Post new topic Reply to topic  [ 404 posts ] Go to page Previous  1 ... 13, 14, 15, 16, 17  Next
Rabbit Farmer's 1.8T 4-door money pit
 Post subject: Re: Rabbit Farmer's 1.8T 4-door money pit
PostPosted: Mon Apr 08, 2019 9:01 pm
The Historic Mt. Philo Hillclimb is in May this year… this means that I have a lot to do to the car… unexpectedly… and help organize the event. Yay!
As with any project, you start out thinking that you just need to replace a light bulb, but then you notice you have to fix the shelf, fix the drawer, get a can of WD-40, and then replace your car engine. It is all related. Search the magical Youtube for “Hal replacing light bulb” get caught-up with the joke.
My light bulb was supposed to be the subframe and hanging clutch… you know, minor stuff like that.
-- The SHELF --
When I had the engine out, I noticed the engine mount (passenger side) was about as loose as throwing a hot dog down the hallway. The good news was that I had an extra 034EFI Track Density motor mount (same as what was already in there) as I replace the transmission mount (also 034EFI Track Density) in 2017 and they were sold as a pair.
I decided to check the transmission mount (driver’s side) and that had a lot of movement. What the @#$%? I just replaced it in 2017.
I decided there had to be a better option out there that did not require an expensive replacement of the entire mount when it failed prematurely. I purchased the VF Engineering transmission mount from UroTuning.com. Very quick turn-around with order and replied exceptionally fast to my technical questions via email. Major thumbs up!
Back to the light bulb. I installed the Nothing Leaves Stock (NLS) 02M 6-speed shim kit (very straight forward) and the new Luk brand more-metal-than-plastic throw out bearing/slave cylinder that I got from UroTuning.com. Turns out that I already had this in my car… but, while in there, out with the old and in with the new (or regret it later).
Installed… nothing too exciting, but I will remember it in the future when I have the transmission out of the car. It will happen… I have heard of it happening before… once or twice.
Naturally, since the transmission is off, we might as well check out the Spec 2+ (I always thought it was 3+, but I’m pretty sure it is 2+) clutch, pressure plate, and flywheel that was installed in 2010. Wow!
It looked awesome! So, just need to reinstall it.
-- The DRAWER --
But, since I noticed that the non-stretch bolts were looking a little rounded (they are hex heads), I decided to hunt down six new bolts.
They are M8 (8mm), 1.25 pitch, 16mm long (bottom of head to end of bolt), grade 12.9, DIN 912 (socket head screws), and black-oxide steel.
Of course, I know what all this means now as I head to search to the ends of the internet to find them. (DIN was new to me and I wasn’t sure how grade 12.9 compared to the 8.8 that I was used to for seat belt bolts)
I ended up getting them from the Nutty Company in CT (www.nutty.com) as they had a good price on 30 bolts and the shipping was reasonable. It was cheaper than purchasing locally from Fastenal.
-- The WD-40 --
I replaced both fender liners in the front. I have done this in the past, but when there was an issue with securing them properly, the tires wore them out due to contact. Opps.
I also noticed that the plug that goes to the radiator fans was broken (been ignoring it for a while), so I ordered a new one (guaranteed for life!) from FCP Euro (www.fcpeuro.com). Quick, efficient, and pleasant ordering experience. Recommended!
There is a great article on GRM here: https://grassrootsmotorsports.com/artic ... ore-world/
-- The ENGINE --
Thankfully, when I had the subframe off, I checked out the power steering rack. The hard lines were very rusty. I checked with the local VW parts place and they said the lines are not available individually (nor are the little metal clips that hold them one). New rack was over $800. Nope… manual steering would happen before I spent $800 here.
Refurbished racks weren’t too expensive, but were a bit more than I wanted to spend.
Plus, I wanted to solve the problem, not just delay it for… heck, I guess for 18 years isn’t that bad.
Internet searching brought me to EAA Engineering (www.eaaengineering.com)... Again. Yep, I was there before looking at these lines. Now, it seemed that I needed them.
This kit would take care of the hard lines that needed to be replaced.
This took care of all the other lines. I will be nice to not have to worry about them in the future.
Plus, I noticed they have a “1.8T engine swap with the MK2 power steering rack” kit, which will work quite well with the Scirocco as it has the MK2 rack. Well, that is my understanding anyway. More to come a bit down the road.
Anyway, engine and sub-frame are sitting on the floor pending the arrival of the hoses.
I fixed the beat to hell heat shield that is over the power steering rack. $27 for a new shield (that will get beat to hell) or four rivets (hammered flat) and some sheet metal. Done.
Rattle rattle rattle goes the heat shield under the car. Enter some do-hickies to rectify the problem.
Seat is kind of installed. I mounted the new Sparco side mounts. The new mounts are slightly different from my older Sparco mounts… I swapped them because the new brackets allowed for the correct width to mount the seat.
Everything on the mounts and seat are loose for the test fit. It will all come out as I change the mounting points for the 6-point harness submarine belt.
The new seat is a bit lower (I have it at the highest setting on the side mounts). I need to put the seats side by side to see why they are so different. It will work, but a change to the mount on the car (the welded in tubing that forms the base) might be in order.
Also, with the halo style seat, I now wish I got a removable steering wheel to help with entry/exit.
Of course, with all the times that I had to access my tool boxes and head out to the shed or trailer to get parts, I finally ordered matching locks for my toolbox (instead of having two different keys) and fixed that @#$%#ing blinking exterior light. I got a quick education from www.ledsupply.com (great site, good information, quick turn-around) on what was wrong and how to identify the exact driver I needed to fix the light.
That is all for exciting news.
Next update should have car 100% done with the exception of needed to add back the mounting points on the subframe for the skid plate (threaded inserts x 4) and ordering new tires (that won’t be cheap!)
www.VermontRacing.com
PostPosted: Sun Dec 08, 2019 5:53 pm
How about a whole season in one post!
I am happy to report that we seemed to have a pretty smooth season this year… nothing broke. (or I am just very forgetful)
---- To catch up with the 1980 MK1 Scirocco ----
Thanks to a lot of expertise and advice from the members of the New England Hillclimb Association (NEHA), especially John Reed for the information on the different properties of some of the typical roll cage tubing, we settled on using the Rocal R-8.
Joey Kale (who is doing the cage) said this has been some pretty tough stuff to bend. Very impressive.
The Scirocco at Joey’s shop in June 2019
Some updates throughout the summer… main hoop installed.
The new halo seat (that I used the entire 2019 season in the Golf) is made to fit and the old Sparco seat (my old Golf IV seat) is being used for the passenger side after some modification to the center tunnel to make it fit.
I plan to buy another halo seat so that both the MK1 Scirocco and MK4 Golf have the same seat.
Cutting out some of the light sheet metal to mount the main hoop to the non-stock framework that was built into the unibody of the Scirocco to stiffen the chassis and create better platform to build the original cage.
A lot of the tubing is cut and ready to install in October 2019.
The time to get a spare part is when you don’t need it and there is a deal. My brother (Andy… still plays with cars) ordered three new M1 Scirocco windshields… of which I purchased one of them.
Pretty cool custom “Rabbit Farmer” badge that I plan to install on the Scirocco. It looks identical to the stock MK1 Rabbit badges. Very good quality. I highly recommend.
Vendor:
Pop Zombie Laserkraft
www.facebook.com/PZLaserkraft
[email protected]
---- Updates to the MK4 Golf ----
The earlier posts showed the power steering lines that I planned to install.
Here is what arrived for the complete kit for the Golf.
Two braided steel lines for the rack
One braided steel/rubber line from the rack the power steering pump
One rubber line from the rack to the reservoir
The lines on the actual power steer rack seemed to fit good. Great quality.
The lines almost installed on the rack. I did grind the rust and repaint the clips that hold the lines to the rack. These are parts that do not seem to be available on the aftermarket.
Kinda like the power steering lines… you need to purchase the entire complete rack to replace the lines.
For some reason, the line that went from the rack to the reservoir seemed to be too short. I spoke with the company and they tell me that the line was the correct size, but I didn’t see how it worked.
