Post new topic Reply to topic  [ 124 posts ] Go to page Previous  1, 2, 3, 4, 5  Next
Project: my first 20v
 Post subject: Re: Project: my first 20v
PostPosted: Sat Sep 21, 2019 1:26 pm
Love the tool, it goes perfectly with your sig!
Little Egg Harbor, NJ
PostPosted: Sat Sep 21, 2019 1:34 pm
The problem is I could have found one... I just didn't like the price, and from a lot of the reviews I red, they didn't fit well. This one fits perfectly, and should work very well. Unfortunately trying to fix my truck today... Not going that well...
Dallastown, PA
PostPosted: Mon Sep 23, 2019 9:38 am
i dig that home made tool!
//Dave
PostPosted: Mon Sep 23, 2019 10:29 am
It should work well. I haven't used it yet. I had to fight the rear brakes on my truck for most of the weekend. All of that was for nothing! The inspection tech flat out lied of the inspection report, and the only thing wrong with my rear brakes was the PS adjuster...
Dallastown, PA
PostPosted: Tue Sep 24, 2019 2:18 pm
895 837 725B :drool:
Mike
1990 CQ 3b
PostPosted: Tue Sep 24, 2019 8:11 pm
Bowden cable?
Nevermind, looked a little closer at the websites. :slap:
Dallastown, PA
PostPosted: Sun Oct 06, 2019 5:41 pm
Spent half the weekend in the garage. The old bottom end it out! Took longer than I expected, but that's what I get for doing it by myself. It's been a long time since I took out an engine, and honestly forgot a lot of it. Hell, I couldn't remember how to get the radiator and condenser out, so I worked around it. At least it's out now, so I'll be cleaning a lot of things and getting ready to install the next 7A. I'll be working on getting the radiator and condenser out over this week as well.
As always, here are the pics of it out...
Oh yeah, as you can see in the hanging pic, I had to make some M11 eye bolts. I did that by cutting down a couple old head bolts and welding on some pieces of tubing.
Also, the scary part of the whole thing was the amount of rust falling off the subframe... I filled a standard household dust pan with what fell off while getting the engine out. I may need to find some better subframes...
Dallastown, PA
PostPosted: Sun Oct 06, 2019 7:45 pm
yeah the front subframe on my "new" cq is pretty bad so that will get replaced and binned.
Its a shame parts/cars are so hard to get over here. The one I just got would have been a breaker in the UK, here its a expensive project.
Carpet came out good, I might have to give that a go with mine soon
PostPosted: Sun Oct 06, 2019 8:17 pm
I'm going to take the subframes to work and have them walnut shelled. Then I'll make the decision as to what to do. I've seen ones that look much worse, so who knows.
Dallastown, PA
PostPosted: Mon Oct 07, 2019 7:06 pm
I'll get around to that on mine, just fitting some of the bits i've got stored. I might end up swapping out my front subframe to be able to fit a six speed.
I spent an hour on it at the weekend and dash is all out, heater box will be removed soon and binned and most of the interiors already out.
While the subframe is out its worth doing bushes etc.
PostPosted: Mon Oct 14, 2019 5:57 pm
Crappy pic of the things picked up in CT this weekend.
I'll go through it tommorow, and take better pics before I start to assemble things again...
Dallastown, PA
PostPosted: Tue Oct 15, 2019 12:00 pm
Here is a better look at my haul from the weekend. Lots of good parts I need, and some I don't need but can sell off to find the build.
Here is a more spread out pic.
So if you see something you might need, hit me up. I only need one of the BOS heat shields...
So then I decided it was time to clean up the rusty spots under the hood. I started with what looked like the worst area, the PS frame rail. I guess that was a good idea...
Now I'm kind of stuck. I now need to plate the frame rail, but I also need to tear down down the engine for a general reseal. I kind of lost my mojo now finding this...
Dallastown, PA
PostPosted: Wed Oct 16, 2019 6:58 pm
Know that feeling about losing mojo after finding hidden things. At the very least clean that back to see the extent of it, it might not be as bad as you thought.
how'd you end up with that many cruise control actuator things, think thats the most i've seen in one picture. I think the one on my cq is missing the arm/rod that goes to the throttle.
PostPosted: Wed Oct 16, 2019 9:34 pm
So that hole isn't nearly as bad as I thought. I opened it up quite a bit, and there is only a very small radius of corrosion around it. I'm going to clean the area, and plate over it. I also looked down into the rail, and the sides and bottom are in good shape.
