Post new topic Reply to topic  [ 17 posts ]
Audi Coupe Quattro 1985 real_customs build
 Post subject: Audi Coupe Quattro 1985 real_customs build
PostPosted: Sat Nov 21, 2020 10:16 am
Another project, very rare, factory, Quattro coupe. Condition as usual)
dismantle
A 4-cylinder motor was pushed in to deregister, then naturally there will be a 5-cylinder motor.
Inspection of the body showed rust and a lot of putty, then sent the body to sandblasting for cleaning
And there interesting details were revealed
After the sand, immediately the soil
Next - welding, holes in the bottom, new thresholds and arches
the battery was transferred to the trunk
new jacks with emphasis on the side member
Thresholds and arches were stained and oiled before installation
Then the suspension was removed and the bottom was immediately covered with epoxy primer and then with an anti-gravel coating
Audi S8 1998
Audi urQuattro 1982
 Post subject: Re: Audi Coupe Quattro 1985 real_customs build
PostPosted: Mon Nov 30, 2020 10:33 am
After the bottom I took up the suspension, everything was disassembled and sent for sandblasting and painting
All consumables are new, the body is on wheels
Then it was necessary to remove the layer of putties and paints that had accumulated over 30 years
After that, everything is immediately put into epoxy and we see such a picture
Further alignment
And priming again
The color will be original LY3D
https://www.instagram.com/real__customs/
Audi S8 1998
Audi urQuattro 1982
PostPosted: Wed Dec 02, 2020 8:23 pm
Looks good so far, thank you for sharing your work with us!
http://coupe.gofergusons.org
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Mon Dec 07, 2020 10:20 am
Painting, base as I already wrote LY3D, PPG D800 varnish, paint took 4 liters, varnish 6 liters
Audi S8 1998
Audi urQuattro 1982
PostPosted: Wed Dec 09, 2020 7:59 pm
I love LY3D...I've had five cars that color.
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Sat Dec 12, 2020 10:12 am
The assembly began with the laying of fuel and brake lines
The pump suspension with filter is used from b3, because there was no native as well as fasteners on the body
Everything is ready to put the motor.
The state looks so-so, I decided to disassemble it before installation, and for good reason
inside the oil turned into something incomprehensible
As a result, I completely disassembled
New liners ring gaskets
Collected and installed under the hood
Then I installed the rail and pedal assembly
The vacuum amplifier installed a two-membrane from A4, for this I made an adapter for the stem and a flange for fasteners
Then I picked up the back part a little
black vinyl under the number
Audi S8 1998
Audi urQuattro 1982
PostPosted: Thu Dec 17, 2020 4:43 pm
Looking good, that was some nasty sludge from the 7A!
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Sun Dec 20, 2020 1:30 pm
the motor was lying for a long time, perhaps the oil has oxidized during this time and turned into this
Audi S8 1998
Audi urQuattro 1982
PostPosted: Sun Dec 20, 2020 3:32 pm
Highly likely that is the case.
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Tue Dec 22, 2020 11:28 am
Today we will talk about wiring.
In 90% of cases in old cars, it requires repair, after the intervention of music installers, alarms, under the hood, the wires crack from temperature and the ends break off.
Now there will be photos not for the faint of heart)
We managed to get the harness on the buttons in good condition
This heap of wires, extra, from alarms, music and other incomprehensible things
First of all, power wires are laid on the battery in the trunk, starter and generator
grounding
Made a new harness for sensors for tidy, and Headlights, gearbox
Further wiring to the engine. since it is from an audi 90 b3, then I had to unwind the harness, remove or add wires and rewind
ECU installed under the feet of the passenger
After I collected the engine compartment
Checking all systems
Audi S8 1998
Audi urQuattro 1982
PostPosted: Wed Dec 23, 2020 6:11 pm
I take it you re-wrapped the harnesses after you stripped them down with the cloth/friction tape? Looks nice and factory.
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Thu Dec 24, 2020 8:55 am
yes, I removed the factory braid, I had to take out extra wires or add somewhere, and then I rewound everything
Audi S8 1998
Audi urQuattro 1982
PostPosted: Sun Jan 10, 2021 9:31 am
The longest part of the work is assembly, search or manufacture of fasteners, spare parts, etc.
Drive, there was a replacement of all CV joints and cardan repair
Everything went smoothly at the back, but the front hubs from a4b5 and the shruz ordered from a4b5 did not climb there for some reason, just like the front one from b3 5cyl, as a result, it was possible to pick up by typing, the front one came from b3 4cyl without abs.
Along the way, the oil in the gearbox and gearbox was changed to GL-5 synthetics
Set the brakes by re-drilling the stock discs for 5 bolts
the caliper had to be sharpened in front, so that it would become exactly on the disk, perhaps because of a non-native hub
New hoses and boots for steering rods
The exhaust for the 80 quattro is only from the b3 body, so I had to modify
at the end I welded stainless steel nozzles, made a swing like a drain
Painting of installed elements
The power steering from the 7a motor has a circuit for the brakes, so I took out a plunger and made a new hose to the rail
The filter box has become standard, almost to the factory fasteners
Stove, all elements are new, on top and inside, new seals
In the process, some alterations are solved, such as a clutch rod and other little things
The engine starts, the car drives and slows down, but there are still a lot of problems that we are dealing with.
Audi S8 1998
Audi urQuattro 1982
PostPosted: Thu Feb 04, 2021 11:01 am
The assembly continues:
Glazing
New door hinges
Before installing the attachments, everything is covered with conservation grease.
Sour trapezium is a standard disease of long-lasting cars, disassemble and lubricate
Correct wheels
Painting burnt-out plastic
On-site nameplates
The rear shelf in the factory is made of cardboard, which of course suffered from music installers over 30 years and simply decomposed, so a new shelf was made from fiberglass and sheathed in the same material as the racks with the ceiling
Who did not know, the hatch of the coupe can be taken out and put on a special shelf in the trunk
The timing cover had to be made of 10 valve ones, because the factory was broken
Installing little things
The car is almost assembled, it remains to hang the bumper and polish
Audi S8 1998
Audi urQuattro 1982
PostPosted: Fri Feb 05, 2021 6:23 pm
Looks really nice!
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Thu Feb 11, 2021 1:27 pm
Before collecting all the parts that were lying.
Side members spilled with conservation grease
It's + over 700 hours of work and this is what came out:
Audi S8 1998
Audi urQuattro 1982
PostPosted: Tue Mar 09, 2021 7:14 pm
This is some seriously impressive work. Congrats on the result, all the hard work and time really shows. Now go put it in a museum or a showroom!
Barry
2001 Audi S4
2005 Audi A4 Avant 1.8T Quattro
1988 BMW 530i (E34)
1999 Audi A4 1.8T Quattro - sold
2008 Mazdaspeed3 - sold
1990 Audi Coupe Quattro - sold
1990 Audi 90q 20vT - retired
1987 Honda Prelude Si - sold
Ottawa, Ontario
  |  It is currently Thu Apr 22, 2021 3:14 am
