Post new topic Reply to topic  [ 294 posts ] Go to page 1, 2, 3, 4, 5 ... 12  Next
JBD's Project CQ - Starting on the 3B Swap...
 Post subject: JBD's Project CQ - Starting on the 3B Swap...
PostPosted: Sun Feb 21, 2010 3:55 pm
Well, after a couple of years of mostly lurking here on MG, I thought I would introduce myself now that I have a project to add to the site. I have owned two Audis prior to this one (a '96 A4 12v and my current daily driver which is an '01 A4 Avant).
CQs are hard to come by locally here in Oklahoma. So, the wife and I went to Chicago last weekend and we met up with the previous owner of this '91 CQ. It's rough, needs lots of work, but it was cheap. My plan, in time, is to fix it up and do a 20vt swap, but it won't happen overnight that's for sure. I'll be moving slow as time, space and money permit. Now, on with the pics.
While on the way home, it hit a milestone.
Brent
1991 CQ - Project Car
PostPosted: Thu Apr 01, 2010 8:04 am
Just checking in with some updates and some questions too.
Exhaust
I have received all of the parts needed for the exhaust (royal rogue). I went to the shop, get it on the lift and there's a fuel leak at the fuel filter. I don't remember seeing that before, but needless to say, it didn't get the exhaust put on. Hopefully, I can work on that this weekend.
Lighting
Within the next few weeks, I hope to receive a set of one-piece b3 euro lights. Only the high beams work on my current lights and they are missing the back covers. And the relay job from the PO needs to be re-done. Should I buy all of the parts myself and follow the 20v.org diagram or are there places that sell the relay kits already made?
Body Repair
At some point in the past, someone failed at putting the car on a lift PROPERLY. Here's a picture of the damage.
I know this won't be a cheap and easy fix, but how would you go about it? Have it pulled at a body shop or just have them weld in a new rocker panel? Part #3 is available from genuinevwaudiparts.com for $300 plus shipping.
Any help or suggestions are appreciated.
Brent
PostPosted: Thu Apr 01, 2010 8:09 am
only the high beams working was the light switch (stalk) on my 200, seems to be a common failure, they probably got relayed a bit too late.
XLR8
2003 540i/6 M-Tech #1090/1265 Spring/Summer/Fall
1991 200 20v Winter/Utility - MRC tune, Bilsteins, powerflex
PostPosted: Mon Apr 26, 2010 6:33 pm
Holy crap that is some nasty damage from the lift. Check with a local body shop - they'll tell you what your best option is. I'm guessing it won't be cheap either way you look at it.
Was this one originally for sale in southern WI?
Josh
90' Coupe Quattro Project (AAN'd)
13 Moonlight Blue C7 A6 Prestige
17 Ford Exploder Sport
PostPosted: Mon Apr 26, 2010 8:26 pm
Yep. I picked it up in Chicago.
Brent
PostPosted: Mon Apr 26, 2010 8:52 pm
Looks like it's in pretty good shape minus the lift damage.
Wish my fenders were that clean... Bumpers too.
2001 A6 2.7T
1993 Cummins "AUDIHLR"
1991 200 20VT
1990 V8 Quattro
1985 4000s 16v "NOTQUAT"
1999 R1
PostPosted: Mon Apr 26, 2010 9:23 pm
It's basically the sister project to boschman's project. only yours is much nicer looking that boschman's.
djapothecary-"I've removed the clock and think that would be an ideal spot for the rally style "you're stupid if you don't shift NOW" shift light . . . "
PostPosted: Tue Apr 27, 2010 6:44 am
I didn't show the bad side of the bumper. :wink:
Here's an S2 rear waiting to go on. I've also got a euro coupe front with fogs and turns on its way too.
While we're on the subject...what are the chances I can get these rusty bumper bolts off without damaging them? I'd like to mount the brackets and then install the bumper on the brackets.
Brent
 Post subject: You can either use heat or some form of a Liquid Wrench...
PostPosted: Tue Apr 27, 2010 6:57 am
Rustblaster, Wurth's Release fluid or the New stuff from Loctite that freezes bolts & nuts and makes it easy to take them off.
PostPosted: Tue Apr 27, 2010 6:58 am
PostPosted: Fri Apr 30, 2010 11:23 am
Looking good, Brent. When you are ready, I've got a Porsche Big Brake Kit if you are interested! ;) Can't wait to see the progress pictures.
PostPosted: Fri Apr 30, 2010 5:21 pm
soak them in kroil. my s2 rear bumper looked the same way. eastwood sell it. i swear by the stuff. dipenetrant might work to.
PostPosted: Fri Apr 30, 2010 6:59 pm
wire brush, run a die over the threads, and soak them. BTDT on stuff like that.