The cruise vacuum actuators were part of a hoard from a friend of mine. He saved all the ones he pulled from cars that held vacuum. Now they have been turned over to me, as he is trying to clean some stuff out of his shop. I know the one has a rod on it, but not sure if it's the correct one for a 7A. I have lots of good parts here that will soon be posted up for sale. Don't need them taking up space in my garage for long either.
Dallastown, PA
PostPosted: Fri Oct 25, 2019 5:26 pm
I had plans to pull the engine apart for a complete reseal this weekend. All my parts showed up today, and I was kind of excited. This was until I pulled out the timing belt rockauto sent me. The belt they sent was 1/2" too wide, and way too long! I even made sure the part# was correct... I filed a claim with them, and should have another belt next week. Hopefully this one shows up correct. Not sure if I want to pull the engine apart without having the timing belt on hand though.
Dallastown, PA
PostPosted: Fri Oct 25, 2019 6:01 pm
Unless you think you're going to have trouble getting one that's right, I'd continue work.
The timing belt is one of the last things to go on when you do the engine over, and even could wait until the engine is reinstalled in the car (but the front is still off).
Eric Law
'14 A6Q 3.0t: fast & getting faster
'12 A4Q: not so fast but working on it
'90 80Q with AAN and Megasquirt, gone but not forgotten
PostPosted: Fri Oct 25, 2019 6:06 pm
This is very true. It's just frustrating to check and recheck part#'s and have the wrong part show up.
Dallastown, PA
PostPosted: Sat Oct 26, 2019 6:50 am
Been working on a couple things for this this week. I repaired the outlet flange on the BOS. It was pretty rough, and not much left of it. Luckily it was me steel, so a short time with the mig welder, and it was built up. Then the grinder, file, and stone got out to work to clean it up so it was flat and in line with the original.
The I was guy able to get the broken bolts out of the lower heat shield. That was a real PITA, and I managed to break 2 easy outs doing it. After figuring out how the 2 got assembled I went about figuring out what the tabs on the top of the upper portion were for. Turns out, I'm sure most of you already know, this gets bolted to the intake manifold. That's a problem, as it turns out there are some distinct differences between the early and late intake manifolds.
Again, something I'm sure most of you already knew... I'm still pretty green on the 20v, so learning as I go. Looks like I need to do some machining to the late style, so I have somewhere to mount the heat shield.
That's all for now. Going to take a nap, then try to make some headway on resealing the engine.
Dallastown, PA
PostPosted: Sun Oct 27, 2019 10:30 am
I'm unsure what version inlet was on my spare 7a engine I didn't pay that much attention to it tbh, I removed the inlet/sump and I think the only other bits I might keep off that engine is the head and distributor.
Having the engine in the car makes doing the big bolt on the front lower pulley easier.
PostPosted: Sun Oct 27, 2019 12:20 pm
You are spot on with that. I'm at a bit of a stand still because I can't get that out...
Dallastown, PA
PostPosted: Mon Oct 28, 2019 5:05 am
I dont know how many miles are on this engine, but the ring ridge is worse than my 350k+ mile MC1. The pic doesn't do it justice, but you can see the difference.
The bottom end that came with the car has almost no ring ridge, so l be putting the head onto that one. I have ordered a lower gasket kit, so now I will be replacing all the gaskets and seals on the engine.
Dallastown, PA
PostPosted: Mon Oct 28, 2019 7:22 am
Damn rock Auto! Now the belt is "out of stock" so I'll be receiving a refund... :frustrated:
Dallastown, PA
PostPosted: Mon Oct 28, 2019 9:00 am
So here is the belt on the original bottom end.
I believe that someone installed a new belt, and did it wrong. This is probably what happened to the head. I'll get it out, and check for damage. If nothing is found, I might just use this one.
Dallastown, PA
PostPosted: Tue Oct 29, 2019 7:07 am
So after ordering the gaskets I thought I was going to need, I was convinced I needed to pull the head. To get the head gasket, it was cheaper to buy the whole kit... I then decided I should probably replace the oil filter housing gasket and o-ring. To get the housing gasket, I had to order the bottom end kit! So. Ow I have many gaskets in pair, or hell 10's... Oh well, never hurts to have spares around!
Dallastown, PA
PostPosted: Tue Oct 29, 2019 8:00 pm
Glad to see they are still available. I need to get some soon for my 944.
Victor reinz is a good brand
  |  It is currently Thu Apr 22, 2021 3:02 am
