________ They can have my car when they pry my cold dead fingers from the steering wheel.
Top |
RennenMsports
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Mon Dec 28, 2020 7:13 am |
What about these? Using urs front hubs Attachment:
91' 80q
Top |
RennenMsports
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Mon Dec 28, 2020 11:48 am |
varia wrote: its possible. but i dont think many ppl here used that wheel (and 6.5 pretty narrow) Greg and I have/had S2 hub on the front Gotcha! Thank u!
91' 80q
Top |
ringbearer
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Sat Jan 09, 2021 4:15 pm |
My UrS4 has a 2B kit with big reds and a 314mm rotor. Cleared 16”Fuchs, barely!
Top |
RennenMsports
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Mon Jan 11, 2021 9:16 pm |
Ok. Good to know but What do Fuchs look like? I’m curious. Sorry! I’m learning. Some insight. I bought an 01E 6spd. Trans. Before I even had an Audi.
91' 80q
Top |
90quattrocoupe
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Tue Jan 12, 2021 12:51 pm |
Top |
PRY4SNO
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Wed Jan 13, 2021 10:44 am |
Joined: Thu Oct 02, 2008 12:48 pm Posts: 1378 Location: Edmonton, AB
I know this is a bit out of left field but on the topic of brakes that will fit under 16s...
The mk6 Sportwagen TDI uses the same brakes as the mk5 r32 which uses a 312mm rotor and fits under 16" wheels. They're easy to find and cheap (~$100), and haul down my wagon pretty decently for what they are.
What are the chances they fit/work on a small chassis? Is there somewhere to find the specs on the spacing for the caliper brackets? They'd definitely be an upgrade over G60s.
_________________ Find me on Instagram @pry4sno
|| 2010 Golf Sportwagen TDI /// #farmenwagen || 2002 Dodge Ram 2500 24v Cummins 4x4 #bertancummins || 1992 80 quattro 20v /// Eventual AAN'd Winter Sled || 1990 Coupe quattro /// #becauseracecar
|| Spare parts for sale
Top |
RennenMsports
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Wed Jan 13, 2021 6:36 pm |
TorqAddict wrote: Yup apparently they will fit with 12mm spacers, I guess I was a bit off saying 15mm. I added a pic of Fuchs for Rennen Thank u for that! I’m going for the sleeper look. The only thing aftermarket I have so far on my 80q is the front bumper. I’m looking into regular steel wheels to hide the brakes. Cheap and strong. I think I’m going for boxster s calipers but not sure yet. Gotta collect all the parts that are just getting harder and harder to find. My 80q turned 30 years old in November
91' 80q
Top |
90quattrocoupe
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Thu Jan 14, 2021 9:24 am |
PRY4SNO wrote: I know this is a bit out of left field but on the topic of brakes that will fit under 16s...
What are the chances they fit/work on a small chassis? Is there somewhere to find the specs on the spacing for the caliper brackets? They'd definitely be an upgrade over G60s. The brakes used on the MK5 JSW, are the same brakes as the MK5 GTI. The brakes used on the MK5 R32 are a 345mm rotors. The GTI brakes are not really an upgrade, as the piston area is smaller than the G60s. The GTI brakes have a somewhat higher torque value, because the caliper is placed further out on a larger rotor. Greg W.
Top |
PRY4SNO
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Thu Jan 14, 2021 1:36 pm |
Makes sense. Thanks Greg.
Top |
90quattrocoupe
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Thu Jan 14, 2021 1:49 pm |
PRY4SNO wrote: Makes sense. Thanks Greg. You are welcome. The MK5 R32 brakes, will fit behind the VW 17inch Gaol wheels.
Top |
ejfluhr
Post subject: Re: Biggest brakes that can fit behind 16’s Posted: Sun Jan 17, 2021 10:54 pm |
Redline? |
Joined: Sun Jun 14, 2009 1:35 am Posts: 169 Location: Austin, TX
>>...uses a 312mm rotor and fits under 16" wheels. ... >>What are the chances they fit/work on a small chassis?
This doesn't work for the B3 due to the hub offset, but I run the 312mm A4 rotor with Boxster (non-S) calipers behind the 16x8" Fuchs on my Urquattro. I couldn't imagine anything larger fitting, either rotor or caliper. My 16x7.5" TSW wheels did not clear this combination.
The challenge is to find somebody to make a caliper bracket for this setup.
Top |