With the limited time before the first event of the season (first time since the 1970s that the Mt. Philo hillclimb is in the spring) I ended up not using that line. I also returned the line that went from the rack to the pump as it wasn’t needed as what I had was in good condition.
For the original line that went from the rack to the reservoir, I sanded the metal surfaces to remove the rust, painted with high-temp black paint, and put a Cool It / Thermo Tec heat shield around the line from the rack up the firewall.
Since the last time that I purchased tires was for the 2017 Mt. Washington Hillclimb (I normally purchased a set every 1.5 seasons… they were getting VERY thin mid-2018 season), I purchased another set of Toyo R888R tires 235-40-17.
I noticed that there was a still leak under the engine (noticed it last season also thanks to the skid plate catching everything). In 2018, it seemed to be some loose bolts on the metal part of the oil pan (this is the hybrid aluminum/metal pan). I torqued them.
At the start of the 2019 season, I removed the metal portion, cleaned it along with the bolts and engine block, and reinstalled everything using Permatex Ultra Black.
It still seems to be leaking a bit come the end of the 2019 season, so that will be another project over the 2019-2020 winter. I might just return to the all-aluminum one-piece pan. I have a robust skid plate to protect the pan. We will see.
I noticed that one of the holes in the transmission mounting bracket was a little stripped. It must have been a little stripped by the constant removal/reinstall over the years, but it was never noticed until I install the VF Engineering mount that uses shorter bolts. I guess the threads that actually worked were at the bottom of the hole.
Since I did not have a spare bracket that mounts to the transmission (well, at least not for the 6-speed), Joey Kale was going to install a HeliCoil to rectify the issue.
Turns out the HeliCoil thread was exactly the same as a bolt he had, so we just used the larger bolt.
Time for some new front brake rotors. In the second image you can see the ridge on the edge of the old rotor.
And the final thing needed for the 2019 season was the reinstall of the skid plate threaded mounting points on the subframe… I replaced the subframe earlier as it was 3/8” out of true. That is Joey under the car doing the welding. Thanks to my friend Chris Achilles for coming over to install a 50amp outlet in the garage so that we could plug in the welder. Good thing I had a 100amp panel installed in the garage shortly after moving it.
And… the first hillclimb of the year! Mt Philo in the spring. (same for 2020)
The season progressed with zero (recallable) issues. We heard that the Mt. Ascutney hillclimb in the fall was going to run the full 3.6 mile hill course.
My favorite hill of the NEHA series, but over the past 10 years +/- it has gotten very bumpy between checkpoint 7 and the normal finish line at the 2.8 mile mark.
The fall 2019 event will bring us to the very top of the course at 3.6 miles.
My suspension was built back when the hill was a lot smoother. I believe that the bumps, a little airborne with the hard springs with some wheel spin, followed by the shock to the drivetrain upon the wheel making contact again (lots of grip) has been the cause to transmission and axle failures over the years.
Digging up an old photo from 2006 that shows the Shine Racing suspension prior to install.
Front: 8” 500# spring
Rear: 8” 350# spring
I borrowed some springs from Chris Putzier (he does a lot of rallying since… well, forever ago) to try.
Rear: 10” 140# spring replaced the 8” 350#
Originally, before Chris offered the loan of the softer springs, I looked at some alternative tender spring options for the springs sitting in my tool box.
The current setup was the 8” 500# spring with a helper spring (0# spring rate).
I had a 3” 200# tender spring that I thought of trying (remove the helper spring), but it seemed that it was too long.
Front: 12” 130# spring replaced the 8” 500#
Fronts installed.
Because I now had softer springs, there would be more body roll… so, I reinstalled the Shine Racing anti-sway bar.
I originally removed it during a HPDE day at New Hampshire Motor Speedway (NHMS) where it was raining and the combination of stiff springs and the big anti-sway bar created some undesirable oversteer.
When installing the tire, I noticed that the wire that goes to the wheel speed sensor (used for ABS) was damaged as it was making contact with the rim. Something that I will replace during the 2019-2020 winter. For now, addressed the wires with issues and wrapped it in electrical tape.
Both sides of the front now have wheel spacers.
During the fall Ascutney event. Nothing broke.
Even though I thought the new softer suspension would help suck up the harsh bumps (and protect my axles from breaking), I did take it easy as I only had one replacement driver’s side axle. My times show slower times to the traditional finish at the 2.8 mile mark.
Best time 2:56 (2016)
Fall 2019 3:02.17 (traditional) and 3:49.27 (full hill)
I got into it on Sunday after a few easy runs, but put it in the trailer early as I had to get home to my lovely wife.
While the softer springs did help with the bumps, they were actually too soft.
Winter 2019-2020 will provide a new suspension that has a better spring rate that will work for all the hills (I will keep the stiffer springs for the track) and adjustable shocks/struts.
PostPosted: Wed Feb 05, 2020 9:57 pm
The research continues on the upgrade for my suspension.
Something with good suspension travel, adjustable struts/stocks (two way), beefier construction, etc.
I looked at some brands and after contacting the company found they were outside of my racing budget. (i.e. Ohlin and Reigers)
Great quality, but I need to eat also!
My research for "racing coilovers" kept bringing up brands that use "racing" in their names (i.e. BC Racing) that might not have meet my needs.
KW Competition did come up in my research, but I am unsure (like I don't know) about the quality of the product. Anyone with insight?
So, three options that did come up were:
D2
https://d2racingsport.eu/" onclick="window.open(this.href);return false;
Rally Asphalt Coilover Kit - #D-VO-23-RA - Volkswagen JETTA 4-MK4 (2WD)
K Sport didn't seem to have anything that fit my car.
https://ksportusa.com" onclick="window.open(this.href);return false;
And finally...
Gaz Gold Coilovers
VW Golf Mk4 2WD Gaz Gold Coilover Suspension Kit
https://gazcoilovers.com/vw-golf-mk4-2wd-gaz-gold-coilover-suspension-kit-96-p.asp
I sent an email to Gaz to start that conversation.
What I like, so far, about Gaz, is that they seem to be speaking the language of "racing" while they still seem to be in my budget (assuming I'm converting that crazy looking L to the $ properly).
They also have the cheaper GHA coilovers (and this is what peaked my interest), but they stated:
"The GHA kit is not recommended for cars running semi slick track day tyres or full racing slicks as they are not designed to accept the high side loadings the extra grip of these tyres exert on the main seals and bearings within the dampers. If you run these tyres, you will be better served by our Gaz GOLD coilover range."
Great... so, the Gold is the better option for racing. They recognize side loading and the strength of the suspension.
What really caught my attention with the Gaz Gold are all the options available to setup the coilovers right down to their assistant with picking the correct spring rates for the type of racing you do. Sweet!
Going back at little bit in time, I was having a conversation with MurrayMotorsport.com (great company! highly recommend them) about Gaz coilovers, but the Gaz brand doesn't seem to be on their site anymore. I do see in their 2019 catalog, that they have Proflex, Ohlins, Gaz, Koni, Bilstein, etc. available. Unsure which is current.
Research continues.
Lots of upgrades to various parts throughout the car. Going to be a busy winter/spring in preparation for the first hillclimb of the year in May.
Lots of snow forecasted for the next few days. Good excuse to spend some time in the garage working on the car and doing research for parts.
Still having an issue finding good lightweight rims ( 17 x 8 ) that aren't crazy expensive.
Steve
PostPosted: Sat Feb 22, 2020 10:25 pm
A few updates, but no real progress on the Golf.
Planned for this weekend is a compression and leak down test. I haven't used the lead down tester yet, but I get the general idea. I might be a YouTube-certified Master Leak Down Tester by tomorrow.
The few things that I have been researching are spare rims (perhaps a little lighter) and a better coilover suspension.
Rim research continues, but I haven't narrowed it down yet.
I know it will be 17x8, 5x100, ET35, around 22-23 pounds, and around $150. And a dark color... I like black and gun metal. There are a number of options on Tire Rack that caught my attention.
The current rims that I purchased back in 2003 are quite heavy coming in at 26.8 pounds. The company that made the rims hasn't been around for a very long time. Edge Racing. I purchased them because they were $99 each.
Part of getting ready for the 2020 season is to make sure that I have extra parts and purchased some basic maintenance parts.
