Author |
Message |
varia
Post subject: Re: eS2 evolution Posted: Sun Jul 15, 2018 9:36 am |
I post, therefore I am |
Joined: Thu Mar 12, 2009 10:42 pm Posts: 4052 Location: Lost Angels, Ca
Fbatwork wrote: Looking for some input - I have a couple of thoughts on this but wondering if others have found a really good way to clean the carpet while out of the car...
Sent from my iPad using Tapatalk Pro worked well on mine https://www.youtube.com/watch?v=MAg4PUs6EKQ
_________________ ¯\_(ツ)_/¯
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sun Jul 15, 2018 9:49 am |
I sprinkle rubber on my Cherios |
DE80q wrote: Pressure washer with carpet cleaner. That’s what I was thinking was just concerned about too much pressure... Sent from my iPhone using Tapatalk Pro
_________________ 2010 Dodge Ram 4X4 1500 2003 Audi RS6 1991 Audi Quattro Coupe eS2
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sun Jul 15, 2018 9:54 am |
varia wrote: Fbatwork wrote: Looking for some input - I have a couple of thoughts on this but wondering if others have found a really good way to clean the carpet while out of the car...
Sent from my iPad using Tapatalk Pro worked well on mine https://www.youtube.com/watch?v=MAg4PUs6EKQ" onclick="window.open(this.href);return false; Thank you. Was thinking of renting a commercial house steam cleaner as option 2. Sent from my iPhone using Tapatalk Pro
Top |
q20v
Post subject: Re: eS2 evolution Posted: Sun Jul 15, 2018 6:17 pm |
Joined: Wed Mar 08, 2006 9:51 pm Posts: 486 Location: Ottawa
Sorry it took a few days but I was elbow deep in 2.7t flex pipe replacement (down pipe removal is a pain in the B5 S4!), I pulled a rotor before putting the car back on the ground:
Rotor Thickness (~1-2000 km of use): 29.8mm Hub side of rotor to inside disk face: 46.4mm Hub thickness: ~7.35 Disk diameter: 320mm
Let me know if that helps or if you need any other specific measurements.
For the carpets, second what DE80q said, you can get industrial carpet cleaner at Home Depot etc and use hot water, should get most of the dirt out.
_________________ Barry 2001 Audi S4 2005 Audi A4 Avant 1.8T Quattro 1988 BMW 530i (E34) 1999 Audi A4 1.8T Quattro - sold 2008 Mazdaspeed3 - sold 1990 Audi Coupe Quattro - sold 1990 Audi 90q 20vT - retired 1987 Honda Prelude Si - sold Ottawa, Ontario
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sun Jul 15, 2018 6:20 pm |
q20v wrote: Sorry it took a few days but I was elbow deep in 2.7t flex pipe replacement (down pipe removal is a pain in the B5 S4!), I pulled a rotor before putting the car back on the ground:
For the carpets, second what DE80q said, you can get industrial carpet cleaner at Home Depot etc and use hot water, should get most of the dirt out. Excellent, thank you very much. Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Mon Jul 16, 2018 9:56 pm |
I was just doing a little cleaning before putting the front end / brakes back on. The front calliper’s had horrid brake dust baked on. I tried numerous methods, Magyars brake dust rim cleaner, brake clean, engine degreaser, varsol and finally a pressure washer. It was better but still not very good. So I checked with one of the local shops and he said the only thing that he knew for sure that would work was Sonax Wheel Cleaner. I have to say it was unbelievable. Half the effort from the day before. Fantastic results, if there other products work 1/2 as well I’m sold. Spray on, let soak a little scrubbing and washed a few time with water through the process.  Before   During cleaning  I may give one more spray and soak but super pleased with the results.   Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Tue Jul 17, 2018 8:55 pm |
Front end mostly back together, still need to do brake lines...   Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Fri Sep 07, 2018 7:07 pm |
Finally getting back to some work on the car, I’ve been travelling a ton for work and trying to get some family time so haven’t done a thing... I wish I had given a little more thought to doing the rear subframe bushings earlier, I should have waited until I dropped it out. I initially was planning on doing the rear end bushings with the frame in the car but figured it will be easier to do everything with the frame out.... I think I’ll seam weld up the sub frame while it is out... for anyone that has done it any concerns with warping if it’s not bolted in car? Way easier on a bench...    Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sat Sep 08, 2018 6:24 pm |
Pulled apart.   Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sun Oct 07, 2018 7:06 pm |
Ended up re doing my seam welding, didn’t like the first result, struggled with getting enough heat... much better round 2.   Pressed out the bushings in rear control arms...   Sent from my iPhone using Tapatalk Pro
Top |
jbrentd
Post subject: Re: eS2 evolution Posted: Mon Oct 08, 2018 5:53 am |
kickin' tires'n lightin fires |
Joined: Tue Nov 27, 2007 9:55 pm Posts: 766 Location: Owasso, OK
Nice work! I'll be in bushing land soon myself. And I like that Keinzle head unit. Where did you buy yours?
