Post new topic Reply to topic  [ 107 posts ] Go to page Previous  1, 2, 3, 4, 5  Next
eS2 evolution
 Post subject: Re: eS2 evolution
PostPosted: Wed Dec 19, 2018 8:29 pm
I decided to not put the rear factory heat shields back on, put heat shield directly on the chassis instead.
2010 Dodge Ram 4X4 1500
2003 Audi RS6
1991 Audi Quattro Coupe eS2
PostPosted: Thu Dec 20, 2018 6:24 am
Whoa - drool :drool:
CURRENT
1995 90Q 20VT
- 1987 Porsche 924S - 1979 Porsche 928
PAST
1994 Cabriolet - 5 speed - 1986 Audi Coupe GT - 1993 Audi 90 CS Quattro - 1990 CQ - V8 - 1995.5 Audi S6 - 1993 Audi V8 - 2013 A5 Prestige - 2011 A4 Avant
PostPosted: Sun Dec 30, 2018 11:02 am
Ok so wasn’t happy with the rear cast control arm positioning... went back to AK MSports for some more parts.
Quality is 10/10. I’ll let some pictures do the talking.
Moving back to the front of the car, hate re work so I paused to get started on the CAE shifter install. Video of it but here are a couple of pictures as well.
https://youtu.be/PEMvqC9sOF8
Also did some seam sealing with some structural adhesive around handbrake bracket install (no I’m not a pressure welder that is confident in it being sealed)!
Now back to work on front end...
2003 Audi RS6
PostPosted: Sun Dec 30, 2018 6:03 pm
Front end back together, still need to center subframe.
My gearbox did not have one of the holes drilled to mount CAE bracket.
2003 Audi RS6
PostPosted: Sat Jan 05, 2019 5:06 pm
Pulled the engine out of the crate, starting to bolt a few things on before dropping it in.
2003 Audi RS6
PostPosted: Sat Jan 05, 2019 6:29 pm
Beautiful!
Maybe you want to add one more bolt for that seal.
First time i did like this:
after that:
¯\_(ツ)_/¯
PostPosted: Sat Jan 05, 2019 6:39 pm
varia wrote:
Beautiful!
after that:
Great idea, I wasn’t sure the best way to secure it, now I know!! Thanks.
2003 Audi RS6
PostPosted: Sat Jan 05, 2019 10:18 pm
varia wrote:
Beautiful!
after that:
An did you drill and tap the last bolt when your engine was torn down? I’m leaning towards your tab idea...
2003 Audi RS6
PostPosted: Sun Jan 06, 2019 9:11 am
Fbatwork wrote:
varia wrote:
Beautiful!
after that:
yes, drill and tap
¯\_(ツ)_/¯
PostPosted: Sun Jan 13, 2019 4:38 pm
Some good progress this weekend.
I keep thinking I should be done cleaning parts and then I find more grimy stuff...
Ready for a splash of paint.
Tilton twin disk will be going in. 034 bits to make it all work.
The factory heat shields should help keep temps down, does hide the Iroz manifold but function over fashion!! Still needs a cleaning.
Some Iabed Ind, glad we have people like Issam doing development still!
Doing port injection water/meth, measured and recheck a lot before drilling! Went to the boys shop for an extra set of hands and drill press...3 bits to get to the final size.
I’m Happy with the results
2003 Audi RS6
PostPosted: Sun Jan 13, 2019 4:43 pm
this is an awesome build
1991 Audi Coupe(S2 clone)(Round 2)
PostPosted: Sat Jan 26, 2019 5:45 pm
Went to start putting my flywheel on and hit a wall...
The crankshaft center that the flywheel goes over is .006 inches larger than the flywheel. I would expect tight but not certain if that is too tight?
Thoughts?
2003 Audi RS6
PostPosted: Mon Feb 11, 2019 6:34 pm
Went to install the speed sensor in the transmission, it is out of my other 01e. It’s way to long. Anyone have a part number for the shorter sensor?
This is the one that is too long.
Much shorter one needed...
2003 Audi RS6
PostPosted: Sat Feb 16, 2019 7:00 pm
Starting to plumb stuff before I drop the engine in.
Still have the Kool tool for rubber hoses - almost everything will be PTFE though other than coolant
-8 PTFE for the main fuel lines
Silicone fibreglass sleeve over anything near heat... some silicone tape to seal the sleeve.
Black fittings for supply and blue/red for return lines.
2003 Audi RS6
PostPosted: Sun Feb 17, 2019 3:53 pm
If you didn’t know, you’d think I was drinking when I put this together... regulator and then filter, that way the ECU will see the proper pressure... moving stuff now.
2003 Audi RS6
PostPosted: Mon Feb 18, 2019 8:59 am
Need a new T fitting to adjust fuel bypass and return.
2003 Audi RS6
PostPosted: Tue Feb 19, 2019 9:50 am
After some back and forth with people far smarter than I am, filter will be going back to my initial configuration... far easier to see pressure drops before the regulator...
2003 Audi RS6
PostPosted: Tue Feb 19, 2019 3:48 pm
Love it
PostPosted: Fri Feb 22, 2019 7:39 pm
Dropped the engine and tranny in so I can finish mocking everything up, it will have to come out one more time... pleased with the time, took around an hour without an engine hoist.
Tight by the down pipe.
2003 Audi RS6
PostPosted: Sat Feb 23, 2019 8:00 am
Nice, any info on how you did the header heat shielding?
1991 Coupe Q Silver/Platinum
http://www.naaclub.org
PostPosted: Sat Feb 23, 2019 8:38 am
I’m fortunate that the car was very complete, factory heat shield. Wouldn’t be to difficult to bed up though. 2 pieces.
2003 Audi RS6
PostPosted: Sat Mar 02, 2019 6:51 pm
Installed injectors and then wasted a bunch of time looking / planning wiring...
ID2000 so I can run E85 with the bigger turbo.
2003 Audi RS6
PostPosted: Sat Mar 09, 2019 11:04 am
progress
PostPosted: Sat Mar 09, 2019 2:45 pm
waxcoupe wrote:
progress
It’s going to slow down...
2003 Audi RS6
PostPosted: Sun Mar 17, 2019 7:04 pm
Simplest things seem to take the most time. Working on attaching all of the modules (Power Cell’s) in the car... still have one under the dash to do and then find a spot for the motion control module.
Removed the front fuse box, hacked it up, and attached the Power Cell.
Found a good spot to put the rear Powercell. Used some old material I had laying around, installed a couple of nutserts to hold everything in place...
2003 Audi RS6
  |  It is currently Thu Apr 22, 2021 3:57 am