HANS replacement tether (dated 2020) from Summit Racing.
Simpson model number TK 1231.4
Extra 2.5 and 3.0 silicone couplers and T-bolt clamps from Mishimoto (New Castle, DE)
I often thought that if I dropped just one lugnut that I would not be able to drive. So... I ordered 20 new nuts from 034 Motorsports.
From FCP Euro, new bolts for the trailing arm bushings, new wheel bearings, speed sensor wire (front left was damaged), and rear spring rubber perch are all going in now. The ball joints are spares.
For tools that love to fly across the garage when in use, the strut spreader is one of those. The current tool I have is just the bit that I have to insert into a 9mm (or so) socket to use it. Enter the Metal Nerd strut spreading bit with a larger end for easier handling. I might glue it into a socket since everything at Sears is (was?) on sale. I picked up two of these tools due to the likelihood of them taking flight. Ordered from UroTuning.
Now the fun stuff.... Rear trailing arm bushings with spherical bearings from 034 Motorsports. (that's what I needed the new bolts for)
One problem that I have experienced over the years is that the brake pedal was a solid rock when it was used during or shortly after full boost. Bit me at Mt Washington in 2017.
Enter an electric vacuum pump from Leed.
This is the Bandit pump in black. It is approx 8" tall. I thought it was a bit smaller when ordering it as I had plans to install it under the hood, but since it is quite large, it will end up in the back of the car.
Ordered from Summit Racing.
I settled on Gaz Coilovers "VW Golf MK4 2WD Gas Gold"
https://gazcoilovers.com/vw-golf-mk4-2w ... t-96-p.asp
9" springs. Front 400# and rear 350# with everything valved accordingly.
Able to adjust the rebound and compression damping.
I had to measure the current spherical bearing in the Cusco (part number 566-410-A for "Mitsubishi Lancer Evo X (08-13)"... reminder for myself when I am trying to recall what I have) pillow top to ensure the Gaz shaft was machined to the correct spec.
PostPosted: Sun Mar 08, 2020 6:58 pm
A few MK4 and MK1 updates.
The 2020 hillclimb season is fast approaching and I just realized that are a number of general maintenance things that I need to do to my car plus some bigger stuff… like a new suspension and rims.
Rims should be minor, but a new set of tires are in the mix and it is impacting a few things.
So… the car is off the ground with the front and rear suspension completely removed.
In the front, I am trying a new set of tires. Yokohama Advan 230/640-17
They are “take offs” from Vermont SportsCar… I’m sure someone much faster had them before. But, the price was right; I grabbed two sets.
They are the same width when mounted on the same rim as my Toyo R888R tires, but the shoulder is more square and they are taller. Toyo height 24-1/2 and Yokohama 25-5/8.
This means they are severely rubbing against the current coilovers even with the 3mm spacer. The rims are 17x8 ET35. I plan to purchase a new set of rims after I get the new suspension in. Either I will have an offset that allows the Yokohama tires to work or I will get the same offset (35) and just use spacers.
I removed the rear beam to replace the 2001 stock bushings… yep, I never changed them. And they always squeaked.
The fronts and rear headed down to the Cheese Factory in Colchester, VT for some bearing and bushing pulling and pushing. Chris did a great job as usual!
While I had the rear beam off, we also did the original 2001 wheel bearings in the rear. Brake pads and rotors looked good.
I ordered some misc. parts to address some of the old bits and pieces… plastic retainers that hold the solid brake lines to the beam, wheel speed sensor (and new plugs for both sides as those where checking out soon), e-brake clips, new bolts and nuts for the bushing.
Enter the solid 034 Motorsport solution. Not all the parts are included in the picture.
New front wheel bearings. I have to bring one back as it needs a new hub (Chris couldn’t source one locally). I also ordered a new set of brake pads for this season.
Next on the Golf is the oil pan (ordered aluminum) and power steering leak.
Interesting thing about the oil pan. I am changing from the hybrid pan (aluminum body with bolted on steel bottom). The bolts were all loose on the pan. I tried to address the leaking by removing, cleaning, and sealing everything, but she is leaking again.
The aluminum pan should be fine as I have a really good skid plate.
One thing I did recall when getting the hybrid oil pan is that ECS Tuning (where I purchased it) included the oil pickup tube as it was different from the aluminum pan.
So, going back to the aluminum pan, I needed to get the older pickup.
I was stuck on model year split for the new vs. the old pan, but it wasn’t just the model year, it was actually the year they went from aluminum to the hybrid. I recall our 2004 Jetta IV 1.8t came with the hybrid pan.
VW part 06A115251 | 2003 and prior (because it has the aluminum pan)
VW part 06A115251G | 2004 forward (because it had the hybrid pan)
I’m going to try to remember to get some side by side pictures and measurements of the two to see the real different.
Well… I guess that oil pick tube story wasn’t all that exciting… but, I will need this information in 5 years when I am trying to remember what I did to the car.
Blah blah blah…
Let’s check out Joey’s progress on the Scirocco.
Joey took a lot of great pictures that detailed the progress and the details; for now, I will just present some of the images I took this weekend. I will post up his pictures later.
Once the seats are in, we will determine which steering column to purchase. I am unsure of the size, brand, design, but it is something like this:
Also part of the work that Joey is doing is trying to address the camber plates. I want something similar to what I have on the Golf. Something that I can purchase off the shelf in the future (should I need to replace them) instead of a fabricated piece.
I am also currently researching tubular front control arms and purchase different knuckles… we will see.
PostPosted: Sun Mar 22, 2020 7:35 pm
Not a whole lot to report…
Both sides… new plastic clips for the hard brake lines on the beam plus the metal hangers for the e-brake cable.
Rear beam went in very easy on the left side of the car.
There weren’t any instructions from 034 (other than “coming soon”) so I had to figure it out myself. It isn’t that difficult, I just would have liked to have the instructions to make sure I did everything correctly. A little “tool” of some sort was included with the kit… not idea how we were supposed to use it.
I greased all the parts before assembly, figured out that the longer of the two bearing spacers went on the outside.
The right side of the car seemed a bit problematic.
I removed the bracket from the car as it seemed a little bent. “A little” didn’t do it justice. Enter hammer and anvil to make it look pretty again, installed the rear bear, torqued bracket bolts to 55 lb/# and the bearing bolts on both sides to 59 lb/#.
Installed both rear brake lines… and that is how everything suspension related will sit until the new coilovers arrive from England.
Time to check out the engine to see what shape it is in for this season. Naturally, I should have done this back in October, but life was busy back then.
I picked up a leak down test kit from Summit Racing a few years ago. It is a lot easier to use than I expected.
I understood the general concept… pressurize a cylinder and see how much air gets by the valves, rings, etc.
I pressurized the tool, turned the yellow knob until the right gauge was in the middle of “Set”, connected the hose to the #1 cylinder, and connected the other end to the tool.
And… HIIIIIIIIIIISSSSSSSSSSSSSSSSSSSSSSSSSSSSSS with 100% leak down. I passed! I got 100%.
Nope… that would be very, very bad to have 100%
Oops, forgot about the whole top dead center thing.
I turned the crank to get TDC for #1 and #4 and tested those and rotated it 180-degrees for #2 and #3.
In addition, I did the standard compression test afterwards.
Here are the results (both test in each picture… pretty snazzy)
My helper (Julie) holding the engine in position so that the piston doesn’t go down when pressurized.
Suspension-wise, the car is done.
Left to do:
1. Power steering hose on the rack is leaking (hopefully, just need to tighten it)
2. New oil pan
3. Figure out what offset works with the new taller tires and the new suspension (when it arrives) and order another set of lighter rims
4. Install the new suspension (hopefully, in two weeks!)
5. Install seat… currently it is sitting in the MK1 Scirocco as I will be running the seat in both cars (well, each car will have its own seat, but they will be the same brand/model)
PostPosted: Wed Apr 15, 2020 10:17 am
A few Volvo and Volkswagen updates…
In this exciting episode of “Finding more time to work on my cars since I don’t need to commute to work” Garage:
2015.5 Volvo S60 T6 R-Design
Rear Brakes
Misadventures of Trying to Replace the Power Steering Control Module (Snipe Hunt)
Clean and Ready for Summer
2001 Volkswagen MK4
Wheel Speed Sensor Replacement and Removal of Pad Wear Sensor
Coil Relocation
New Coilover Suspension is Here!
