Post new topic Reply to topic  [ 290 posts ] Go to page Previous  1 ... 8, 9, 10, 11, 12  Next
Casey's V8 5spd:Cort's, no, Casey's, no, Cort's, no Keith's!
 Post subject: Re: Casey's V8 5spd:Cort's, no, Casey's, no, Cort's, no Keit
PostPosted: Sat Feb 25, 2017 7:00 pm
Drives like a new car again. Completed during the past two weeks: Timing belt service, full tune up, coolant flush, power steering flush, things are starting to look up for the good weather.
P.S: don't reuse the hardware for the water pump etc , rounded out torq heads that are sitting recessed in = nightmare for removal. Will post some pics later on.
Plan to dive into it more tomorrow and tackle some minor things. Get the horn working again, adjust headlights, make some sort of spring for the fuel door, and of course give her the nice inside and out clean she deserves.
Also, currently searching for some BBS LMs, OZ Futuras, or even BBS speedlines. Thinking those should suit the car well.
Mike
'91 V8Q Pearl w/5 Speed
'90 CQ Alpine White / AAN
'90 CQ Crystal Silver
'91 90Q Tornado Red (RIP)
'86 Monte Carlo SS
PostPosted: Mon Feb 27, 2017 8:37 pm
Of course, I have everything fine and leak free for a few days and now one pops up. Smelled some oil burning, checked under the car and can see it leaking on the manifold as well as oil on the ground. Leads me to believe the rear main needs replacement, fan fkn tastic! Everything else seems to be dry, not sure where else it would be leaking from at back of block. Plan to tackle said leak sooner than later, though I'm sure I could get away without for a bit and just drive the car and enjoy it, but it's going to bother me, so that's doubtful.
Stay tuned
Mike
'86 Monte Carlo SS
PostPosted: Wed Mar 01, 2017 11:47 am
Check both distributors and the seemingly irrelevant "cam inspection plate" that's just below the passenger distributor...all common rear leak spots. Also Audi issued a TSB at some point changing the oil level from 10 to 8 quarts, but never reissued a dipstick, so you should be running at the bottom of dipstick, otherwise will have excessive consumption/leakage, especially out of the potentially rotted out rear breather on drivers head.
90 V8 Lago Blue 113K(nice)
93 V8 Pearl 205K(Sold)
91 V8 Indigo pearl 5-speed 165K(Love)
90 V8 Titan Grey 125K (parted)
91 V8 Indigo Pearl (parted)
91 V8 Panther Black 198K(sold)
90 V8 Panther Black 218K(sold)
04 Silverado 2500 HD 4x4(forever)
87 Silver Saab Turbo 205K(given away to friend for project)
4 other Saabs that I'm starting to miss.
PostPosted: Wed Mar 01, 2017 11:49 am
Oh, and if it is indeed coming out of rear main....be thankful its not a 450lb autobox....Ha
PostPosted: Sat Mar 04, 2017 8:04 am
Tom, thank you.
I had let the level go down and it seems to have solved the issue , or brought it to a very minor issue now. I can't believe it. We'll see how long it lasts, for one thing , the driveway ( or what's left it if) is going to be happy to have no leaks on it.
Aside from that, everything is solid. Going to look into getting the holes in the doors solved. Slowly as it gets warmer I'll revive all the trim outside again as well as the rockers. Locate myself some nice summer tires and perhaps wheels and get her ready for the show season
Mike
'86 Monte Carlo SS
PostPosted: Tue Mar 21, 2017 6:49 pm
Well it happened today. Spirited driving on this spring like day of course came to an abrupt hault when I heard a big pssssh followed by that sweet smell and then my feet becoming soaked with coolant. I have been dreading doing the heater core but I have no choice now. I'll need to hit the package store to get me through this one . Wish me luck
Mike
'86 Monte Carlo SS
PostPosted: Wed Mar 22, 2017 6:54 am
Mike
'86 Monte Carlo SS
PostPosted: Wed Mar 22, 2017 8:42 pm
Aaaaaarrrrrrggggg. Bummer. I parked the 5-speed quite awhile ago when I noticed some small blue drips on the drivers carpet. Since I also need to do the rack/driveshaft support bearing and entire suspension, was waiting for the time/energy to pull the motor as both the rack and heater box would be easier with the motor out of way. I did drive it to the gas station last week and was praying it wouldn't let loose like yours did....If the padded mat is really bad, I may have a spare grey one....I'll look.....Hey, at least it's not one of the cars that has ECU right in middle of the puddle.....I feel your pain....Tom
PostPosted: Sat Mar 25, 2017 7:54 am
Freaking bummer man! The V8 gods demand a fresh sacrifice. You really don't have much that can go wrong now, do ya?
91 Audi V8 Quattro Black/Black OEM 5speed (Later to be Red/black 4.2L 6speed)
03 Audi S8 Avus grey/Oxblood red (later to be 6speed)
91 BMW 850i - Red 6speed
94 BMW 850Csi - Red 6speed
94 & 95 Ford Thunderbird Supercharged 5 speed
92 Mustang convertible 5speed
PostPosted: Sat Mar 25, 2017 7:56 am
Wow, really??? I didn't know this. Good to know. So if you want to check the oil "full" should be if you are at the bottom part of the existing dipstick?
