Post new topic Reply to topic  [ 151 posts ] Go to page Previous  1 ... 3, 4, 5, 6, 7  Next
audiurq project 1983 ur-q Restoration 30 Years in
 Post subject: Re: audiurq project(s) thread
PostPosted: Sun Dec 02, 2012 11:30 am
Mike, time to update the thread!!
Martin Pajak
www.quattro.ca
83 80 q - Euro 2-door!!
85 Ur-q - Euro with 3B
93 90 quattro - S2 Limo copy
04 A4q avant 1.8T USP 6-speed
04 A4q avant 3.0 USP 6-speed
PostPosted: Mon Mar 11, 2013 2:59 pm
Maybe time for an update and a change in direction....?
PostPosted: Mon Mar 11, 2013 3:21 pm
Just don't tell Paul.. :)
Martin Pajak
www.quattro.ca
PostPosted: Mon Dec 09, 2013 9:07 am
It has been a while, but I am determined to make some progress on the '83 over the Winter months.
To that end I installed a 5000W,18K BTU ceiling heater in the garage on Saturday. I read good reviews
of this heater and I can honestly say I love it. I insulated the walls and ceiling several years ago and
installed insulated doors a couple of years back. I had been using a small radiant heater which was
only good it you were very close. This ceiling mounted unit is awesome, so no excuses....
Not one of my favorite jobs and the cold garage gave me an excuse to avoid tackling it.
Spent a few hours cleaning the block, another couple and it should be done. The garage can now
be set at the right temperature, even for painting parts. I know her indoors is thrilled by the prospect.
PostPosted: Tue Feb 04, 2014 9:15 am
Needs a bit of work still..... Anyway the front side glass is in, door handles etc
Gear box freshened up a bit
Pistons in process of being cleaned
Hopefully get the engine parts in soon and get the short block in the car.
PostPosted: Tue Feb 04, 2014 9:32 am
Any tips on how you got the block and trans 'cleaner than clean'? They look *very* nice!
And.. What's the secret scauce the you are cooking the pistions in? That seems to work quite well too!
-=Frank=-
Image <- "The Twins" Image
PostPosted: Tue Feb 04, 2014 9:49 am
Thanks Frank,
For the block and transmission it was naval jelly and lots of wire wheeling.
For the pistons I soaedk them for 24 hours in "Gunk" and then use a green plastic
scowering pad and brake cleaner.
PostPosted: Mon Nov 24, 2014 10:14 am
So put the 4kqt back on the road for winter. It has been dormant for
18 months and didn't take kindly to recommisioning. Since it is my daily
driver, reliability is the most important thing. So I started with cosmetics...
obviously....
I tried out some plasti-dip on the Fuchs....
Before:-
During:-
After
PostPosted: Mon Nov 24, 2014 11:10 am
How is the reliability? The white Fuchs must make some kind of a difference?
Martin Pajak
www.quattro.ca
PostPosted: Mon Nov 24, 2014 11:11 am
No improvement in reliability but +10HP, +15 foot/lbs
PostPosted: Mon Nov 24, 2014 12:12 pm
Do not forget 10 more mpg.
"Nulla tenaci invia est via"
1990 20v coupes (2 X red)
95.5 UrS6
1996 Cabriolet.
 Post subject: Re: audiurq project 1983 ur-q Restoration 21 Years in
PostPosted: Tue Jan 27, 2015 9:44 am
So a momentous couple of weeks for my '83 ur-q. It started like this:-
Lightened flywheel:-
Windage tray and clearance holes for ARP main bearing studs
I considered both early and late style clutch forks, because I don't like the design
of the later style plastic release bearing:-
Old style
New style
I ended up going with the plastic one, because it is the "correct one"
Engine and transmission ready
It might not look like it, but I made some room and moved the car so I didn't have
to open the doors
Getting close
So, the car came off the road in 1994, after 21 years it finally has an engine and transmission
back in.....
:) :cheers:
PostPosted: Tue Jan 27, 2015 10:44 am
thats awesome.. i just got a urq and ive been gathering parts everywhere.. good luck and keep it up im definitely keeping a eye on this one...
PostPosted: Tue Jan 27, 2015 11:59 am
that's one way to keep 'em low mileage
2017 8v S3
Integrale EVO1
UrQuattro 07k
Porsche 968
Coupe Quattro
Lancia Scorpion
Lancia Beta Coupe
PostPosted: Tue Jan 27, 2015 8:38 pm
Wow.. I am speechless... beer to celebrate?? ;)
Martin Pajak
www.quattro.ca
PostPosted: Tue Jan 27, 2015 9:05 pm
Great to see this project still underway!
If you have a 5 cylinder, you don't need a stereo
Homologation car junkie.
PostPosted: Wed Jan 28, 2015 9:04 am
Oh boy, you are gathering steam now. I may need to dust off the quattro so you don't beat me. ;)
PostPosted: Wed Jan 28, 2015 7:58 pm
Mike is a man on a mission... we expect to see it running this year!!!
Martin Pajak
www.quattro.ca
PostPosted: Wed Oct 21, 2015 2:09 pm
So it's getting cold here and I need to get a winter car ready.... I parked the 4ktq in
the spring when it was running poorly. It over heated in the fall previously and had
been getting worse - culminating with coolant in cylinder #1. The head gasket:-
The head+manifolds+downpipe was a bit of a PITA to remove as everything is heavily rusted....
Anyway I was thinking of putting in a K24. I know this means I need to reprofile the MAC11
boost profile, so does someone have MAC11 code for a K24 on an MC1?
thanks, Mike
PostPosted: Sat Nov 14, 2015 4:02 pm
My urq has a MAC11 running with a k24. Seems to work well! Coded by someone reputable (but I can't rememeber who)
However.. As I understand, IS also coded to accommodate the urq flywheel, which has the timing pin located a few degrees different than on a MC? If you can get the code out..? :-)
-=Frank=-
 Post subject: Re: audiurq project 1983 ur-q Restoration 25 Years in
PostPosted: Mon Oct 15, 2018 10:40 am
Right - so it's been a while, I think the car came off the road in 1993.
So in celebration of being parked for 25 years.... I am going to finish
what I started. Spring 2019 will see one more quattro back on the road.
Watch this space :)
PostPosted: Mon Oct 15, 2018 10:47 am
Hell yeah, get on it!
//Dave
PostPosted: Mon Oct 15, 2018 11:37 am
Glad to hear that Mike, we are here if you need help or emotional support.
Did you find that glovebox??
Martin Pajak
www.quattro.ca
PostPosted: Mon Oct 15, 2018 3:15 pm
Hell yes !!!
Let's get that boat out the water. Get the garage heater on and we'll be there
 Post subject: Re: audiurq project 1983 ur-q Restoration 30 Years in
PostPosted: Mon Jun 01, 2020 8:46 am
So still working on the car.... Earlier this year I was very sorry to hear the original owner
of this car, Neil Peart died - way too young.
There has been a bit of progress and I will start posting updates to motivate me and try to get
this finished - 30 years seems like a good round number to complete the "rebuild". Still trying
to beat Steve E.
Also got another bit of a project that I will be working on, stay tuned.
Cheers, Mike
  |  It is currently Tue Sep 22, 2020 9:41 am