I'd have the rocker replaced, BTDT when I smushed mine on who knows what (seriously, I hit something, but NEVER found what it was no matter how many times I went back and looked). It's spot welded on from what I remember.
http://coupe.gofergusons.org
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
 Post subject: Re: JBD's Project CQ - Kind of like polishing a turd.
PostPosted: Tue Feb 15, 2011 12:35 pm
I guess this project has had a little case of "out of sight, out of mind" a bit. But I do have some updates. It's been getting some body work by a friend's dad when he finds time to work on it. Progress is slow, but at least it's moving in A direction now. Now, it's in money saving mode so I can have the whole car resprayed.
Rear rocker panel damage. Thanks to audiopro for the donor piece.
Before
After
Rust on the rear below the left tail light
BEFORE
After (as you can see here, the S2 bumper has been installed)
There was a ton of bondo on the driver's side fenders from a previous half-ass repair job and a dent in the door.
Before
After
He tried to pull the front portion of the rocker panel. We may need to use another piece of donor rocker...not sure yet.
Before
After
Now that it's back home, I'll work on installing some parts.
Euro coupe bumper. I'm thinking I will shave the sprayers. Any thoughts on that?
UrS6 three-spoke steering wheen. Anyone got the '95 90 column clam shelf for sale?
One-piece B3 headlights.
Brent
PostPosted: Tue Feb 15, 2011 12:37 pm
Any thoughts on the respray?
My friend's dad that I will use to paint the car suggests something like the Cadillac White Diamond Pearl. Says he's had good luck with it in the past.
Or should I just stick with the stock Audi Pearl White? I'm sure most people know what it looks like.
Brent
PostPosted: Tue Feb 15, 2011 12:48 pm
nice progress! I rock sans headlight washers. If i were going to paint my car i would NOT go with pearl at all. I would go with a nice silver/grey or a ibis white.
//Dave
3x '95 90 quattro - 83 URQ - 99 B5 A4 Avant - 82 coupe
PostPosted: Tue Feb 15, 2011 12:51 pm
I know how much you like your rare blue colors, why not go with a Kingfisher blue?
//Dave
PostPosted: Tue Feb 15, 2011 1:06 pm
I do like blue and I would love to change the color, but isn't it just so much more work and $$$ to do that as apposed to a simple respray? Was hoping to find a Lago coupe when I was looking.
Brent
PostPosted: Tue Feb 15, 2011 1:17 pm
Did you ever pick up that 200 with rs2 goodies?
//Dave
PostPosted: Tue Feb 15, 2011 1:33 pm
That color is hot.... if it would work on my S6 I would do it in a heart-beat, but it doesn't fit the car.
[email protected]
Present: 2008 Mustang GT Premium Coupe 5-speed (Koni shocks, Steeda Ultralite springs, Borla mufflers, x-pipe, K&N intake)
Past: 95 UrS6 - Lots of 034 goodies including a GT2871R, FMIC, turbo-back exhaust, 6-speed, intake, cylinder head, etc.
Past: 04 Tacoma 4x4 - 4-inch lift, armored bumpers & rock-sliders, snorkel, 33-inch tires, 9000lb winch, lights, etc.
PostPosted: Tue Feb 15, 2011 2:20 pm
I think it's still available, but I couldn't talk the wife into taking on a parts car, what with my Avant, Jeep and CQ and nowhere to store it except in the driveway. Sheez, women :slap:
Brent
PostPosted: Tue Feb 15, 2011 2:31 pm
it was a steal... i think you should.
//Dave
 Post subject: JBD's Project CQ - Kind of like polishing a turd.
PostPosted: Tue Feb 15, 2011 3:51 pm
I would keep the headlight jets, seems a shame if you get rid as you could have saved a little money and had the euro V6 bumper without them.
And it would be nice also to stick with original pearl white.
PostPosted: Mon Feb 21, 2011 11:01 pm
Got some time to work on the coupe tonight while the wife had friends over. Was able to get the one-piece euro headlights and euro coupe bumper fitted. Next up is to re-do the headlight relay job since 1) it was half-assed and 2) these headlights have a different style plug.
Will take some better pics in the daylight.
I need to know the color coding on the four-wire connector for the euro headlights. Anyone out there know what is what? The colors are:
* brown (ground I presume)
* yellow/black
* grey/black
* white/black
Thanks
Brent
PostPosted: Mon Feb 21, 2011 11:16 pm
Lets get freaky 8)
Nice, coming along!
Jimmy G
'89 90tq the "vomit comet"
'01 A6, the "ocho"
Original web page
  |  It is currently Sun Aug 09, 2020 12:45 am
