Post new topic Reply to topic  [ 4 posts ]
FS: Misc UrS4 parts (all must go)
 Post subject: FS: Misc UrS4 parts (all must go)
PostPosted: Sun Oct 04, 2020 11:07 am
I have come to the realization that I need the space more than I need parts off my old 93 UrS4.
The car had ~142K miles on it when it was taken off the road.
I have the following list of AAN / UrS4 parts for sale;
Intake manifold
turbo oil supply line
turbo oil return line
turbo water return? line (attaches to freeze plug nipple)
connector cover (unbroken 1 locking pin missing)
engine harness
intake hoses (used oem)
turbo heat shield
fuel rail with injectors (has feed lines / 142K on oem injectors)
radiator fan resistor
timing belt tensioner bracket
oil pump
idle air controller
oil pressure sender
downpipe (oem)
fan shroud (plastic frame for mechanical fan)
electric fan with shroud
alternator (w 142K miles)
starter (w 142K miles)
water manifold
harmonic balancer
timing cog (0 miles, but has been installed for several years)
coil upgrade harness with coils (no name setup I bought many years ago and never used)
front calipers (from southern car)
unbroken gas pedal
grille (with rings / no UrS badge)
tan rear deck speakers (don't think speakers are good)
flywheel (was resurfaced and never used / timing pin on back replaced / has surface rust)
tail lights (several sedan and avant outers and nice set of inners)
power steering bracket
AAN MAF
Rear knuckles with hubs
Make me an offer for anything or everything.
 Post subject: Re: FS: Misc UrS4 parts (all must go)
PostPosted: Thu Oct 08, 2020 12:45 pm
You have any 5 speed 01E’s? Email me
if possible, thanks.
PostPosted: Thu Oct 08, 2020 6:19 pm
No transmissions.
PostPosted: Sun Oct 18, 2020 3:42 pm
Updated list to removed SOLD items.
Users browsing this forum: No registered users and 6 guests
  |  It is currently Tue Oct 20, 2020 7:31 am
