Post new topic Reply to topic  [ 183 posts ] Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
SAYODA's Audi Coupe V8 Build - Runs and Drives!!
PostPosted: Sat Feb 27, 2010 4:19 pm
Looking good Steve! Keep the progress going! You will be driving in no time :woowoo:
-Mike
87 Audi 4000Q AAN GT30R- Sold
90 V8Q- Sold
78 Harley Shovelhead
PostPosted: Sat Feb 27, 2010 4:39 pm
THANKS..... and driving it is the Ultimate goal!!!
------steve
1990 Audi Coupe
PostPosted: Sat Feb 27, 2010 4:52 pm
Nice progress. Keep up the good work.
87' 5KTQ Dying if i don't get it in a project.
88' 90Q
90' V8Q It's drivable.
00' A4 Avant DD
PostPosted: Sat Mar 13, 2010 9:28 am
opened up the heater box, needs a little spring cleaning!
we are trying to install the IIc in its new home under the heater box...
the next step will be to install it all now and hopefully it doesn't interfere with too much stuff (our fingers r crossed)...
and then remove it to seal it all back up, and cut and reroute some of the ductwork for our feet, and then put it all back in again.
at this time i'm also putting in a new heatercore... makes sense!
i'm wondering if i should replace any a.c. stuff at this point?
(besides the fact it stopped blowing cold air when we started to take it apart)
File comment: we don't want no trees growing in here!!!!
File comment: temp. mounted for now
File comment: relay panel will be mounted here
------steve
1990 Audi Coupe
PostPosted: Wed Jun 02, 2010 6:40 pm
been working on the car a little bit...
-heater core assembly back in (034 ecu mounted)
-dash back in (stereo rewired --- sounds mint)
-still working on fiinishing the rest of the wiring
and my rota wheels came in ....
File comment: heater core assembly
File comment: 034 mounted
File comment: wheel test fit
------steve
1990 Audi Coupe
 Post subject: Re: SAYODA's Audi Coupe V8 Build - Starting the 034 IIc inst
PostPosted: Sat Sep 25, 2010 8:04 am
Summer has dragged on and fall is finally here!
Project has been dusted off and resumed were left off...
Some small updates too follow:
Biggest problem is I couldn't get my computer to play nice with the IIc ecu (stoopid vista and no actual comm port)
Long story short but a laptop was built for the car (thanks MIKE)
File comment: Mike hard at work
File comment: and the communication works!
------steve
1990 Audi Coupe
PostPosted: Sat Sep 25, 2010 8:10 am
I got a 245/40 17 tire mounted on one of the wheels (checking fitment)
Fits awesome out back, but the front tie rod ends will need to be flipped for clearance.
And the brake kit from 034 is awesome.
File comment: front - tie rod clearance issues
File comment: 034 brakes
File comment: comparison with the g60
File comment: rear
File comment: front
------steve
1990 Audi Coupe
PostPosted: Sat Sep 25, 2010 8:19 am
We are trying to figure out how to get the guages to work on the coupe.
The 3 center gauges are volt, oil pressure and oil temp.
volt gauge already works
oil pressure (do we just hook up the sensor from the v8 to the coupe's harness?)
oil temp (same thing)
File comment: oil temp, pressure and coolant temp sensors
------steve
1990 Audi Coupe
PostPosted: Sat Sep 25, 2010 9:02 am
What offset are your wheels? I have et30 and zero clearance problems
//Dave
PostPosted: Sat Sep 25, 2010 3:13 pm
the wheels are 35... are you running the same size tire that i will be?
------steve
1990 Audi Coupe
PostPosted: Sat Sep 25, 2010 3:21 pm
we are exploring replacing the oil pressure gauge with a new tranducer and digital readout.
what do you guys think?
File comment: new idea / oil pressure
------steve
1990 Audi Coupe
PostPosted: Sat Sep 25, 2010 4:43 pm
yeah 245/40s 8" wheel
//Dave
PostPosted: Sat Sep 25, 2010 6:04 pm
unfortunately the tires do rub (the pic doesn't show it properly, but i couldn't get the wheel fully seated...
gotta be the slightly different offset, not really a big deal. just need another alignment.
------steve
1990 Audi Coupe
PostPosted: Thu Feb 05, 2015 9:07 am
Figured its time for an update!
Finally got a bath on 11/29/13 on the way to the coupe's new home
File comment: my boys approve
------steve
1990 Audi Coupe
PostPosted: Thu Feb 05, 2015 9:33 am
Finally making time to work on it again (at least a couple hours a week)
progress made so far:
-new fuel pump and new fuel lines
-working on new brake lines
-installed radiator, working on hose layout
-clutch and timing sensor installed
-made sure that the bumper still fits!!!
------steve
1990 Audi Coupe
 Post subject: Re: SAYODA's Audi Coupe V8 Build - working on cooling (radia
PostPosted: Thu Feb 05, 2015 2:05 pm
I'm in the midst of a similar build. I am putting the ABH from my 93 V8 into a 1990 Coupe.
Using the whole ABZ intake and valve covers but I'm going VEMS instead of the 034 EMS.
I thought I had read through all the v8 coupe threads here but hadn't seen this before. Nice work so far!
CURRENT
1995 90Q 20VT
- 1987 Porsche 924S - 1979 Porsche 928
PAST
1994 Cabriolet - 5 speed - 1986 Audi Coupe GT - 1993 Audi 90 CS Quattro - 1990 CQ - V8 - 1995.5 Audi S6 - 1993 Audi V8 - 2013 A5 Prestige - 2011 A4 Avant
PostPosted: Tue Oct 27, 2015 9:44 am
Update
garage: 1990 Audi CQ rally build
2008 Audi A4 Quattro DD
PostPosted: Thu Nov 12, 2015 9:26 pm
Update?
Started it for the first time tonight!!! We took way too big a video to download :)
Tomorrow I'll hopefully take a vid to post here. (Never loaded a video b4?)
Open headers, sounded great...
------steve
1990 Audi Coupe
PostPosted: Thu Nov 12, 2015 9:37 pm
Awesome! Can't wait to hear it!
CURRENT
1995 90Q 20VT
PAST
PostPosted: Sat Nov 14, 2015 7:54 pm
FIRST START LINK
Link to video
https://youtu.be/xNqu0yWnJ8g"
------steve
1990 Audi Coupe
 Post subject: Re: SAYODA's Audi Coupe V8 Build - FIRST V8 START!!!
PostPosted: Fri Nov 20, 2015 7:43 am
Replaced my fuel rails, redid the lines and installed an adjustable fuel pressure regulator.
The rails are from E F I express, I'm very happy with them!!
(I will add pics soon)
------steve
1990 Audi Coupe
PostPosted: Fri Nov 20, 2015 7:53 am
New fuel rails
------steve
1990 Audi Coupe
 Post subject: Re: SAYODA's Audi Coupe V8 Build - Runs and Drives!!
PostPosted: Sat Sep 08, 2018 6:43 am
Finally hooked the fans up.
File comment: v8 engine bay
------steve
1990 Audi Coupe
PostPosted: Sat Sep 08, 2018 3:07 pm
Installed a side exist exhaust (downpipes to a single 3")...
File comment: Side Exit
File comment: Carbon Fiber Side Exit
------steve
1990 Audi Coupe
PostPosted: Sat Sep 08, 2018 5:30 pm
Exhaust before it was finish welded...
File comment: Tack welded
------steve
1990 Audi Coupe
  |  It is currently Thu Apr 22, 2021 3:06 am
