Post new topic Reply to topic  [ 398 posts ] Go to page Previous  1 ... 11, 12, 13, 14, 15, 16  Next
 Post subject: Re: JBD's Project CQ - Starting on the 3B Swap...
PostPosted: Wed Oct 07, 2020 10:39 pm
i will try my picture when i put the euro cq bumper next to the s2.
s2 comes out significantly more
edit: not mine but you can see it
¯\_(ツ)_/¯
PostPosted: Thu Oct 08, 2020 6:34 am
Thanks Chris for that comparison pic. Got any stashed away that you might be willing to sell? I have mine that I can trade.
Brent
1991 CQ - Project Car
PostPosted: Thu Oct 08, 2020 7:10 am
I dont, but send me a pm on FB and let you know who has it.
¯\_(ツ)_/¯
PostPosted: Thu Oct 08, 2020 7:15 am
Message sent!
Brent
PostPosted: Fri Oct 09, 2020 7:43 pm
What I would do..... if I was going to keep the euro bumper.... put the IC in front of the rad. Seen it done on a few 450+ bhp cars in the UK. Just get a cheap ebay IC and run a slightly longer pipework tract.
PostPosted: Sat Oct 10, 2020 4:07 pm
I’d like to retain AC, but have seen some people run ICs above the cross member and behind the grill.
Found some time today to work on the floor pans. POR15 is on. 3 coats on the driver side, 2 on the passenger side. Next up, decide what sound and heat material to use.
Brent
PostPosted: Mon Oct 12, 2020 6:54 pm
Floor looks a lot better, good work.
What about using a 10v urq type of intercooler?
PostPosted: Mon Oct 12, 2020 8:11 pm
Why dont you sell him a bumper?
Ive sent him to you direction on FB :)
¯\_(ツ)_/¯
PostPosted: Mon Oct 12, 2020 8:35 pm
Crossing my fingers that we can do a deal.
Brent
PostPosted: Sun Oct 25, 2020 12:03 pm
Sound/heat barrier is in.
Brent
PostPosted: Thu Nov 05, 2020 3:43 pm
Did you keep the previous sound deadening in? Or scrape it out?
PostPosted: Thu Nov 05, 2020 3:47 pm
I removed it with a heat gun and scraper, followed up with some mineral spirits to remove the sticky residue.
Brent
PostPosted: Thu Nov 05, 2020 3:51 pm
How was applying the Por15? I’m about to do the same, I lifted the insulation of my coupes floor and also found some surface rust, so I need to go and remove all the old sound deadening and spray.
PostPosted: Thu Nov 05, 2020 3:56 pm
Not bad. The time consuming parts are in the prep (i.e. clearing the surface, degrease, metal prep, and letting it dry out completely). I applied 3 coats to the driver side and 2 coats to the passenger side. Make sure your area is well ventilated and use a respirator.
Brent
PostPosted: Sun Nov 22, 2020 3:09 pm
Made some progress on the suspension and brakes today. Rears are pretty much done.
Brent
PostPosted: Sun Nov 22, 2020 3:27 pm
Looking good
1983 Audi 4ks Plain Jane
1990 90q 20v: Project?
1982 Honda v45
X2 1995 S6 part cars
 Post subject: JBD's Project CQ - Starting on the 3B Swap...
PostPosted: Sun Dec 20, 2020 3:30 pm
Work has been keeping busy and out of town a lot lately, but I managed to spend the afternoon cleaning and organizing the garage and cleaning the CQ’s carpet. It’s not perfect, but much better than before. Rust stains are tough to get out.
Brent
PostPosted: Sun Dec 20, 2020 8:30 pm
Carpet has come up good.
PostPosted: Mon Dec 21, 2020 12:38 pm
Thanks!
Brent
PostPosted: Sun Jan 10, 2021 1:36 pm
It feels like I went 10 rounds with it, but the 7A harness has been removed. Could have used a couple more hands.
Brent
PostPosted: Mon Jan 11, 2021 6:49 am
I see a lot of people have routed their 3B harness through the hole for the AC lines due to how the 3B harness is built. I intend to keep AC and am considering cutting a new hole in the firewall somewhere on the passenger side (with a firewall grommet). I'd rather do this then have a bunch of wires that are either too long or too short. Plus, the driver's side area under the dash doesn't need any more wiring than it already has. Any thoughts on that?
Brent
PostPosted: Mon Jan 11, 2021 10:23 am
This is what I'm doing but with an AAN harness. I cut a hole to the left of the A/C hole, I'll shoot you a pic on IG, it seems like it'll work out pretty nicely.
-Shawn C.
2002 B6 A4 3.0l->1.8t+Southbend+VEMS+Rods+HX35=happy daily
1987 5ktq most reliable $500 I've ever spent
1989 200tq Avant- Gone but not forgotten
1986 GTI- longterm project
And one brindle pup in the back
PostPosted: Mon Jan 11, 2021 11:09 am
Much appreciated!
Brent
PostPosted: Wed Jan 13, 2021 10:15 pm
I think I’m mostly done with stripping down the 7A harness.
I do have a question about this T7 connector. I think it’s for the coolant thermoswitch. I did not remove it yet. Am I supposed to keep it?
Brent
PostPosted: Thu Jan 14, 2021 8:01 am
:blog:
That's for the 7A sub harness, MFTS coolant temp sensor and oil pressure switches.
Austin
Users browsing this forum: Google [Bot] and 1 guest
  |  It is currently Thu Apr 22, 2021 4:26 am