Wonder if there is a longer dipstick we can use...that's kind of annoying.
PostPosted: Sat Mar 25, 2017 8:30 am
Bummer yes, but you are right there. With the timing belt done, now the heater core to be done, I guess the next major issue will be the clutch, which nearly isn't as bad as either of them. Regardless I do kind of enjoy it as it puts me that much closer with the car. I knew what I was getting into buying an older audi, and I'm completely ok with it.
Mike
'86 Monte Carlo SS
PostPosted: Sat Mar 25, 2017 8:33 am
Amen brotha...i know this awaits me with mine. Not if...when....and I'm also cool with it :). Great cars these.
PostPosted: Tue Apr 11, 2017 3:28 am
Back in action just in time for the beautiful weather coming around. FYI for those looking todo heater core / blower box resto , a blower motor from 92-94 v8 with the 4.2 will work; though the cage/ fan itself will need to be salvaged from the original and mated with the new motor as the cage/fan from the 4.2 doesn't fit properly.
Need to source myself a new A/c compressor, as well as accumulator while I'm at it. It looks like it might be the same as the one a coupe takes ? I would assume the v8 shares some parts with the others.
Mike
'86 Monte Carlo SS
PostPosted: Tue Apr 11, 2017 6:18 pm
That was quick! Glad to hear you're back in action.
PostPosted: Tue Apr 25, 2017 9:18 am
Next project is the a/c system. Got myself a new compressor and of course the clutch is incorrect. Came with v belt clutch , have to source myself a new serp belt 6? Ridge clutch? Maybe someone has a P/N I could use to get one. Once that's sourced should be pretty straight forward, and finally have a car with A/C
Mike
'86 Monte Carlo SS
PostPosted: Wed Apr 26, 2017 6:19 am
maybe you should look at what's on the car now and replace that. Don't assume that what's on the car now is necessarily what the car came with from the factory - someone may have swapped parts or converted the setup previously
1991 Coupe Q Silver/Platinum
http://www.naaclub.org
PostPosted: Wed Jun 07, 2017 12:04 pm
I'm at the point now where I'm going to enjoy the car, but feel I'm in the market for something different soon. I do really enjoy the vehicle, but I simply don't have the time I used to have to be able to tinker away at it. I'm open to offers/ trades, just seeing whats there. As of right now, the car needs an A/C clutch to get the a/c operating, and a little tlc of course. There is a small amount of oil weeping, seems to be from the rear main, so that would need to be addressed. I can provide receipts of the recent jobs (timing belt, heater core etc,) You all know the car, I've done nothing further (modification wise) so referring to the older pictures shows how it looks. Not in a rush to get rid of, but feel I can't take care of the car as I had hoped. Work is picking up, I need something a bit more reliable, though I'm not biased to another older audi, 5 cyl turbo. Let me know, I can provide you with as much info as possible from my end (pictures and all) upon request.
Mike
'86 Monte Carlo SS
PostPosted: Thu Jun 08, 2017 3:29 pm
If you were to sell it, do you know how much you'd want for it?
-Phil
87 5ktq - 3b swap, VEMS "TurdQuat"
91 v8 - 5spd
05 s4 - "Daily"
PostPosted: Fri Jun 16, 2017 12:37 pm
Thought some things over, have not fully committed to getting rid of it. It's a love hate with the car, but there are issues that need to be addressed. Just replaced coolant reservoir as the old one was borderline about to explode with all the micro cracks. Also freed up the electric cooling fan which was inoperable. Next is to tackle the a/c. Sourced some compressors new that are a fraction of the cost (nice when non audis use the same parts but the cost for them is close to nothing ) once that is good, there at a few other things trying to source. New instrument cluster, and window regs all around ( if anyone has a lead that would be awesome,) I plan to go to my local pick n pull and see what they have
Mike
'86 Monte Carlo SS
 Post subject: Casey's V8 5spd:Cort's, no, Casey's, no, Cort's, no Keith's!
PostPosted: Sat Jul 15, 2017 3:43 pm
Today's fun. Looks like a perfectly good factory original ignition switch, right ?
Mike
'86 Monte Carlo SS
PostPosted: Tue Jul 18, 2017 3:39 pm
Fix one thing and the Audi gods immediately decide that is not allowed. Walk out from office just to find the entire power steering system has dumped onto the ground, needless to say I am thrilled. Next project.:
Mike
'86 Monte Carlo SS
PostPosted: Wed Jul 19, 2017 4:44 pm
New p/s pump ordered, looks like the one on the car is kaput. P/s fluid flowing like a river out of the backside, either a crack in it, or seals are f**$ed. Sourcing new low/high pressure lines to go with it, should make a big difference.
Mike
'86 Monte Carlo SS
PostPosted: Wed Jul 26, 2017 10:15 am
In all it's glory, ready be put in this weekend
Mike
'86 Monte Carlo SS
PostPosted: Fri Jul 28, 2017 3:07 pm
More goodies , let the work commence
Mike
'86 Monte Carlo SS
PostPosted: Fri Jul 28, 2017 5:41 pm
shiny parts! What are you doing for your steering hoses? Custom made?
  |  It is currently Thu Apr 22, 2021 4:30 am
