Post new topic Reply to topic  [ 183 posts ] Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
SAYODA's Audi Coupe V8 Build - Runs and Drives!!
PostPosted: Sun May 10, 2009 4:32 pm
sayoda wrote:
ordered up a couple small parts:
ABZ flexplate
pilot bearing
Do you mean flywheel?
Flexi's for auto.
PostPosted: Sun May 10, 2009 5:00 pm
master of teh modz
Lookin' good! Should be making fire in no time 8)
Don't Panic
- Douglas Adams
PostPosted: Fri May 15, 2009 7:24 pm
siena wrote:
ABZ flexplate
pilot bearing
Flexi's for auto.
Nope Flex plate... the boys at 034 told me I needed one to make a custom flywheel! 8) and damn it looks good!
------steve
1990 Audi Coupe
PostPosted: Fri May 15, 2009 7:27 pm
thanks, nate... i'm shootin for some sparks first... and then some fire!
------steve
1990 Audi Coupe
PostPosted: Wed May 20, 2009 2:57 am
I couldn't resist this shifter, she sure is a sexy piece of aluminums!!!
Slapped on my refinished wood knob for a pic...
File comment: new shifter
------steve
1990 Audi Coupe
PostPosted: Wed May 20, 2009 3:05 am
We also got to work-
-battery posts in the engine bay
-started running the cable from the battery
Which leads to a question- (since Summit only sent the positive cable with the kit and a short section of negative)
Should I run a neg. cable from the engine bay to the battery anyways?
Or will I be fine grounding the battery near the battery and grounding the neg. post in the engine bay?
An old school neighbor already said he's always run both pos/neg all the way when relocating a battery....
File comment: Yup.... crooked on purpose :)
------steve
1990 Audi Coupe
PostPosted: Wed May 20, 2009 3:12 am
Thanks for the input on powder coating... my buddy and I have talked about getting the Sears setup for awhile.
But we decided to leave them as is... for now.
File comment: all there, gunk and all
File comment: abz cover
------steve
1990 Audi Coupe
PostPosted: Wed May 20, 2009 3:52 am
Individual grounds are fine. When Audi installed jump start posts in the T44 cars (batt under rear seat), they only put a hot post. You ground to the engine...
http://coupe.gofergusons.org
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Wed May 20, 2009 6:03 am
I was gonna say, ground the battery with short cable and don't even need negative post up front, but you can make it if you want to.
Nice progress! Keep the pics coming..
Peter
PostPosted: Wed May 20, 2009 7:02 pm
the motor geeks boys say it can be done!!! thanks much....
more progress to come....
------steve
1990 Audi Coupe
PostPosted: Mon Jun 29, 2009 9:09 pm
nice project!
Did you have to run any special distributor blockoffs on the 3.6 to run COP ignition? I have always thought that would be easier than dealing with the distributor space issues...
White Mountain Watercooled
PostPosted: Thu Jul 02, 2009 5:06 am
i'm using 034 blockoff plates to delete them.
finally made some small progress... it's very slow, very slow progress right now!
but we have moved the brake lines and the proportioning valve to gain some extra needed clearance... pic shows the jumbled mess of brake lines :roll:
someday maybe we will rebend some new ones!
fuel lines have been moved in the engine bay and almost done under the car.
found a few minutes to put on the new shifter... now i really want to drive the damn car!!!
------steve
1990 Audi Coupe
PostPosted: Thu Jul 02, 2009 5:13 am
brake proportioning valve moved
and
shiny aluminums shifter
File comment: brake lines
File comment: pure awesomeness
------steve
1990 Audi Coupe
PostPosted: Thu Jul 09, 2009 2:10 am
Looks good, very good thread, has given me some good ideas for a v8 into my 80
 Post subject: Finally got started again.
PostPosted: Sat Jan 09, 2010 3:14 pm
we haven't made much progress in the last couple monthes... no time!
So I'm posting a couple pics/excuses...
then a small update!
1st pic/excuse - wife wanted to get into riding (she took the class, got her license, got a bike....and wanted to spend every spare moment RIDING)
2nd pic/excuse - 2 bay was too small for a project car and my construction stuff.... so build another bay!
3rd pic/excuse - my truck/trailer were getting stuck in the mud... put in a driveway with some pavers we had left ova!
