Post new topic Reply to topic  [ 76 posts ] Go to page Previous  1, 2, 3, 4  Next
Barry's '90 200TQA - parting out, emotional support vehicle
 Post subject: Re: Barry's '90 200TQA - vacuum brake boost conversion
PostPosted: Thu Jun 06, 2013 3:23 pm
After much deliberation and head-scratching, my vacuum brake booster conversion is finally finished! I wrote a how-to on Quattroworld HERE.
Pic of finished product:
booster vacuum line by a-talk, on Flickr
(*edit*)
Many thanks to Nick Lawrence, loxxrider and yodasfro for their advice on this one.
2014 Audi Allroad Premium Plus - the daily driver
1990 Audi 200 Turbo Quattro Avant - rear-ended by texting driver, parting out
1984 Porsche 944 - Mathilda the needy
PostPosted: Thu Jun 06, 2013 3:56 pm
oh yeah! That's sweet.
How do the brakes feel now?
Peter Peterson
1999 Miata
(Sold) 1990 Audi 200 Quattro 10VT - Project Thread: https://www.motorgeek.com/viewtopic.php?f=6&t=37948
PostPosted: Thu Jun 06, 2013 4:24 pm
They feel good, just as solid as the old hydraulic booster to me. And the whole conversion was much cheaper than the $850 or so for a new hydraulic booster :D.
PostPosted: Thu Jun 06, 2013 5:05 pm
I saw your writeup on QW. Can you go into more detail when you removed the pistons from the pump?
Peter Peterson
1999 Miata
PostPosted: Thu Jun 06, 2013 10:59 pm
I didn't take photos of that process, but it's pretty simple. There is a piston under each X cap on the PS pump. The front two X caps nearest the pulley provide the power to the brake boost. Remove the X caps, remove the pistons inside, reinstall X caps and the brake boost is disabled.
PostPosted: Fri Jun 07, 2013 9:28 am
Here's an image explaining the PS pump mods. Original photos stolen from eBay, modified by me:
PostPosted: Wed Mar 12, 2014 12:20 pm
Any way to repost the pics how you trimmed the trim to fit the steering wheel? They disappeared.
PostPosted: Tue Mar 25, 2014 11:40 am
Is this conversion the same for 91 20v?
Looks like almost the same system although I don't have the lines going into the passenger side of the master.
PostPosted: Tue Mar 25, 2014 11:47 am
Exactly what car is the b3 9" booster out of?
Passat/80?
PostPosted: Tue Mar 25, 2014 2:09 pm
Also did your brake light stay on after the conversion?
Because of low/no accumulator pressure?
Thanks for the info
PostPosted: Tue Mar 25, 2014 3:56 pm
To hit all your questions, Android222:
- I believe the conversion to be the same for the '91 20vt, but I have not done that conversion myself. My current PS pump, however, is off a 20v car
- The booster I installed is PN 893612107A, which was used on B2 and B3 chassis cars
- My pressure warning system does not light up. I cannot remember now if I had to jump the sensor wiring, or if the sensor was looking for a connection between those two wires to illuminate a warning
Thanks for the info
 Post subject: Re: Barry's '90 200TQA - quick updates
PostPosted: Tue Mar 25, 2014 4:28 pm
It's been awhile since my last update, and there have been three major projects completed. I do not have much in the way of photos, but they are important:
1) I installed Eibach lowering springs and new Konis on the car. I love them. Photos below.
2) I had a local shop install an 034 LW flywheel, a Southbend Stage 1 clutch, new subframe bushings, and 034 motor and trans mounts
3) I had the local exhaust shop install a 2.5" exhaust. First is a high-flow cat, then a resonator and lastly a Magnaflow out back with a subtle black tip
Needless to say, 1st and 2nd gear pulls are even more entertaining than before :D. And the sound matches the speed - subtle, growly, and pretty fast. These two upgrades alone have transformed the driving experience of the car. So right now I mostly just drive and enjoy it!
on Eibachs and Konis
at a local EV station :)
PostPosted: Tue Mar 25, 2014 4:32 pm
Oh and several little fixes, including:
- a rebuild LF axle from Raxles
- a new glove box light
- black interior grab handles and lamps
- a leather handbrake handle from France (that one still needs some massaging)
 Post subject: Re: Barry's '90 200TQA - new clutch, new Eibachs, new exhaus
PostPosted: Sat Dec 06, 2014 7:03 pm
GORGEOUS avant man!!!!
91 Audi V8 Quattro Black/Black OEM 5speed (Later to be Red/black 4.2L 6speed)
03 Audi S8 Avus grey/Oxblood red (later to be 6speed)
91 BMW 850i - Red 6speed
94 BMW 850Csi - Red 6speed
94 & 95 Ford Thunderbird Supercharged 5 speed
92 Mustang convertible 5speed
PostPosted: Sat Dec 06, 2014 7:47 pm
Lowering it really set it off and gave it a different look. The Euro headlights, 3 spoke wheel, and vacuum brakes are an awesome conversion. Clean!
PostPosted: Sun Dec 07, 2014 9:15 am
Thanks 'RS200Q' and 'CaifanSC'. She's still doing well, with the occasional 'Audi Gods' breakdown :P. Just a few nights ago I started smelling coolant while driving. Pulled over and peeked under the hood and saw the coolant tank seam leaking. Will be taking care of that over Christmas break.