I thought there would be Subaru WRX updates also (other than putting on the summer tires!), but everything looked good including the brake pads and rotors. It is getting close to the time to sell the WRX and purchase something new for my daily.
Though… I do love having an older car like this (2009) to navigate the winter roads and bring it to car events from time to time (Autocross, track, etc.). Don’t race a car payment!
Let’s start with the Volvo.
This is my first time doing anything to this car other than the basics; swapping summer and winter tires, changing engine intake filter, and changing (what a pain!) cabin air filter.
Since the car isn’t needed as a daily commuter right now with all this stay-at-home Zombie stuff, I was comfortable digging into this car to replace the Power Steering Computer Module (or so I thought) and the rear brake rotors/pads. I did not want to take the car apart when it was needed for the daily commute as I was worried I would need to order parts that I hadn’t thought of when planning the projects, which would have put us down on car. In the summer… no big deal as I can drive my truck, but I try not to drive my all season tire truck in the winter (because of the salt).
Rear brakes…
Very easy as the design of the rear brakes is very similar to what I normally see on the fronts of cars. Remove caliper and remove bracket. Since the Golf has been on jackstands for a while, I had to buy another set of four jackstands to do other projects.
Basic hand tools (13mm and 15mm sockets) plus T30 (long) to remove the Electronic Parking Brake (EPB) motor, T40 to turn in (reset) the EPB, and T50 to remove the screw the holds the rotor to the hub.
Good thing I addressed the pads; very thin. Image shows the old pads installed with a new pad next to it. Wow!
All installed. The pads came with new 13mm caliper bolts and sliders and the rotors had new 15mm bracket bolts, but I do wish I replaced the T30 head EPB bolts. Normally, you reset the EPB via putting the car in service mode, but I don’t have a scanner to do it electronically.
Next, diving into the front end to address an intermittent power steering issue.
Sometimes, when we start the car we can feel in the steering wheel (without even going anywhere) that the power steering is not working. Turn off the car and restart it… might take a few tries… and everything is back to normal.
This issue has never occurred while driving. If it does occur after we first start the car and we don’t restart the car to correct the issue and just drive it, the issue does not go away.
It was suggested to me to replace the Power Steering Control Module (Volvo part number 31360217) as it is an inexpensive part ($150 +/-). Looks like a typical relay, but I could not find any information on where it goes on the car.
Going to some of the Volvo forums or Facebook, it was suggested that the PSCM is located on the pump that is located behind the front right bumper corner.
The power steering on this car is an electric hydraulic pump.
I did over complicate accessing the pump. It is as easy as removing the front right tire, removing the fender liner, removing the two pins that makes it very easy to remove the entire headlight housing (wish all cars were like this), unplug the headlight, disconnect the power steering reservoir to make it easier to move the pump, and then remove the four nuts from the front (accessible because the headlight was removed) and back (removed fender liner) of the pump. Bam!
The power steering pump. The pump itself looks easy to change, but my goal was to replace an inexpensive part to see if that fixed the issue.
Talking through a friend to his friend who is a Volvo tech, I am told that the PSCM is part of the pump… so, I have no idea what the relay looking thing belongs.
So… I put it all back together. If I need to replace the pump, at least I now know how to access and replace it. A waste of my time, but it was a learning experience.
Yuck!
Un-yucked!
All back together with the summer rims and tires and a car wash.
Switching gears to the 2001 Volkswagen Golf MK4 that I race.
I ordered a replacement wheel speed sensor wire for the front left wheel.
I ordered 1J0927903E (excludes the pad wear sensor) accidently instead of 1J0927903R (includes the pad wear sensor) from www.FCPEuro.com (great place… I highly recommend them!).
The front left corner is supposed to have the pad wear sensor, but I have had it disconnected for years and had it ziptied to the strut.
So, it seemed like a good time to just remove the pad wear sensor from my car.
This shows the new (no pad wear sensor with only one plug) vs. the old pad sensor version with two plugs.
Of course, it can’t be that straight forward. The plugs are different.
The wire gauge is the same, but the terminals are different, so I will have to replace the terminals (able to reuse the Weather Pack seals); ordered terminals from www.ecstuning.com along with some other parts (coming in soon).
Reuse Weather Pack seals and boot; just need terminals and a proper crimper.
Next… trying to address this piece of crap that I made a few years ago to hold the coils.
This is what I removed… the stock battery tray and the bracket I made.
The issue with this design is that it is hard to unplug the coils (if trying to address an issue) and I have to remove this entire contraption to access the ground wires on the car. Bad design all around when trying to access things to try to address issues. This I discovered one year when I had an issue with the fuel pump… what a pain.
Enter the replacement. Something that I am planning to mount in the engine bay to the fender-side wall.
ICT Billet Remote Mount Ignition Coil Relocation Brackets (part number 551588) from www.SummitRacing.com.
There are two of them in the package for $60.
Coils mocked up.
I have a few choices here how to mount them.
Bracket-coil-coil-coil-coil-Bracket
If I mount them all between the two brackets, the coils need to alternate as the #4 coil cannot be oriented so that the plug on the bottom is on the outside as it will interfere with the bracket.
I would also need to grind down the relief for the heat sink to mount it this way.
The actually instructions show the final coil after the bracket end.
Bracket-coil-coil-coil-Bracket-coil
I will figure out what works best for me. Key part is that the coils and ground wires will be easier to access and service AND will look soooo much better.
Now the good stuff.
The VW Golf Mk4 2WD Gaz Gold Coilover Suspension Kit arrived!
I did get a spammy looking text message that stated:
DHL Express Shipment (tracking number): Your shipment is ready! To complete delivery please pay required US import duties/taxes here: https://del/dhs.com/US/(with-a-unique-link)
Riiiiiiiight….
I figured it was spam, but I did check the tracking number supplied in the text to the DHL website and was able to verify that it was my shipment and it was pending payment for duties/taxes. Followed the link in the text message and got my package (which was sitting in the US) moving forward.
My conversation with Gaz Coilovers was about how rough our roads are and I needed something to suck up the bumps. They suggested their gravel setup with 9” springs and 400lb front and 350lb rear.
Looking at what I actually received, it looks like I have 7” front and 8” rear. Springs are cheap and easy to swap out.
Old vs. New Fronts
Rears… One question about the rears is how do I make them operational; currently they are complete compress and do not come out on their own. I read online that if the shocks are sitting on their side or upside down, the gases end up at the wrong side of the piston. So, the two choices offered were to install them and they would start working over time (not going to do this) or pull them out and push them in until they start working. Also, recommended letting them site upright.
Still doesn’t seem to be working… Hmmmmm.
Old vs. New Rears
The new setup does need the upper stock mount.
The old lower mounting point for the spring was pretty beat up. The old version did pivot while the new one does not; hopefully, this all works out when the rear beam is in its operating limits (right now it is dropped low as nothing is connected).
The new lower mounting point fits nicely into the perch and has a huge buttocks bolt holding it all together vs. the PITA snap ring setup.
PostPosted: Fri Apr 17, 2020 6:56 pm
It took a surprising amount of time today to get things accomplished on the Golf today.
Spent a lot of time cleaning parts and attending to the small details. The day went by waaaaay too quickly.
I should have ordered one of these years ago to protect the pinch weld when jacking up the car.
Powerflex Black Series “Universal Jack Pad Adapter” that has 14mm wide x 15mm deep and 10mm wide x 15mm deep slots in it.
I don’t need it for the Golf as the pinch weld is flattened, but will be very useful for the Subaru WRX and Volvo S60 and whatever future car we get.
Purchased at www.ECStuning.com (ES#4006979)
Today’s goal was to install the front coilovers. The rears are on hold for some hardware that should arrive next week.
The Golf currently has the nut pictured on the left (Cusco kit); this is what goes though the 18mm ID spherical bearing on the pillow ball mounts.
On the right is what came with the Gaz kit; one piece goes on either side of the bearing.
