Post new topic Reply to topic  [ 107 posts ] Go to page Previous  1, 2, 3, 4, 5  Next
eS2 evolution
 Post subject: Re: eS2 evolution
PostPosted: Wed May 16, 2018 4:42 pm
I’m glad I checked before running wires... seat doesn’t clear everything so I had to revise my layout...
2010 Dodge Ram 4X4 1500
2003 Audi RS6
1991 Audi Quattro Coupe eS2
PostPosted: Sun Jun 03, 2018 7:23 am
Slow progress, continue bolting components into place. Fuel pumps mounted. 044 in tank into dual 1 litre surge tanks with Bosch 044’s.
2003 Audi RS6
PostPosted: Thu Jun 21, 2018 4:51 pm
Got home from Gatebil in Mantorp Sweden to a nice box...
2003 Audi RS6
PostPosted: Thu Jun 21, 2018 7:05 pm
Cleaned up rad support support mounts.
And test fitting radiator. When I ordered from Ron Davis they had never done one with a shroud and fan so...
Going to need to make a couple a offset brackets to pull forward approximately an inch, I’ll wait for final firmware until the engine is in so I’m not doing rework.
2003 Audi RS6
 Post subject: eS2 evolution
PostPosted: Thu Jun 21, 2018 7:20 pm
Yes, all over the place tonight as I’m not actually feeling like doing much...
Not doing to much with sound system, but want to be able to have some sound other than the engine occasionally!
I guess this is why there was no real depth to the sound!!
I’ve been collecting parts for quite a while, although the factory stereo is mint I wanted something with some modern features like Bluetooth for hands free phone etc.
The Kienzle unit I have keeps the look but modern features. SD card, USB, audio jack and blue tooth. Also has steering wheel controls but don’t think I’m going to try to integrate into anything.
2003 Audi RS6
PostPosted: Fri Jun 22, 2018 8:05 pm
Front end out. More cleaning to do and some paint required.
Way easier removing bushings with frame out. Used a hole saw, quick drill and the air hammer to pop outside bit of bushing.
2003 Audi RS6
PostPosted: Sat Jun 23, 2018 8:32 pm
Cleaned, painted, control arm bushings installed, ready to re install... tomorrow.
2003 Audi RS6
PostPosted: Sat Jun 23, 2018 8:43 pm
Question for the experts out there. As I am cleaning and putting stuff back together I am documenting parts numbers so that I can easily source parts...
I am trying to figure out the rotors that are on the front. I can’t find a part number anywhere. Only thing I have been able to find is AU16 inscribed. They are a 320 mm disc.
The hubs and knuckle are S2 parts.
Thoughts?
2003 Audi RS6
PostPosted: Thu Jun 28, 2018 1:46 pm
some info on the carriers and calipers? from my archives of the original build
"- I used bira system2 (996 cal/s4 rotor) on the eS2, and weighed it when I did the swap. It was definitely less in weight than the G60 setup, but I can't find the
details, and can't remember where I posted them. I just checked the bira website but no luck. I do remember the same relationship between
component weights, ie the S4 rotor was much heavier than the G60 rotor, and the 996 caliper was much lighter than the g60 caliper, for a net reduction of a couple pounds. Interestingly, I just put new front rotors on the S2, and one side rubbed the caliper very slightly such that I had to grind it down. (jack corner up, start engine in first gear, hold a file against the rotor edge!) Amazing that manufacturing tolerances could be so sloppy. It must have been at least 1mm in diam bigger than the one it replaced..."
So that rotor may be from an B5 S4
1991 Coupe Q Silver/Platinum
http://www.naaclub.org
PostPosted: Fri Jun 29, 2018 9:49 am
Thanks for the input. They are 996 big reds. The carriers are aluminum but don’t have any discernible markings on them.
2003 Audi RS6
PostPosted: Fri Jun 29, 2018 10:27 am
AFAIK only bira bracket was alu but that had markings
¯\_(ツ)_/¯
PostPosted: Fri Jun 29, 2018 11:39 am
check the other side of the rotor around the hub for markings
PostPosted: Fri Jun 29, 2018 11:45 am
Thank you. It was painted black (it was peeling and looked terrible... I’ll have a closer look.
2003 Audi RS6
PostPosted: Fri Jun 29, 2018 11:46 am
I will have a closer look didn’t see anything on my initial inspection.
2003 Audi RS6
PostPosted: Thu Jul 05, 2018 11:28 am
Looking for thoughts on finding some cast control arms to put on the rear to eliminate the stamped steel units. I am doing ball joints anyway and have bushings for the cast units...
Any negatives to this? Anyone have some from a part out?
Ultimately I would like to do the AK Motorsports units but that is out of budget currently...
Thanks
2003 Audi RS6
PostPosted: Thu Jul 05, 2018 12:27 pm
Thanks
its forged, but works on the rear.
I used diff ball joints
¯\_(ツ)_/¯
PostPosted: Thu Jul 05, 2018 1:58 pm
Yes those are what I was thinking. Just a little less deflection I think... Same ball joints as the front I trust?
2003 Audi RS6
PostPosted: Tue Jul 10, 2018 10:56 am
Did you ever confirm what front rotors you have? I have a B5 S4 with stock brakes and can take some measurements to help you confirm, if it helps. Just let me know what measurements you need.
Barry
Barry
2001 Audi S4
2005 Audi A4 Avant 1.8T Quattro
1988 BMW 530i (E34)
1999 Audi A4 1.8T Quattro - sold
2008 Mazdaspeed3 - sold
1990 Audi Coupe Quattro - sold
1990 Audi 90q 20vT - retired
1987 Honda Prelude Si - sold
Ottawa, Ontario
PostPosted: Tue Jul 10, 2018 5:44 pm
Barry
I did not, no part number anywhere. I’m out of town (again) but I think the critical measurement would be from hub side of the rotor to the inside disc face and the overall thickness of the rotor.
Thanks very much
2003 Audi RS6
PostPosted: Wed Jul 11, 2018 9:51 am
Okay no problem, I'll post some numbers up within the next day or two.
Barry
2001 Audi S4
1988 BMW 530i (E34)
Ottawa, Ontario
PostPosted: Fri Jul 13, 2018 6:17 pm
Front AKMotorsports track rods installed.
2003 Audi RS6
PostPosted: Fri Jul 13, 2018 7:02 pm
I like the idea of the heim joint track rods, but I have an issue of clearing the 10v WG.
Dallastown, PA
PostPosted: Fri Jul 13, 2018 7:06 pm
That’s unfortunate - talking to some guys when I was at Mantorp steering improves - little less flex, better turn in etc.
2003 Audi RS6
PostPosted: Sun Jul 15, 2018 7:05 am
Looking for some input - I have a couple of thoughts on this but wondering if others have found a really good way to clean the carpet while out of the car...
2003 Audi RS6
PostPosted: Sun Jul 15, 2018 8:03 am
Pressure washer with carpet cleaner.
Dallastown, PA
Users browsing this forum: Google [Bot] and 3 guests
  |  It is currently Thu Apr 22, 2021 3:40 am