_________________ Brent 1991 CQ - Project Car
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Mon Oct 08, 2018 8:33 am |
jbrentd wrote: Nice work! I'll be in bushing land soon myself. And I like that Keinzle head unit. Where did you buy yours? I bought it on amazon.de through a friend, couldn’t find one here.... Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Mon Oct 08, 2018 9:20 pm |
With the rear suspension out I was able to do a little more cleaning.   Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sat Oct 27, 2018 2:57 pm |
Summers over, back to work. Rear subframe and suspension refurbishing.   While that’s drying doing some mock-up for placing fuel regulator and filter.   Then I realized that I left the strut tower brace at work... can’t really place anything until I can make sure I have clearance.  Find something else maybe make my ECU bracket...  Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sat Oct 27, 2018 7:23 pm |
jbrentd wrote: What coating are you using on the suspension and subframe? using Por15. It holds up very well, you do t have to get the metal perfect. I’ve just been using a flapper disc on bad spots , POR metal degreaser and the metal prep followed by two coats. Once fully cured you can take a hammer to it, needs a fairly significant dent for it to lift off. Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sun Oct 28, 2018 2:29 pm |
Anyone have thoughts on the phenolic intake spacer. Looking at it last night and really don’t like how it sits. Looks to me like it will interfere with the injector spray pattern? I drank the koolaid to start with but I think it only really helps with the heat sink effect in a drag race type of environment... Thoughts? Anyone have any Dyno results before and after?  Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sat Nov 03, 2018 9:18 am |
varia wrote: Fbatwork wrote: Looking for thoughts on finding some cast control arms to put on the rear to eliminate the stamped steel units. I am doing ball joints anyway and have bushings for the cast units...
Any negatives to this? Anyone have some from a part out?
Ultimately I would like to do the AK Motorsports units but that is out of budget currently...
Thanks
Sent from my iPhone using Tapatalk Pro its forged, but works on the rear. I used diff ball joints Attachment: IMG_20171008_184540.jpg Attachment: IMG_20171228_165441.jpg I notice in your picture that you have the ball joint on top of the control arm on the rear... on the front of my car the ball joint is hanging (also see you have KW’s installed). Not sure if it is just a ride height adjustment difference or? Does it matter? Thanks, Sent from my iPad using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Mon Nov 05, 2018 6:34 pm |
Ok so did a little more cleaning before rear subframe/suspension install POR15 degreaser works wonders.   Subframe in and control arms installed.  Rear diff still has to get installed. Going to do the 108mm flange install first. Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sun Nov 11, 2018 10:04 am |
Ok so still waiting for flanges to get here... I had a quick email session with Scott at Advanced, little concerned on the diff upgrade, he said that often when coming apart things get damaged that can’t be bought. Looking in line things like seals etc don’t look like they are available. Somewhat of a concern especially the side that has the diff lock seal... he has to custom makes shim kits etc and doesn’t even offer the service on rear diffs because of the potential cost overruns (my guess any way as I didn’t ask him. Going to talk to him tomorrow more on it, I’m banking on the fact that my base car was in amazing conditions with low miles / km. So my car didn’t have gear oil under it but it also hasn’t been driven a lot the last 10 years... never being one that’s smart enough to not dive in I thought I’d pull the flanges this morning... No drama at all, bolts came out and stubs with zero issues... seals seem ok, little stiffer than I would prefer but not bad.     Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Fri Nov 16, 2018 6:23 pm |
Moved inside the car, working on the final mock up of the hydraulic hand brake. I think I’m ready to tack things in place.   Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sat Dec 08, 2018 1:55 pm |
Little more progress, I’m happy with the outcome.   Centred in console quite fairly well.  Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sat Dec 08, 2018 3:56 pm |
Heat-shield...  Sent from my iPhone using Tapatalk Pro
Top |
Fbatwork
Post subject: Re: eS2 evolution Posted: Sat Dec 15, 2018 8:23 am |
Haven’t really talked about the heart of the car much.... planning on pulling it out of the crate this weekend so that I can start bolting stuff on... Built by Jeff Gerner @ Four Rings Performance... Wagner Intake - port matched Iroz exhaust header and Dow pipe FRP spec’d Cat Cam’s Mahle Pistons IE Rods CNC’d head FRP Micro polished crank Oil pump Water pump And the other usual stuff associated with a build...           Sent from my iPhone using Tapatalk Pro
Top |