I don’t like the two piece design from an installation point of view… is one design better than the other in terms of properly supporting the suspension on the bearing? Don’t know.
Both versions sitting on top of the strut. The old threaded nut version requires only one nut to handle both the attachment to the strut and working with the bearing. The Gaz version has the nut for the strut and the two pieces for either side of the bearing.
I did notice that it seemed the Gaz version doesn’t allow as much of an angle change from horizontal as compared to the Cusco version.
Gaz version:
Cusco version:
Probably doesn’t matter if both are within the operational range.
I noticed that the pads were wearing uneven in the front right. Inspection of the 2001 calipers showed that it was time to redothe seals, slides, etc.
Well, these remanufactured “Power Stop” calipers purchased from www.ECStuning.com (part number ES#3148871) were the right price, came with the bracket, and both were powder-coated red. I would have preferred black, but that is what they had. I really like that they were powder-coated so they don’t turn into a rusty looking mess… after nearly 20 years.
Big brakes aren’t needed for hillclimbing; the pads are still high temp (Hawk Blue 9012 Compound for the track) with good bite. For the rear pads, I use Hawk HP Plus as they heat up quicker; they did not need to be replaced yet.
Near caliper, new pads, new ball joint, new wheel bearing, new hub, and new suspension.
Sweet! Still need to torque everything. Of course, I will have to remove the pillow ball mounts next week as they go back to Joey’s to fabricate the Scirocco to use the same mounts.
I couldn’t work on the rear shocks (waiting for parts), but I did install new e-brake hangers (1J0609745G - left and 1J0609746F - right), brake line clips (191611715), and two pin connector for the ABS/wheel speed sensor (6N0927997A).
Long day without a lot accomplished. I hope to finish the front suspension 100% this weekend along with addressing the leaking power steering line on the rack and replace the oil pan.
When parts arrive, install the rear suspension during the week.
I do need to order new pillow ball mounts for the Scirocco so that I can reinstall the current mounts that are currently shared between the two cars. And the seat… the Scirocco still has the Golf seat. (I will have to order a new seat later this summer)
Also, once the suspension is together, I get to break out some measuring devices to figure out what rims to purchase to that I can mount the “new” Yokohama Advan tires.
PostPosted: Thu Apr 30, 2020 9:15 pm
Very slow progress as I don't seem to be in a rush as the race season keeps getting postponed due to all the issues with Zombies and such.
To race this car this season...
TQ all the bolts on the suspension
Address loose (I hope) power steering line on the rack
Replace the leaky two-piece hybrid oil pan with a stock one piece aluminum pan.
Reinstall race seat (currently with the Scirocco)
I do want to order another set of rims to work with the "new" tires. Can't show up at a $900 event with only one set of rims/tires (going to file this under "wheels") and spare parts.
The progress... and I learned a lot thanks to Kenji at Cusco USA. (http://www.cuscousainc.com)
The ECStuning.com parts arrived.
The "ECS Heavy Duty Rubber Rear Shock Mount Kit" was advertised as:
"The ECS Heavy Duty Rear Shock Mount Kit offers significant performance to your vehicle's handling and long term durability as compared to stock shock mounts. With the increased durometer over the OEM 50A foam-filled shock mounts, the ECS 80A durometer void-free rubber shock mounts will better resist deflection and premature wear that commonly plagues the OE mounts without sacrificing ride comfort. This is a must have if you are installing sport springs, coilovers or when replacing rear shocks."
We will see...
I also ordered some sockets that make it easier to user Allen wrenches to tighten the struts/shocks... worked fine in the rear (17mm), but the original Golf fronts were 21mm while the Gaz are 22mm. Opps.
Rear coilovers installed.
So much better than my non-adjustable Bilstien setup.
All the bolts that I need to torque on the front and rear suspension... took me a while to catalog all the torque specifications.
And finally, I ordered pillow ball mounts from Kenji at Cusco USA. (http://www.cuscousainc.com). He was a very helpful with getting me to understand all the parts of a pillowball mount. The image below was the biggest help as I did not quite understand the collar part. This is because it is actually missing from my Golf, which would explain why the nut had scrapping damage from moving within the bearing. Something that we will address later.
The new Cusco plates will go on the Scirocco (same plates as the Golf). Unsure what I will be running for suspension on the Scirocco. We will see.
PostPosted: Wed May 06, 2020 3:31 am
Another hillclimb was cancelled this year because of zombies... this one is the biggest event of the season for me.
The Mt. Washington Hillclimb in New Hampshire is normally every three years... it was moved to 2021 (instead of having to wait 3 more years). Some good news in there.
I really need to finish the Golf so that I can do other projects in the garage since warmer weather is here.... was here... and back again (gotta love Vermont weather).
PostPosted: Tue Oct 13, 2020 8:04 pm
First update since May 2020.
Grab some coffee and internet bandwidth… this is 8 pages of text without the pictures.
2001 VW Golf, 2009 Subaru WRX, and 2015 Volvo 60 news… and a 1980 VW Scirocco.
Where this dramatic story left off, the German mistress gained a new suspension and is still, to this day, sitting on jackstands.
And includes a love story. (well, a very “strong like” at the very least.. save the love for family, friends, and small animals)
All the nuts and bolts on the suspension were torqued and pretty much ready to hit the ground to finally stand on its new suspension. I will have a lot of adjustments to make at that point… ride height, setting on the struts/shocks, and perhaps some corner weighting (maybe).
Star date 11237.5… I mean, Chapter 1: Next in line is the leaky hybrid oil pan. Stock for my year car is an all-aluminum pan that doesn’t play nice with objects that might be introduced at speed. When I did some creative parking at the Mt. Washington hillclimb in 2017, I managed to get a hairline crack in the pan.
I replaced it with the hybrid oil pan that is an aluminum base with a steel bottom. This is the stock oil pan for 2004 forward on the 1.8t.
It leaked last summer, so I removed the steel bottom, cleaned it up, sealed, and reassembled. I guess I didn’t do it good enough for leak free service in the long term.
Oh, well, off comes the hybrid pan and back on is a new aluminum pan (part # 038-103-601MA).
I ordered the oil pickup that goes with the aluminum pan to make sure I was using the correct one. There is a slight difference. “A”luminum vs “H”ybrid. The hybrid version goes deeper into the bottom of the pan.
Chapter 2: Next, time to focus on the driver’s ABS wheel speed sensor wire that was damaged. I tried to order the non-brake pad wear sensor version (what I pictured in earlier posts), but it turns out that I ordered the wire for a Passat instead of my Golf. Opps. FCPeuro allowed me to make the exchange even with some time passing since I ordered the part. Nice people!
I tend to order all the parts for the various things that I will do to my car well in advance to when I actually need them.
The non-brake pad wear sensor version is just the passenger side wire, therefore, it is quite a bit longer. The outside coating is very hard to slice to expose the wires to attach the terminals.
I ordered the proper terminal crimping tool (does the terminal and weather seal).
Removed the two terminals from the plug, installed the two new wires, connected the brake pad wear sensor wires together (from the ABS module to the ECU to complete the circuit).
I ran the wire a little different than stock. From the wheel, I went to the back holder on the strut, then the front, and through the fender. I am hoping that doing it this way will keep the wire away from the rim (how the wire was damaged in the first place).
The order from FCPeuro included the ABS wire, front control arm bolts, rear brake disc retention screws (torx heads), two ball joints and outer tie rod ends (I always have an extra two in the trailer when racing), along with two bottles of power steering fluid… that will be part of the major pain in the buttocks story in Chapter 3.
Advantage of cooler weather later in the season… side door open instead of running the AC.
PostPosted: Tue Oct 13, 2020 8:11 pm
Chapter 3: Uggggggghhhhh! I hate working backwards. I had to address a leaky power steering rack. The rack came from the 20AE when I rebuilt the frontend of the Golf after an incident in 2010. I used the transmission, engine, PS rack, etc. etc. from the donor 20AE. Last time that I am going to use old parts… yeah, riiiiiggghttt.
I filled the power steering reservoir as it was completely empty, started the car, and turned the wheel back and forth.
I spent a lot of time crawling under the car and taking pictures as my camera could get in a better angle to see the rack. I thought for sure it was the new flex lines that I installed on the rack since that was the last thing that I did prior to it leaking.