(*edits*: it was the coolant reservoir that was leaking not the radiator. That came later.)
PostPosted: Thu Mar 24, 2016 1:24 pm
Quick update!
I've done so many things to this car in the last year. But I haven't had much time to post updates as I am in school as well. Right now the car is in pieces as it receives a new timing belt, water pump, and radiator. And as we all know, the "while you're in there" list grows when you have old cars apart.
Current status: apart and undrivable
Imagefront end off car by Audi Talk, on Flickr
Imagemid timing belt job by Audi Talk, on Flickr
PostPosted: Thu Mar 24, 2016 1:28 pm
Also, I started shopping for a replacement daily driver a few months back. The old 1993 Audi 90S was getting tired and not worth rebuilding. And as much as I love the old 200TQA, it is not reliable enough for DD duty in a desert climate. So I picked up this 2010 A4 Avant in white and love it!
Imagefront1 by Audi Talk, on Flickr
Imagefront_interior by Audi Talk, on Flickr
 Post subject: A serious update, a serious crash
PostPosted: Tue Nov 28, 2017 1:20 pm
Hello all! I realize I am overdue on posting progress reports on my 1990 Audi 200 Turbo Quattro Avant, but continue reading and the reason for my silence will become clear. The good news is that I did get the car reassembled and it ran great. After new injectors, a new radiator, timing belt, seals, water pump, lifters, and an intercooler upgrade, the car ran amazing!
Engine put back together
Imageengine compartment by Barry James McCabe, on Flickr
Preparing for the first start after repairs
Imageready to start by Barry James McCabe, on Flickr
Treated the car to a car wash reward for passing emissions!
Imageafter emissions testing yay by Barry James McCabe, on Flickr
But then something happened.
On March 1st, 2017, I was driving the Avant to have lunch with a friend. While waiting at a busy stoplight, the car was rear-ended by someone not paying attention while driving a jacked-up Ford Super Duty. Because of the height of the truck, the impact was taken entirely by the rear quarter panel and hatch. This was the result:
Scene of the accident as I look sadly at the car, with "Ford super doody" in the background
Imageright after the accident by Barry James McCabe, on Flickr
It's even worse inside the hatch area
Imagerear quarter was damaged by Barry James McCabe, on Flickr
At first, the insurance company wanted to write off the car for a ludicrously low amount. Fortunately, I have receipts for every repair done to the car since my ownership (over nine years). After submitting my repair records, the insurance company finally settled for an amount that didn't completely insult me. However, as there are no more straight lines anywhere in the rear hatch, the car was deemed not repairable. I bought the car back from the insurance company and converted it to a salvage title in order to save all those sweet sweet parts. Now it sits in my backyard broken, sad, and not legal to drive.
Since then my wife has had job instability and I have not been in a place to make a decision on this car. I will likely not repair the car as it will always be a salvage title car. I have contemplated buying another Avant. Or perhaps moving on to another mark for a change. Right now I make sure to drive it around the neighborhood every week or two to keep the fluids moving. And of course, it runs the best it ever has since my ownership :P.
More to come.
 Post subject: Re: Barry's '90 200TQA - A serious update, a serious crash
PostPosted: Tue Nov 28, 2017 2:18 pm
man, that is some messed up junk. Don't get rid of it yet...at least you have time to figure out what to do. Next thing you know, you and the fam are in a better position and you may have a chance to just fix it. If done right, who cares about the salvage title. Let's be honest...these cars are not on the top of the list to accrue $ to the point where salvage title makes a difference.
Best of luck either way man.
PostPosted: Tue Nov 28, 2017 8:06 pm
Thanks CaifanSC, I appreciate it. It might be possible to fix the car by acquiring a donor. The shop I talked to thought they could straighten the rear on a rack, but I think the hatch would always leak as everything is squiggly now. Also, I am not certain the hatch hinges are still straight at the roof area. Or, I could swap over all the nice parts to another chassis.
PostPosted: Wed Nov 29, 2017 10:47 pm
I agree with CaifanSC ... .. worth looking into a donor car
Don't know where you're located, but i found this donor candidate on CL.
https://columbus.craigslist.org/cto/d/1 ... 89034.html
PostPosted: Sun Feb 24, 2019 12:09 pm
:blog:
https://www.ebay.com/itm/1989-Audi-Othe ... 0005.m1851
Austin
PostPosted: Tue Feb 18, 2020 8:05 am
With the car sitting, and with parts become harder and harder to find, I had to make a decision. I am parting the car and getting out of vintage Audis:
First FS ad here: https://www.motorgeek.com/viewtopic.php?f=4&t=218471
More to come as I clear out storage.
Say it ain't so!
https://youtu.be/ENXvZ9YRjbo
PostPosted: Mon Apr 20, 2020 2:32 pm
I bought an “emotional support vehicle” project to get me through parting out my beloved “Beast”. It’s a 1986 Jetta GLI Wolfsburg Edition in grey with the rare grey leather interior. It only has 66k original miles, but also only has 1/2 a clutch! Meet my new project, “50 Shades of Grey” :D.
Round 2 of Avant parts will go live soon ...
Image1986 Jetta GLI by Barry James McCabe, on Flickr
Imagefront interior by Barry James McCabe, on Flickr
Users browsing this forum: Bing [Bot] and 2 guests
  |  It is currently Sun Aug 01, 2021 1:54 pm