File comment: my wife, her bike and my bike
File comment: new attached shed on right
File comment: new driveway
------steve
1990 Audi Coupe
 Post subject: small update
PostPosted: Sat Jan 09, 2010 3:26 pm
here the car has sat waiting patiently.... note the freaking dust.
we finally finished running the battery cables... done.
and we started laying out the 034 harness, and WOW... I knew it was going to be high quality, but .... WOW! It's sux that most of it will be hidden including the shiny IIc.
So that's where we are right now, trying to make a game plan on how to delete the wires and such that we don't need in the engine bay... I only want to do this once. Meaning only cut wires once!
File comment: she needs a freaking bath
File comment: Apparently it didn't install itself yet!
------steve
1990 Audi Coupe
PostPosted: Sun Jan 10, 2010 3:55 pm
What an awsome build. Keep up the good work.
87' 5KTQ Dying if i don't get it in a project.
88' 90Q
90' V8Q It's drivable.
00' A4 Avant DD
PostPosted: Sun Jan 24, 2010 9:54 am
Started deleting un-needed wires out of the stock v8 harness.
We got rid of the old fuel injector plugs so far..
We also found a fuel saving device (green magnet) on the fuel line that the previous owner installed :D those things were a joke!
We also tried to install the 034 block off plates, and we couldn't get either to fit? They were both different sizes??? We weren't sure if we were supposed to take off the spacer block that attached the distributor to the motor.... but they didn't fit with those off either?
So anybody use these with any success?
Last, I'm having the plastic intake machined out-of aluminums... i'll post some pics when it's done...
File comment: started removing wires
File comment: original wiring
File comment: back of the motor
File comment: green magnets = funny
File comment: block off plates
------steve
1990 Audi Coupe
PostPosted: Sun Jan 24, 2010 3:08 pm
The one with the O-ring goes on the side without the hall sensor in the distributor, after completely removing it. The one without the O-ring goes on the side with the Hall Sensor over the distributor body after you cut the shaft shorter I believe.
I do wish 034 would be a little more explicit with the description on their website for those parts. Adam and I had the same confusion.
1995 A6 Quattro
1996 A6 FWD
1998 A6 Quattro Avant
PostPosted: Sun Jan 24, 2010 3:34 pm
Excellent! I will give that a try. THANKS
------steve
1990 Audi Coupe
PostPosted: Sun Jan 31, 2010 10:34 am
the advice for the block-off plates was spot on!
File comment: cut the shaft shorter
File comment: back of the motor, now distributor-less!!!
------steve
1990 Audi Coupe
PostPosted: Tue Feb 02, 2010 11:34 pm
awesome build just bought a 90q sedan upgrade from my 80q sedan and am contemplating a 3.6 swap you should put up a master list of all the parts bought for the swap when your done :woowoo:
PostPosted: Sat Feb 27, 2010 7:00 am
thanks for the compliment --- and as for a master list, WOW i wish that i had one 8)
but wouldn't that take the fun out of it???
------steve
1990 Audi Coupe
PostPosted: Sat Feb 27, 2010 7:06 am
so we went from comparing the old Nardi wheel I have to the newer audi 3 spoke wheel that I just got...
what do you guys think?
to pulling the dash.
we figured we wanted to delete some wires that we won't be using and adding some new ones...
File comment: Nardi vs. 3 spoke Steering wheels
File comment: dash is out
File comment: heater core is out --- time to play with the rats nest
------steve
1990 Audi Coupe
PostPosted: Sat Feb 27, 2010 1:48 pm
-an 034 hole has appeared through the firewall
-all the switches (abs, seat heaters, rear defrost, front fogs, rear fog) have been deleted, along with the plugs and wiring (to make room for the innovate display.
-I can't believe all the abs and airbag crap, it will all be gone!
-the stereo will be rewired (in my opinion the owner before me had a professional hack wiring/install job done)
-finally finished removing the wood from the interior and added the carbon pieces i had
File comment: a 034 hole
File comment: we found a plug that fits
File comment: misc. stuff to remove
File comment: interior before
File comment: empty
File comment: wood and cf
File comment: getting ready for epoxy
File comment: ta the - #1
File comment: ta the - #2
------steve
1990 Audi Coupe
  |  It is currently Thu Apr 22, 2021 4:24 am