The pain in the buttocks… remember in introduction when the suspension was all tight and ready for action?
Time to backtrack and drop the subframe to access the power steering rack. Fluid all over the top of it.
This is the source of the leak. It is actually the nipple from the rack that is leaking, not where the hose connects to it.
Close up. The “drip” is because I removed the line, but look at the metal on the rack. The source of the leak.
I ordered a remanufactured Bosch rack from FCPeuro… my favorite go to for our Volkswagen and Volvo parts… wish they also had Subaru parts. I figured that someone mentioned that she could see Russia from Alaska, so I figured Japan must also be pretty close to Europe. Nope.
…the “strong like” story…
Pictured on their site when I ordered Bosch 1J1422075P was a fully loaded steering assembly. The rack/pinion, inner tie rods, boots, etc.
What arrived was a little different… though, a nice looking unit.
I sent them an email, had some good constructive conversations with Gus at FCPeuro, and it seems the image on their site needs to be updated and I did get what I ordered.
Okay, I asked if they had the fully assembled rack (less work for me!) and he put everything that I needed together in my cart so that I didn’t have to fish around for what I needed. Big help.
I understand that the website images might not always be correct. No biggy.
Let’s just say that FCPeuro did a solid and handled the whole situation very professionally and beyond my expectation. It might be because I was so nice during this exchange (that was not supposed to be sarcasm.. I was very nice) or it is just because of their business ethics. I have always said that people make mistakes; what they do after they are aware of the mistake is what defines them.
I “strong like” FCPeruo. Enough where I proudly included their sticker on my car. Not something that I take lightly.
I don’t have stickers for brands of parts because I use them. Stickers are on my car because of people. People who helped make racing possible. FCPeuro is a good company with great people… I will continue recommending them.
The gang is (almost) all here.
I realized that I needed the clamps for the boots.
I ordered the clamps from ECStuning
N90834901 (large inner clamp)
N10197601 (small outer clamp)
I noticed that I had a credit sitting at FCPeuro (might have been from the Passat ABS wheel speed sensor that I returned) so I ordered the tool to use on the power steering rack clamps (same as CV joints, it seems… good tool to have) and the tool for those PITA clamps on MK4 coolant lines where I have struggled with channel lock pliers.
I noticed the distinction between “early and late” tie rods, but I do not know if it is driven by model year.
343.1mm is approx. 13.5” (early)
318.9mm is approx. 12.5” (late)
Gus at FCPeuro looked up the inner tie rods based on my VIN just to make sure I was getting the correct rods.
It is interesting that the “late” version includes 2001 (my actual Golf) and the 2003 (20AE donor rack). What the heck is “early” then (assuming it is by model year)… the MK4 came out in the US in 1999.
Chapter 4: I still haven’t installed the rack yet because of a track day coming up that has me focusing on the Subaru WRX. More unexciting news on that.
But first, let’s have a word from our sponsor and flashback to June 2020.
The hillclimbs in Vermont (and Mt Washington in New Hampshire) were naturally canceled this year. I had to make a trip to see a friend to pick up some “car parts” (inside joke, and no, it isn’t drugs) so I stopped by Mt. Ascutney. To my surprise, the access road was open. It just so happened that I arrived on the very first day that the parks were open in 2020.
Ascutney being my favorite (minus the bigger bumps growing at the top of the hill) hillclimb, I paid the day fee and headed up the hill slowly.
Beautiful views. I got FTD as no one else showed up… same scenario is needed for me to get FTD during a real hillclimb.
Picking up those car parts at a secret location in New Hampshire.
And now back to our regularly scheduled program that is in progress.
I replaced the passenger side control arm with a BFI complete control arm with VW R32 bushings earlier this year. I noticed that the driver’s side was also bad.
So, I decided that I didn’t want to find another dead bushing while at an event and ordered the SCCH front control arm bearings.
I’m a little confused who makes them and what SCCH stands for…
The instructions with the bearings show “SCCH: Suspension Components & Cylinder Heads” and provides a link to www.SCCH-Heads.com, but the actual website states “SCCH: Southern California Cylinder Heads”… don’t know.
The instructions also show “Innovative Motorsport Solution”.
Regardless, I purchased the bearings from MRP (www.performancemrp.com) and Chris (Cheesefactory Auto in Colchester, VT) did the pressing. Thanks Chris!
I have the steering rack out of the car, I might as well replace the old stock bushings with Powerflex polyurethane. I looked at the solid metal bushings (brackets at this point?), but could not justify the price. I lived this long with rubber.
Might now seem like much of an update, but I needed a horn. I am missing the high tone (didn’t replace it after the 2010 front end modification incident) which left me with the dull and muffled low tone.
At the hillclimbs, we are required to have a working horn to communicate with the checkpoint workers if something happens unexpectedly… could just be a mechanical issue and the car doesn’t run (one honk) or we hit something and need help (two honks). (removed verbosity soaked attempt to explain the complete rules that you just don’t need to know… you’re welcome)
Anyway, the PIAA horns were inexpensive and louder. I plan to mount then inside the engine bay as I figure the stock location of the horns (front bumper) would make them useless in a frontal impact. Plus, it will make it easier for me to remove the bumper in the future as I won’t have to play with the horn wires.
When I removed the rear wiper blade so that I didn’t accidently turn it on and scratch the back window and damage the stickers, I just put black electrical tape over the hole.
It worked okay, but I wanted something a little better than tape.
Heck, I even graduated from zipties in some cases.
Ordered the rear wiper delete plug from ECStuning (part number ES#3170849).
The description: “The exterior cap is made from Type-6463 Billet Aluminum to achieve the ultra-high gloss bright dip anodized finish to match the rear hatch glass and to maintain protection against ultraviolet light”
And I’m just thinking, “plugs the hole and looks pretty”
Installed…
Chapter 11teen: Reported from Joey at Kales Custom, the cage on the Scirocco is done! I am heading over there on Friday so that we can determine the proper location to mount the fixed seat (no sliders this time). Gotta remember to bring my helmet.
That is it for Volkswagen news…
Time for the Subaru WRX.
Trying to adjust the hover mode…
Or, I just have it on jackstands to install the “track only” brake pads and the Toyo R888 tires for the first (and only?) car event for me this year.
I am currently running the Hawk HP Plus if I bring the car to a small track (and I love them for daily driving), but I noticed at a track event at Canaan (http://www.canaanmotorclub.com/the-track) last year led to hot and fading brakes.
I went with Hawk DTC-60 pads front and rear for the 2020 track event.
Back on the ground with new pads and rubber (the Toyos were already mounted on my “race” rims… easy swapping)
Headed off to Club Motorsports in Tamworth, NH (USA) for a time trial event with some open track on Oct 12. Great track… lots of fun and still so much to learn.
Here is a video of part of the open track session. Because the car doesn’t have a cage or harness, and I didn’t know the track, I did spend a great deal of time coasting into the brake zone and not trying to go as fast as I could. Normally, I would drive in deep and put the brake pads to work. Don’t get me wrong, I was trying to be quick in the corners, etc., but I was cautious with my top speed and how deep I went into corners before hard braking.
[VIDEO]https://www.youtube.com/watch?v=0O4wpXlvHhs[/VIDEO]
The folks that I race with in the New England Hillclimb Association (NEHA) series organized this great event. Very little sitting with a lot of driving. 40ish drivers with a car leaving the start line about every 30 seconds. Kudos!
Some photos from the event… diverse group of drivers and cars.
This is a cool car to have back in our ranks. Charlie Rutan (brother to Bill Rutan who built the Scirocco that I have now) built this fast 1964 VW Beetle and raced it (at the very least) in the NEHA hillclimbs for many years. He retired from racing in 2000.
Somewhere along the lines, his son autocrossed the car and then ended up trying to sell it in 2016. Sometime between 2016 and the Oct 12, 2020 event, the Beetle was sold, rebuilt, and was ready for a track event. Very nice seeing this car back in action again.
PostPosted: Wed Oct 21, 2020 12:55 pm
2009 Subaru WRX... ordering performance exhaust (still planning what I want) to replace the original 150,000 miles stock system. It is my daily driver that sometimes finds itself on a track.
Before it hits the track again, I want to do through all the suspension bushings to freshen the original aging parts.
2001 VW Golf... on my list this weekend is to finish the power steering rack, install control arms (with new fancy parts), and get all the suspension 100% assembled.
That will leave the horns, coil pack mounting (will need some fabrication assistance to do this correctly), and electric brake booster install
1980 VW Scirocco... well, I think it is a 1980. Perhaps I should check.
Progress on cage. I went over to Joey's last week so that we could determine proper mounting location for the seat. It is a little strange sitting more in the center of the car than normal.
Talked about how to mount camber plates to give me camber and caster (via slotted mounting holes where the camber plates mount to the car).
Some jack pins to avoid dorking up the rocker panels. Plus, will be more secure when working on the car in the field. Some tripod adjustable jackstands in the future.
PostPosted: Thu Oct 22, 2020 5:32 pm
Artsy-fartsy image from wife of me working on the car.
Big plans turned into little time tonight.
After dinner (at 6:30) I headed out to garage to assemble the new rack (inner tie rods and new boots), remove old, and install new rack.
At 6:31, upon opening my tool chest drawer to retrieve a tool, I realized that this is going to take me a while to get READY to work.
All my tools were still in the enclosed trailer; I didn't unpack them after the track event at Club Motorsports. Oops.
7:00. Rack mounted on workbench, installed inner tie rod ends, and got ready to install boots.
Glad I assembled everything before attempting to tighten the clamps as the clamps need to be around the inner (large) boot before installation. Hey... this is new to me.
Excited to graduate from zip-ties and hose clamps on the boots.
Got everything together and ready to use my new fancy CV clamp tool. Perhaps CV clamps have different size starting position on the clamp because the tool was too small to get over the clamp.
I got creative and took the tool apart to extend its reach for the initial clamping and then put it back together to complete the clamp. The part that I removed pushes down on the head of the clamp.
I'm sure all you engineering and mechanic types out there are cringing at what I am naming all the parts of... stuff. But, you get the point.
All assembled and called it a night at 8:00. Long day... I needed a break.
PostPosted: Mon Nov 30, 2020 7:59 pm
Rack is back in and mounted to the subframe. Next step is to install the four bolts... one of the 14mm x 1.5 bolts did not seem correct so I want to chase the holes first.
Got me thinking... they are TTY bolts on subframe and steering rack. Decided not to cut any corners and ordered all new bolts.
So... PAUSE for a few days while I source a tap and wait for the bolts to arrive.
Progress is progress.
I recall having to turn the steering wheel to about six o'clock to access the bolt to disconnect the steering column from the rack.
Putting it back together I tried to do a little too much deep thinking. What do I need to turn the steering wheel to while connected to the rack to be able to get the bolt in an easy to access location while not losing "center" on the rack.
Well... that math wasn't needed.
Just put the column on the rack spline and correct the orientation of the steering wheel. Lots of splines there to be able to center the steering wheel.
I'm now thinking my rack wasn't exactly centered before.
Proper install here with easy to access bolt.
Steering wheel is confused. Will adjust when car is rolling around to ensure it is centered properly.
I ordered a new FIA (2025 expiration) OMP Sedan 2/3x3 FIA Harness, 2/3" Shoulder, 3" Lap, Pull Up, 6 point harness. Just one for now... passengers be damned!
The 2/3" for the shoulder harness has 2" at the top to work with my HANS, but widens to 3" below that point to the cam lock. (same as what I have now vs. the other option of all 2")
I made sure to get pull up lap belts to work better with my seats. (same)
Also new is the camlock is attached to the sub-belts instead of the lap belt. We will see how I like that setup. Present harness has it on the lap belt.
If I like the harness, I might order one for the passenger side, though, the rare passenger makes it hard to justify the approx $300 price tag. Could start charging $4.28 per fun run... trust me, some deep thinking math went into that number and it actually could work out. I even carried the two.
After I get subframe situated, install the control arms (new fancy solid bushings!) and the rest of the suspension. I would be able to drive the car at that point, but I still have a few things to work on.
Installing vacuum pump for the brakes (plug brake booster vacuum hole) and trying to determine if my racing budget will allow for removal of old 034EFI engine management in favor of modern VEMS setup.
We will see.
Steve
 Post subject: Re: Rabbit Farmer's 1.8T 4-door money pit
PostPosted: Wed Dec 02, 2020 1:24 pm
Progress on the 1980 Scirocco.
Joey Kale (Kale's Custom) is finalizing the cage, seat mounts, and camber plates, etc.
Here are some images that Joey posted on his Facebook page to show the recent progress.
I think the quality is top notch.
We are using the exact same camber plates as what we used on the MK4 Golf. Joey is building a structure on the strut top so that the camber plate is mounted underneath this structure vs. the camber plate being mounted to the topside of the strut tower. Should be much stronger.
Added in slotted mounting points to allow some caster adjustment as we are trying to dial in the alignment.
Some photos of the cage work...
Good progress.
Yep... I need to get the Golf done as the Scirocco needs to park in the garage where the Golf is sitting. Golf to the trailer for winter storage.
More progress!
Steve
PostPosted: Tue Jan 19, 2021 11:34 am
First update for 2021.
So much was accomplished since November, but would have been completed back in November if I didn’t have one #$%^! hole that was dorked up.
Back in November, the new steering rack was attached to the subframe and the subframe was in place and ready for the four M14 bolts to attach to the car.
One hole wasn’t quite right… I could not easily tighten the bolt by hand and wanted to chase the threads.
I tried a chase, but it would not work as the threads were too messed up.
I ordered new TTY M14 x 1.50 pitch bolts for the subframe and new TTY bolts for the power steering rack along with a M14 x 1.50 tap and die.
With the subframe still in place, I used the tap on the threads (everything felt good).
But… when trying to torque the bolt, I got that terrible feeling when you know the threads checked out and headed to Florida for vacation.
Off came the subframe (power steering rack on jackstands). One step backwards.
This is the front right mounting point for the subframe. Per the Bentley manual, the front mounts, which is a captured nut, is not serviceable with a helicoil unlike the rear mounts. Bentley states to replace the entire assembly, though, I would think cutting a hole and replacing the nut would also be a good option.
I had a conversation with my hillclimb racing cohorts about Heli-Coils; are they a good option for a captured nut, are they strong enough, etc. The responses were very positive.
Then someone mentioned Time-Serts as another option. Hmmmm, internet research of Heli-Coils vs Time-Sert showed both were good options, but I really liked the design of the Time-Sert (a threaded barrel with a lip on top as a stop) for fixing the subframe threads.
Ordered M14 x 1.50 kit from Amazon.
The kit includes a 57/64” S&D drill bit, counterbore, tap for the Time-Sert barrel (unsure of the actual tap size), driver, and four inserts.
Thankfully, I purchased a 1/2" drill back in 2001, used it once to drill three holes in my open trailer, and haven’t used it since.
Drilled the hole for the insert slowly with lots of oil.
Normally, the next step is to use the counterbore to allow for a flush install of the insert as the top has a lip, but it wasn’t needed in my case as the hole in the unibody was adequate.
Tap for the insert.
Installing the insert using 30W oil (per the instructions)
The new threads.
Installed the subframe (new threads worked!), control arms, axles, etc.
This picture captures everything that I did to the car over the summer… obviously, in no rush as there were no events.
* New power steering rack with harder poli mount (there is only one as the second is all metal)
* Control arms with metal bushings
* New ball joints and outer tie rod ends
* New oil pan
* New brake calipers and pads
* New wheel bearings and hubs (right side didn’t need a new hub)
* New suspension
* Changed left front wheel sensor to a non-brake pad wear sensor version (had to depin at the ABS module)
Close up of the rear control arm bushing.
I noticed that I had to full seat the new struts. Was not able to do when installing; had to wait until I was able to put the full weight of the car on it.
Loosened the strut bolt. I also used a strut spreader on each side; unsure if it was necessary.
Good thing I purchased two of the Metal Nerd (MN3424) strut spreaders. I ordered two as I was worried about misplacing the small tool.
Properly seated and everything is tight again.
Torqued inner and outer axle bolts.
I noticed that the right wheel had a heck of a lot of negative camber.
Prior to the new suspension, I had set the right camber plate all the way negative to match the left side that was more in the middle. Something was off with right vs. left. Whatever it was, the changes I made this summer corrected it.
Top view of left and right wheel and camber plate to show the difference.
Car on the ground. I still need to determine ride height (pretty close to stock height), adjust the strut/shock damping, and align the front end.
I forgot that I had this little gem. Custom made “Rabbit Farmer” badge for the back of the Scirocco.
Then there is the 2009 Subaru WRX. It didn’t pass state inspection back in October due to a leaky exhaust system. It is the original… can’t expect it to last forever, especially with the salty winters in Vermont.
I have been trying to find the Invidia Q300 cat back exhaust (model number INVHS08SW4GT3) since October, but it was back ordered on every vendor’s website. I finally ordered it from RallySportDirect for $726 (with taxes) on Black Friday to get 10% off knowing that it was still on back order. The estimate at that time was early December, which changed to late December, then mid-January.
It arrived on January 18.
Based on reviews, the Q300 is not loud and doesn’t drone. I was looking for something a little better than stock and cheaper than an OEM Subaru exhaust. Oh… and stainless steel.
I would install the exhaust myself, except I know that I have to address a leaking shifter shaft seal on the back/top of the transmission. I plan to bring it to a shop for the transmission leak and exhaust install.
Then to Subaru for alignment and inspection.
For my information for the next time I am taking everything apart at a race should I need the torque specs and forgot the Bentley at home:
Powersteering rack to subframe: 15 ft/lb + 1/4 turn
Subframe (all four bolts) to body: 74 ft/lb + 1/4 turn
Ball joint bolts to control arm (3 bolts): 15 ft/lb + 1/4 turn
Outer tie rod to hub: 33 ft/lb
Control arm (front bolt): 52 ft/lb + 1/4 turn
Control arm (back bolt): 52 ft/lb + 1/4 turn
Dogbone to bottom of transmission (2 bolts): 37 ft/lb
Inner axle bolts: Control arm (front bolt): 59 ft/lb
Axle bolt to hub: 184 ft/lb + 1/4 turn, back off 1/2 turn, roll car to rotate wheel 180-degrees, 184 ft/lb + 1/4 turn
www.VermontRacing.com
PostPosted: Tue Jan 19, 2021 7:47 pm
This is a great thread. I'm not sure if you care, but you might be interested to know that VW uses time-serts themselves. I purchased a VW factory remanufactured engine from VW once, and they had used time-serts to fix some damaged threads on the head. I have also used them on other things and they seem to perform very well.
PostPosted: Tue Jan 19, 2021 8:15 pm
That is interesting. I really like the Time-Serts better than Heli-Coil design. Just seems like it would work better (in my unprofessional opinion).
PostPosted: Wed Jan 20, 2021 8:34 am
Invidia Q300 cat back exhaust (model number INVHS08SW4GT3) from www.rallysportdirect.com/ for the 2009 Subaru WRX.
Unpacking to check out the construction. Only one small dent in shipping; there was some metal to metal contact in the package... there was more packing between the exhaust and the outside of the box than between the exhaust pieces.
Seems to be a nicely constructed exhaust system. Looking forward to getting it on the car. Included bolts and gaskets for the three-bolt flanges. I need to determine what I am going to do with exhaust hangers (stock or aftermarket). The car is pretty stock.
PostPosted: Fri Feb 05, 2021 3:31 pm
More progress.
More pictures than words.
1980 VW Scirocco MK1 with 1.8T
Getting closer with cage, camber plates, jack points, etc. at Kales Custom (Joey Kale)
Body plate to support the camber plates almost done. Very strong and functional. Will have to get a little creative with the hood to work around these.
2001 VW Golf MK4 with 1.8T
Smaller hotside to the turbo.
Turbo is GTX2863R with 42mm external WG / 6852 housing ; previously it was the 3652 housing. Just purchased the 2552 housing to spool quicker. I believe this is the smallest I can get for my turbo that is a direct replacement.
I had to get schooled how to read these numbers on the housing as they didn't make sense to me. Hopefully I was paying attention.
Essentially, just reverse the first two numbers for the A/R.
Previous 3652 (.63 A/R)
Current 6852 (.68 A/R) which is larger... I actually wanted to go smaller from the .63
New 2552 (.52 A/R)
Smaller A/R should make things spool up a little quicker. Fingers crossed.
I am still looking to replace the 034EFI engine management and go with VEMS.
With the new .52 A/R hotside, desire to go with pump fuel, and VEMS, we will have a very different driving car this summer. I assume we will have lower power numbers (less speed in the straights), but hopefully have better acceleration out of the corners.
I thought of trying 15" wheels this summer (better gearing.... I hope), but with the excess supply of 17" take-offs from Vermont SportsCar, I will have to stay with 17" for now.
2009 Subaru WRX Impreza 2.5
I would have installed the new cat back exhaust myself, but I also need the seal on the shifter rod (unsure exactly what it is on this car) is known to leak. Since I wasn't sure what was needed for that project (or how to do it), I brought the car to Cheese Factory Automotive (Colchester, Vermont) for the exhaust install and address the transmission leak.
Done quick and correctly. Very happy with the result. Now to get that inspection sticker that expired in October.
PostPosted: Tue Mar 09, 2021 7:59 am
Volkswagen MK1 Scirocco
In the words of Ozzy… “Mama I’m Coming Home!”
Joey laying out some boards to make the transition to the ramp easier (the car was too low). Jumping on the internet bandwagon with Bernie doing the assist.
Joey took lots of pictures during the build. I will share after I get them.
Volkswagen MK4 Golf
I ordered the replacement FIA 6-point harness (driver’s side only). I think I must have missed the part in the description that stated these were for harnesses that mount to the bar in the back of the car.
No problem… I will just roll up the excess and put a ziptip around it.
The difference with this harness is the release is attached to the two anti-sub straps.
My concern with this is having the bar that connects the two points being uncomfortable on top of my legs. I will have to pay attention when adjusting (the installation process) to ensure it is in the correct location.
I have the old race seat in the Golf at the moment as the new seat is in the Scirocco for the cage building. What I did notice is that the release does not fit through the hole on the bottom of the old seat… means that I have to partially uninstall the race seat to bring the anti-sub straps through the top of the seat vs. installing the straps and feeding the release through the hole in the mounted seat.
The good news is that the new seat (which belongs in the Golf) has a huge hole in the bottom to make the installation much easier. Whew!
Next… I have to adjust the height of the suspension in the Golf.
I realize that I was cranking the coilover collar up (raise car) a lot trying to get to stock ride height. I want to start with the stock ride height to get the suspension geometry correct.
Stock is 15.5” front and 15.25” rear measuring from the center of the wheel to the lip on the fender. (I have also seen 395mm front and 390mm rear which makes the rear a little greater than 15.25”)
It seems that I was wasting a lot of spring travel (compressing the single spring trying to get the height correct). So… I decided to add a second spring to the mix.
I changed the setup from a “main and helper” to a “main and tender”.
New spring is ERS-175-250-200 (number printed on spring)
(3.05” free height) - (2.5” diameter) - (200 #/in spring rate)
I had a hard time trying to determine how the first number worked on the Eibach springs.
Eibach part number: 0175.250.0200
(175) Load at block height: 350 pounds, travel is 1.750 in.
(250) Coilover spring inside diameter (in): 2.50” (63.50mm)
(200) Spring rate: 200 lb/in
Spring is 3.05” (77.47mm)
Things I need to further research:
* Block height (I think this means fully compressed spring)
* Preload (excessive preload of the coil spring increases the force to start shock movement)
PostPosted: Fri Mar 19, 2021 12:05 am
If you are still looking to change over from 034 to VEMS, Mark Swanson made an adapter cable for my CQ when he changed mine. Used the same sensors and wiring, already installed.
Just a thought.
Greg W.
Post new topic Reply to topic  [ 404 posts ] Go to page Previous  1 ... 13, 14, 15, 16, 17  Next
  |  It is currently Thu Apr 22, 2021 5:08 am
